1 - 3 of 3 Posts
So mom's car broke down so shes been driving the 38 for a few months and comes in and tells me the ABS lights on i go out and read the codes under the hood ....so many
Any help would be a predicated
DME
A9 DMe: DMS Digital Motor Elecronics Fault stored ( Idle speed controller opening)
A8 same but closing
70 DME DMS ..... (Camshaft sensors)
0F voltage supply EWS3 controle modula
ABS
59 DSC: DSK: brake sys fault stored (Power supply)
20 DSC: DSK: brake sys fault stored ( RF wheel speed sensor cable )
5a DSC: DSK: brake sys fault stored(timeout - passive switching)
1 LWS : supply (terminal 30)
b LWS sensor/vehicle allocation incorrect or not avalible
1 BM: on-board monitor: fault detected
6 BM: on-board monitor: fault detected
b BM: on-board monitor: fault detected
c7 IKE tank sensor 1 (fuel pump side
#7 IKE Tank sensor 2 (without fuel pump)
2 MRS: Failure warning lamp
70 GM: power-window switch block
DE GM: Servomotor steering column (height) jamming during upward travel
e1 Gm Servomotor steering column (longitudinal) overloading of output stage
30 GM Potentiate for interval time circuit
4b GM: Change over relay stage 1/2 wiper motor open circuit
94 GE: LED for anti-theft alarm system open circuit
DC GM: Servomotor steering column (height): transmission fault
DD GM: Servomotor steering column (height): overloading of output stage
DF GM: Servomotor steering column (vertical): Blocking of downward movment
4 GM: Terminal R
some of them i know most of them i do not
Most seem to be related to various seat/steering column/on board computer faults and I would guess a lot of them are old and related to a low voltage situation. Did you give a new battery, especially when she started driving it?
Clear and see what returns.
2001 750iL DD74441
Stock
RIP: 2003 540iA Sport GS56111
H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
Discussion Starter #3
2001 750iL DD74441
Stock
the first 3 are ones that always come up (went cheap and replaced the Ilde speed with one on ebay..it failed)
i put a new battery in it when i bought the car (1-2 years ago).
i cleared the codes after installing the new control arms tonight lights came right back on so drive it a bit tomorrow and check again
1 - 3 of 3 Posts
