1 - 5 of 5 Posts
My car originally did not come with xenon headlights so I bought oem bosch xenon headlights with self leveling motors built in. I have successfully installed the headlight but I don't see them self leveling when I first turn on the car. I have 2 plugs from the factory (gray & black) one is connected to the xenon portion and the other to the high beams. On the headlights I see another connector(4pin I think) is that power for the motors? Where do the motors get power from. How to make this work? Thanks
You have to do an autolevel retrofit, you will need a bunch of wirings and the sensors mounted. You will also need to buy a new LCM (if im not mistaken) and need to reflash your ecu for the autolevel to work. Do you want autolevel DIY instructions in PDF file?
We want the Lion!
emeren said:
Yes please. Instructions and pictures would be great. Thanks
If you would do a search you'll find that many people have done this.
1 - 5 of 5 Posts
