1 - 3 of 3 Posts
i have an engine from a 95 740il and i am rebuilding it and installing it into my 96 540I using everything from my 540I except for the block and heads, will i be running into any problems by installing the M60 instead of the M62 that the vehicle came with.
There may be slight differences, which may, or may not, cause problems. The 540i is not a USA model - we did not get a '96 540i. But, if you truly have a '97 540i, the earlier engine may not play well with the E39 DME, since it is not OBDII-compliant.
Why are you doing this?
Discussion Starter · #3 ·
i bought the vehicle without an engine, i found the 95 740Il engine for 300 dollars, i installed the block with the oil pan in the engine compartment and bolted it to the transmission and engine mounts and everything fit perfect, i than hooked up the intake from the 540 to all the electronics and everything plugged right in, i have everything from the 540 except the block and heads, the 740 did have the OBDII hook up, the only problem i think i may have is the camshaft sensor, the plug for the M62 is different from the M60. I really appreciate all the info that you have for me, and yes you may be right that it is a 97 model and not a 96 540I but by the vin number it says that it's a 96, the last 8 of the vin is VBW51397 and the actual manufacturing or production date is 5/96, thank you soo much again for all the information you may have for me.
1 - 3 of 3 Posts
