1 - 6 of 6 Posts
it shakes bad at 45-55 idk what the problem is.. i have new tires, balanced, and no bent rims.. someone was telling it could be the trust arms but im not sure.. any ideas guys?
Premium Member
Start with inspecting the thrust arm bushings. Get the car in the air, and look closely at the bushings....take a large screwdriver or small pry bar and (gently) move the arm a bit and look for cracks or fluid leaking form the bushing. Moving the arm will expose the fine cracks, if there are any. If there are even a small amount, I would go ahead and replace them both. I was getting some vibration when braking from high speed and this fixed it.
It's not that bad of a job. Do a search here, there is a good write-up with pics that should be quite helpful.
1 - 6 of 6 Posts
