Hey guys,
I am experiencing an issue that is REALLY similar to a head gasket issue on my old acura, but without the fluctuating temperature guage and overheating....
Here's what's up... Occasionally while driving the RPM's will dance up and down about 300-500rpm. doesn't matter what gear the car is in or what speed. Directly following this when shutting the car off the "COOLANT LEVEL" message displays on the DIC. Everytime I let the car sit for a while and then check the coolant level and the level is always about 2-3 inches above the COLD mark on the tank. Spooky right!? The temp guage never moves from just below half way between hot and cold...which leads me to think it isn't a headgasket issue (not to mention no apparent loss of coolant).
What do you guys think it is? T-stat? Water pump? Cruddy coolant? Bad sensor?
I'm taking it in on Friday if I can't get any answers before then...I don't want it to strand the missus...
Thanks guys!
Thanks guys!
