My 328is currently has about 83k miles on it. When fixing an oil leak, I noticed some build-up in the engine compartment (see photos). My mechanic said this was due to a PCV, which is supposed to pull out excess water out of the engine compartment.
I live in Minnesota and at the moment, is very cold here. I imagine the insulation on the PCV isn't enough to perform well in cold weather. I didn't even want to touch it because it seemed brittle. The build-up seems to be because the water isn't being evacuated properly. Mechanic told me that BMW came out with a newer version of this PCV which has a foam insulation.
My questions:
Thank you in advance!
My questions:
- Does the build up look serious?
- Are you aware of a replacement PCV that will do a better job of extracting moisture?
- Is there any way to clean out this build-up in the compartment? Or should I assume that a new PCV will clean this over time?
