1 - 20 of 42 Posts
Was out playing after going out with friends today.
Whee! It's fun to have the response of a summer tire with worse traction than contitouring contacts. Power oversteer is something I very rarely get to play with. :D
G
I think you'd believe me when I say I can kick my tail out at will right now. It's kind of unnerving.
Discussion Starter #3
Re: Re: S-03s are a real blast in sub-freezing weather.
In an M3 I'd be unnerved. In my car, countersteering is a rare treat. ;) (And it still takes a hard 90 degree turn at high revs in first or second gear to do it.)
I can only imagine the fun with AWD and such low grip levels. With my snows and RWD I have to take extra care to avoid coming ALL the way around. Especially with one rear wheel spinning. :cry:
Discussion Starter #5
My seat vibrates in the corners. :p I wish I had one wheel spinning. :(
Trust me, it's annoying as hell. I have literally had the inside wheel spinning for 100ft after a turn in 2nd. The car barely accelerates. This is in the cold, of course.
Discussion Starter #7
I'd just like to be able to turn ADB off. :p In sharp corners under power, the car feels and sounds like a vibrating bed. :mad:
I like cookies.
Re: Re: Re: S-03s are a real blast in sub-freezing weather.
:lmao:
Thankfully, I can still get a bit of power oversteer occasionally, but it does push too much.
With a bit more front bite, I the car would be quite a bit more balanced.
Speaking of 90, that is the fastest that I have had to correct for oversteer in my car. Kinda hairly :yikes:
I like cookies.
:lmao: :lmao:
Pull the fuse again :p
Discussion Starter #10
nate328Ci said:
:lmao: :lmao:
Last time I did that, there were places on my tires where the tread depth was 50% of that of the rest of the tire. :p Too expensive.
I like cookies.
I think you might need to work on your threshold braking :p
Can't you feel a single wheel lock up? I know I can sense it when the ABS is working one wheel, but I haven't had to feel one wheel lock w/o ABS since the E28 533i. I never ruined any tires :p
Discussion Starter #12
I can feel it... But if I'm, say, going into the stopbox (especially when there's a guy standing at the end), I'm not going to let up on the brakes just because a rear wheel has locked up. :p
I like cookies.
How do you lock a rear wheel on a car with such heavy front bias?
Don't be such a puss, many cars are out there sans-ABS :flipoff:
Discussion Starter #14
Lots and lots of brake dive. :p
I like cookies.
Still, you shouldn't be locking a rear wheel...
And, yes, I have seen the braking pic in your sig. Not too great :eek:
Discussion Starter #16
Out of curiosity, how heavy is the braking bias?
OMGWTFBBQ
Nick, I think that you would do yourself a world of good by picking up a cheap, older car with handling "character" and no electronic nannies...well, so long as you didn't hurt yourself with it. :p Something like an E30 w/o ABS (preferably a 1984 318i), a mid 80's Mustang or F Body with a 302 or 305 (respectively) or an '85 Corvette (final year w/o ABS) would be great teaching tools. There are others...
Discussion Starter #19
Some day I'll get myself an old Miata. :p
Edit: I suspect, though, that most cars without ABS are substantially easier to prevent from locking than our current generation Bimmers.
Old Timer
'have renewed respect for those CH95's
the ones that i hate in summer?
they're quite decent in the slush and snow.
'was pleasantly surprised. they are far better than the brig. RE92's on the rexy, which are horrible in any weather condition.
have played with S03's in the slush. those tires float and it was like being a cali-boy surfer in a car.
1 - 20 of 42 Posts
