1 - 2 of 2 Posts
My wife has a 1997 328i that has developed a problem with the shift indicator lights. When it's in Park the light for "P" is on, but in all other gears, nothing. I would assume it is nothing major but you know what they say about assuming anything!! Any thoughts or help in clearing this problem would be great.
Bob
shift light
My 325is does the same thing.. its a loose connection on the connector plug for the l.e.d. if you gently pry up the plastic cover you can see the plug.. disconnect it and tighten up the pins a little bit.. that should take care of it.. hope this helps.
1 - 2 of 2 Posts
