I replaced my RFTs with non-RFTs and it was great. This was on my previous 2007 530i. My RFTs were constantly showing up as low on air in the TPM. Just get the right replacement tires. My new ones drove great, but they became very noisy after about 10,000.Thinking of changing my run flats,just wondering if anyone has done this,and felt a complete difference with proper tyres,feels like driving a bone shaker.
Where do you get the idea there is any more air in a non run flat tire? Run flats carry 34-42 psi (on my 535i) just like non run flats.I've searched the threads a bit more, and it seems an argument can be made the other way in that the run flat tires can cause damage themselves due to their hardened compound and lack of air compared to that of a pnumatic (sp) tire. It's possible that the cushion that can be gained from more air in a tire (as in a pnumatic tire) may be more protective to wheels than the RFTs.
The pressure has nothing to do with the volume in the tire. Higher pressure with a smaller volume can result in less air being in the tire so it was a valid comment/question. If the run flat has the same psi and a smaller air volume.....it has less air.Where do you get the idea there is any more air in a non run flat tire? Run flats carry 34-42 psi (on my 535i) just like non run flats.
dj
I get the pressure vs volume thing, I dealt with that sort of thing my entire career, so I'll ask you the same question, where do you get the idea there is any more air in a non run flat tire? Or any less volume in a RFT? :dunno:The pressure has nothing to do with the volume in the tire. Higher pressure with a smaller volume can result in less air being in the tire so it was a valid comment/question. If the run flat has the same psi and a smaller air volume.....it has less air.
Brand new tires are always gonna start out quieter.:dunno: Give them a while and report back.I know it's been a couple of weeks since this thread had begun, but thought that I would throw in my two cents worth... I just turned 32K miles on my OEM Dunlop RFTs and had them changed out. Personally, I like the idea of having the RFTs when driving at high speeds but thought the Dunlops were a bit rough. I priced out several brands from TireRack.com and spoke to one of my local tire shops who actually beat their prices (by a lot)! I decided on the Michelin RFTs and I have really noticed a change in the ride. They definitely ride much smoother and quieter than the Dunlops and have a similar speed rating...
+1. Funny how everyone who rates a new set of tires always notes how much quieter they are than the set they just replaced. My experience is that the closer a tire gets to its wear limit, the noiser it gets. I've never had a new set of tires that was noisier than the ones I took off - regardless of style.Brand new tires are always gonna start out quieter.:dunno: Give them a while and report back.
dj
