- Vehicle: 2006 BMW X3, 2.5L M54, 6-Speed Manual
- Mileage: 268k km / 166k mi
- Code: P16A7 (BMW Scanner 1.4 = 28A2)
Background:
Over the past year I would get an occasional oxygen sensor code for Bank 2 / Sensor 2 (Lean).
Typically this would happen about once a month, and I kept clearing the code thinking it was a lazy O2 sensor I'd eventually change.
About 2 months ago, I was quite literally driving up the side of a steep mountain road and the code triggered about halfway up under load.
Since this moment, the code would trigger about once every 2 weeks.. then once a week.. then every other day.
I had some almost-new post cat O2 sensors laying around from my E46, so I figured it was time to change them both.
Post Cat O2 Sensor for Bank 1 came out with a lot of force and swearing. Bank 2 sensor was a rusty bitch and I ended up stripping the hex so I had to take it in to my mechanic.
Well.. my mechanic also had a tough time getting the sensor out & needed to drop the exhaust. He used a torch to remove the corroded exhaust manifold studs in the process.
I can only imagine the amount of banging that the manifold studs had to take from his hammer.This probably dislodged / destroyed my Bank 2 catalytic converter.
Problem:
Fast forward 3 weeks to today, and the SAV is now sluggish in high RPMs and triggers the weirdest / most brutal limp mode I've ever seen.
I can now trigger limp mode on command by accelerating above 5000 rpm on WOT. Engine completely cuts out power, and idle bounces at 1300 rpm until I turn it off and restart it.
The ABS and 4x4 lights come on as well, along with MIL, and Check Engine lights. Upon restarting a couple times, they all go away except for the Check Engine.
BMW Scanner 1.4 shows a code of P16A7 / 28A2, "Air Path".
I've tested Camshaft Position Sensors one by one (intake & exhaust), and MAF. Not the cause. I also just installed a new DISA and new rubber intake tube recently.
So that leads me to the expensive conclusion that my mechanic must've destroyed my Bank 2 catalytic converter and now its probably melted together & clogging my exhaust.
Options?
I love my E83 (especially since it's a 6 speed) and it is in immaculate condition.. but it only cost me $2,000 a couple years ago, and I'm unwilling to spend a lot on it.
The options to resolve this matter all seem pretty crappy. Either expensive, labour intensive, or both:
1) Find a used Bank 2 manifold from another E83 X3, or an E46 330xi (same P/N). Do any other E46 M54 manifolds fit our cars?? (325i, 330i)
2) Drop the exhaust and dig out enough of the blockage in my Bank 2 manifold, just to get enough flow. Add a defouler to try and avoid a CEL.
3) Buy a new manifold.. or 2. They are aftermarket but look like OEMs that have been cut open and had the element replaced, then welded shut. ($229 each)
4) Other ingenious solutions Bimmerfest can think of that I haven't thunk yet..
I have an exhaust back-pressure tester on the way via Amazon Prime. I should be able to confirm my clogged cat tomorrow.
If I go the "proper" route and replace the manifold, shouldn't I just replace both at the same time since the other is likely to be next?
Sincerely,
- Disheartened owner
Update: See Post #7. MAF was the cause of the issue.
