Hello,
I couldn't find a solid answer so hopefully I can get a good pointer here. Recently acquired an e70 and a few issues that seem electrical. I first checked fuses and they all seem to pass my cheap fuse tester, however, I fear that some fuses might have been missing. Some spots seem empty, so I put one in, just to see if the tester would light up, and they do.
My questions:
Does anyone know if putting a fuse in a spot where there are not supposed to be, causes other issues? I did verify with the fuse sheet, but some seem to have more than one fuse, yet I see empty spots. For example, Windows would have 1,6,121, however, 121 would be empty. Is that normal?
Where can I find exactly what fuses my build is supposed to have? I know it is dependent on build options, but I am assuming basic functions should be all the same. Maybe I can start there and than find the extra options.
What do all those icons on the cheat sheet mean? Some are obvious, but others I can't figure out at all. Stared at them for minutes, can't seem to figure it out.
FYI - I am mostly interested in making sure the gauge cluster lights up since it seems to be completely dead. I don't mind sending it to get repaired, but would like to make sure this is not something simple like a fuse or a bad ground somewhere. It does make a clicking sound, from what I assume is the speaker, but not 100% sure. Also, the trunk button in the rear does not open the trunk. Lights up, but pressing button does nothing. I have to use the key or button on the center console. It also opens when I unlock the car, not by pressing the trunk button, all on its own. I also seems to do this when the ECU's wake up, regardless of car functions. Very weird. Has to be something missing with a fuse that a previous owner messed up.
Any help is appreciated! TIA
My questions:
