Secondar air system , error code 2760
8673 Views 2 Replies 3 Participants Last post by  Hallivand
Hello,
Does an error in the secondary air system produce a rough idle/misfire only at cold start (around 1 min)?
The pump is running but what I get is error code 2760 Secondary air system-Air flow too low and some misfire codes on different cylinders each time.
engine is 100% perfect after the cold start, no stored errors efter the cold start (I erase them by INPA).
Thanks for any help!
George
1 - 3 of 3 Posts
I have this same problem.... HELP
Run the codes - what does it say for your vehicle? Secondary Air System errors can point to your valve stem seals going / CCV system having problems.
1 - 3 of 3 Posts
