1 - 3 of 3 Posts
Has anyone had a problem with their running lights burning out. My 2006 530xi has has the right side running light burnout 3 times. The computer says the Right High Beam Light is out, but it's not that lamp. Both headlamps work and so do the high beams on each side. If you had the problem, besides replacing the bulb, was there something else that needed to be replaced? Thanks for your anticipated help.
1 - 3 of 3 Posts
