Hi All just wanted to give some feedback ,
So @640jims , mentions the use of Lithium based grease, I do NOT recommend using this type of grease, if you pay close attention the bushing is of s Plastic nature , so lithium contains properties that breakdown plastic over time.
Therefore i went with a Teflon based grease, it performs well in low or high temperatures , is generally used in load bearing situations.
When you look at the bushing under the front seats (This is done by moving the seat to the far back as possible and then raising the seat high to the max) then tilt your head down and look straight up towards the front edge of the seat)
Place a micro-fiber to cover electronics and carpet, then spray liberally "use the straw provided with the canister" make sure you get the inside of the bushing and outside edges.
Let the car sit for a while so the grease really soaks in , then try it out.
Tested my 6 GC 15' right now and no movement no squeaks . I use to get movement by making even the slightest turn , really uncomfortable
I just wanted to thank everyone on hear for all there help and advise, I might still build the bracket that Allan mentions , its fairly easy to construct.
Feel free to reach out if any of you need some help with this issue.
