1 - 18 of 18 Posts
I'm pretty sure SP-Daten is one of the things required for E-series coding, not F-Series.
Discussion Starter · #3 ·
Hi,
Thanks. What is the best tool then to use? I am rebuilding a F07 and need to fix a few problems.
Premium Member
Premium Member
Premium Member
Premium Member
Depends. Again, SP-Daten for what use? What are you wanting to accomplish?
My instrument cluster is not working. Only Speedometer works, and rest gauges, such fuel, RPM, temperature stopped working. I removed/reconnected fuse and battery, still the same. Someone mentioned could be Daten file is bad, somehow and need to reflash it. Thanks!
Premium Member
You need PSdZData, not SP-Daten. PM sent.
  • Like
Reactions: seattleweather
Premium Member
  • Like
Premium Member
I assume all default setting/fireware are inside the software and I can upload from PSdZData to reflash KOMBI?
If you are flashing ECU, you need Flashing Guide. PM sent..
  • Like
1 - 18 of 18 Posts
