1 - 8 of 8 Posts
· Registered
Hello,
After map update (2022-2 Europe East) iDrive restarts every 20 seconds.
Car is equipped from factory with Entrynav (F25 2017), updated to latest I-step (21-03-545) and was working fine after map 2022-1 Europe East update, done 3 moths ago.
After connection of maps 2022-2 (on USB that was working previously), HU restarted few times but eventually initiated update. Once completed, it restarted again and it is in this state a third day in a row. It boots to main menu, that I can browse it for 20 seconds, but then is shuts down and restarts.
Actions performed so far:
  • attempt to update to previous maps - not possible as HU restarts after confirmation of update
  • re-programming to the same software using Esys - no difference
  • disconnected battery for 24 hrs - no difference
  • delete map data using Tool32: entrynav.prg: ARG;NAVI_MAP;STR;0x01 - JOB_STATUS=OKAY but maps are still present as I can enter to Navigation and see car position on map for 2 sec, before it restarts.
  • downgrade to I-step 18-03-520 (different (older) SWFLs) using Esys - no difference
  • update again to I-step 21-03-545 using ISTA+ - no difference. Right after completion, Navigation was greyed out, but HU rebooted regardless. Now Navigation is available and reboots.
What else I can do ?
· Premium Member
When you run Check FSC Status with E-Sys, what does it show for ENTRYNAV?
· Registered
Discussion Starter · #4 ·
Here is what I get:
--> Read the state from "1" ECU(s) <--
HU_ENTRYNAV[DiagAddress=99(0x63)]
WBAWX310500B78847
RootCertStatus not available
SWSigStatus accepted
SWTApplications
AppID 180(0xB4)
UpgradeIndex 97(0x61)
SWTType SWTshort
FSCStatus accepted
FSCCertStatus not available
AppID 179(0xB3)
UpgradeIndex 1(0x01)
SWTType SWTshort
FSCStatus not available
AppID 201(0xC9)
SWTType SWTclassic light
FSCStatus accepted
AppID 223(0xDF)
FSCStatus accepted
AppID 111(0x6F)
AppID 199(0xC7)
AppID 200(0xC8)
FSCStatus accepted
AppID 156(0x9C)
AppID 178(0xB2)
SWTType SWTshort
AppID 181(0xB5)
SWTType SWTshort
AppID 182(0xB6)
SWTType SWTshort
AppID 183(0xB7)
SWTType SWTshort
AppID 184(0xB8)
SWTType SWTshort
AppID 185(0xB9)
SWTType SWTshort
AppID 186(0xBA)
SWTType SWTshort
AppID 187(0xBB)
SWTType SWTshort
AppID 188(0xBC)
SWTType SWTshort
AppID 204(0xCC)
SWTType SWTshort
AppID 206(0xCE)
SWTType SWTshort
AppID 219(0xDB)
SWTType SWTshort
AppID 221(0xDD)
SWTType SWTshort
Do you have any relevant error codes?
No error codes in ISTA+.
Since car runs normally, I took it for a spin (1 hr total) and after 10 min of driving, HU restarts stopped and behaved correctly, including fully functioning navigation, until I turn off vehicle 20 min later. When I turned it on again, for next 30 min, it continued rebooting and still does now. In summary: 10 min not OK - 20 min OK - 30 min not OK.
After this, I torn apart HU and reseated a 32 GB eMMC Micron BGA module from main board, using flux and hot air, but nothing changed.
· Premium Member
Here is what I get:
WBAWX310500B78847
SWTApplications
AppID 180(0xB4)
SWTType SWTshort
FSCStatus accepted
AppID 179(0xB3)
SWTType SWTshort
AppID 201(0xC9)
FSCStatus accepted
AppID 223(0xDF)
FSCStatus accepted
AppID 111(0x6F)
AppID 199(0xC7)
AppID 200(0xC8)
FSCStatus accepted
AppID 156(0x9C)
AppID 178(0xB2)
SWTType SWTshort
AppID 181(0xB5)
SWTType SWTshort
AppID 182(0xB6)
SWTType SWTshort
AppID 183(0xB7)
SWTType SWTshort
AppID 184(0xB8)
SWTType SWTshort
AppID 185(0xB9)
SWTType SWTshort
AppID 186(0xBA)
SWTType SWTshort
AppID 187(0xBB)
SWTType SWTshort
AppID 188(0xBC)
SWTType SWTshort
AppID 204(0xCC)
SWTType SWTshort
AppID 206(0xCE)
SWTType SWTshort
AppID 219(0xDB)
SWTType SWTshort
AppID 221(0xDD)
SWTType SWTshort
FSC Codes are good. I have no idea on issue. Seems hardware (eMMC) related.
· Registered
My (very wild) guess would be that the headunit doesn't get enough current. Maybe a cable is bend/broken or a connection not sitting correctly. Or the problem is with the HU itself. Maybe it has a faulty RAM module... Can you SSH into it and see for messages while it's running?
· Registered
Discussion Starter · #7 · (Edited)
I have fixed Entrynav.
Issue was with USB stick used for map update - even after full format it was causing HU reboot.
Steps to fix restart loop via Tool32:
1. To stop restart temporarily (till next power cycle): Open Entrynav.prg->select "diagnose_mode"->enter attribute "$10"->double click on "diagnose_mode".
2. To check if map exist: Select "status_lesen"->enter "ARG;STATUS_MAPMATERIAL_VERSION"->double click on "status_lesen"->last line of results window should show saved map (e.g Road Map EUROPE EAST Route 2022-1).
3. To remove map: Select "steuern_routine"->enter "ARG;NAVI_MAP;STR;0x01"->double click on "steuren_routine"->leave car for 10 min.
4. To confirm if map has been removed: Select "status_lesen"->enter "ARG;STATUS_MAPMATERIAL_VERSION"->double click on "status_lesen"->last line of results window should NOT show saved map anymore (e.g Road Map EUROPE EAST Route 2022-1).
At this point, you can cycle power and HU should not restart anymore.
Proceed with map update from USB stick, that is different than one that caused all hassle.
· Premium Member
(y)
1 - 8 of 8 Posts
