1 - 17 of 17 Posts
post pics... should be interesting
Thebizzy.com
Thebizzy.com
Drilled/slotted with powder coated hubs.
Just a Gigolo
:wave::yummy:
Thebizzy.com
Mmmmmm. Is anything sexier than a sweet BBK? Nice!
I'm going to be needing new rotors soon and these look like a STEAL for the price.
I also found the flat faced Centrics for only $99/side (M5 rotors) and like $62/side for the rears! Tough to pass that up...
yee!
slotted rotors are great...a good upgrade from the stock 528 rotors.
Could you say a bit more about the benefits of slotted rotors? Are there drawbacks?
I've seen a bunch of threads were people go on and on about how cross drilled rotors just look cool and don't do anything unless your tracking or auto-xing, but this is the first I've seen of slotted rotors. I've reasonably happy with my 528i stopping power, but it never hurts to have more :thumbup:.
BMW Nuthead
benefits are the slots wipe the surface of the brake pad off everytime you brake, so there is better bite everytime. the down side is a little more brake wear than normal
yee!
yes the pads wear a little faster, but the bite is better and the rotors will last longer. from what i have experienced...slotted/drilled are pretty much the same just if its drilled its more prone to cracking, and buying two rotors cause of one sucks...just like tires. here check this out....http://flashoffroad.com/Maintenance/Brakes/BrakeRotors.html
I puchased some from bavauto and they look sweet, brake like nobody's business, but tend to create a LOT of brake dust and while they're braking they tend to squeek a little (everything's been greesed properly).
1 - 17 of 17 Posts
