1 - 8 of 8 Posts
SO my UUC motorworks EVO3 short shifter arrived in the mail the other day. I didn't quite understand the directions, and it sounded pretty hard. I was wondering how complicated it actually is, or if anyone knows of any places in the west la area (or greater la area) that could install it for me.
thanks!!
The easiest way to do it is on a lift or by jacking the car up.
I jacked the car up and supported the rear of the tranny while I removed the bolts that hold the cross support that holds up the back of the tranny.
You can then lower the tranny a few inches to get your hand up there to disconnect the old shifter parts.
I was able to install a new shifter without lowering the transmission, but it would have been easier to lower it as Jim did. Here's a link to replacing the shift bushings on an e36.
I would think that just about any transmission shop should be able to install a SSK since you have to remove the shifter to lower the transmission and replace the clutch.
Just heads up if you also ordered the DSSR from UUC there is a chance it will rub/contact the carrier/aka shifting arm (part #2 in the diagram). It may not be an issue with the 540, but it was with my 530. I called them and asked about it prior to ordering the DSSR and they said that was a problem years ago on the M5s only and it would not be an issue. But when I got my car back after the install I could not get the car into reverse. The fix ending up being to grind down the carrier a couple mm so there was no longer contact.
http://bmwfans.info/parts/catalog/E39/Sedan/USA/540i-M62/LHD/M/2003/june/browse/gearshift/gearbox_shifting_parts/
1 - 8 of 8 Posts
