I'm working with a 2008 535xi with 140k miles on it.
So yesterday I heard a thrashing sound after a light turned green as i was accelerating forward. This was followed by my power steering failing, charging error, no charging ports, and air conditioner becoming weak. Panicing me was a block from Orielly autoparts, they ran a diagnostic amd said it was the alternator and sold me some power steering fluid just in case. So after ordering new alternator last night I took another look at it. From what im seeing its just my serpentine belt that was broke. I do have an oil leak but the belt was dry so I don't think that caused it to come off the rotating pieces as is a suggested cause in other posts. Is there any way to tell if the alternator is bad as well? I want to just resell the alternator I get if it was just the belt.
On how to fix videos they also replace the pulley tensioner. How do I know if I need that? I'm going to fix it myself so I want to know what all parts to order. Also, what is the parts the belt rotates on called? I'm not a mechanic but I'm a pretty smart dude and normally fix stuff myself with do it yourself videos on YouTube so I dont know what all the parts are. One of those appears to have tangled a piece that splintered off the belt so I'm assuming thats why it snapped. That piece still has a chunk stuck in it and its harder to rotate than the others so do I need to replace that part or you think once i get it opened up and unwrap the piece of the belt twisted in there it will be fine?
From other posts I saw something about having to check the oil for chunks but im not seeing how it would possibly send chunks in there. How would I check for that? Just empty the oil like i would changing it? I do see little pieces on the drivers side laying on other tubes and the shrout but everything is looks closed off so I dont see how it would end up in the engine oil.
I have included what pictures i could from observations without taking anything apart yet. Looking for advice from people who have done this before.
