99' 318i e46 1.9
Car has recently failed an inspection, but thats just the beginning of my problems.
It is stuttering when you first get going in the morning...while the secondary air pump is on...needs about 5 minutes to warm up. Even after a warm up, when you hit the gas pedal hard to the floor, not much happens...you have to kind of push it down half way before it has steady acceleration. also, it won't go over 5krpm. like its blowing air or something.
The secondary air pump, here:
http://www.ebay.co.uk/itm/Secondary-Air-Pump-Emissions-316i-318i-16v-N42-BMW-E46-3-series-/380398492804?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5891845c84
seems to be leaking around the edges when the car starts initiallly. but seems ok when its warmed up. a lot of hills around here...seems to struggle with them.
also, i found a vacum leak (see
http://realoem.com/bmw/showparts.do?model=AL32&mospid=47631&btnr=11_2071&hg=11&fg=45 and replaced the hoses 1,3, 5, 12
Have noticed air filter box is not sealed either, so I've ordered the replacement clips as it seems to have gone missing
Checked the ignition control module (with a used one, but might put old one back on as it seems worse)
Car needs a new muffler, so could that be blocked?...should arrive soon
Replaced the fuel filter, spark plugs and oil change
Any ideas what else I could check?
let me know what you think cheers
