Finally back on the project, this time with the Getrag 260/6.
The replacement parts were extensive and required a bit of planning before pulling the trans.
I sourced a single mass flywheel from a an earlier 635 that needed to be shaved. It was more difficult than I thought finding those single mass FWs. About $230 invested in purchase and machining which I consider fair... I suppose.
Everything else I got from Pelican Parts, which is local to me and include:
Front and rear seals, shifter seals, clutch plate, shorter flywheel bolts, TO bearing...
I had been ordering from them for years, even while living back in Chicago. They are overall helpful but ran into a bit of a hiccup when parts were shipped separately. No one is perfect, so always consider shopping around. BavAuto is my other go-to source for new parts but have found a local guy in Redondo Beach who has some e34's for parts.
All in all, it was a diy job but it's significantly more difficult without a lift and a shop.
There really wasn't anything wrong with the clutch, but I had to decided this was one thing I to prevent from failure.
The previous owner was from Henderson Nevada and did not keep up with the vehicle as it needed so I have been taking care of things in the order of most urgent priority, to the not so urgent priorities and eventually aesthetics.
Next up is brake fluid and coolant flushes... and anything else that needs immediate attention. :thumbup:
