To be totally clear:
1. The noise is a high pitched squealing sound. Squealing sounds are typically associated with too much friction in a moving part.
2. The car MUST be moving to hear the noise. At what vehicle speed does the sound occur and when does it stop or is overcome by road noise?
3. If this occurs ONLY when the car is in motion (and I presume you revved the engine while stopped) and stops when the car is stopped.
Based on these factors, the sound has nothing to do with the engine and is most likely related to your drivetrain or suspension (the things that only move when the car is in motion). Yet most sounds, especially squealing sounds, are due to engine issues (belts, rollers, fan, leaks, etc.) due to the number of high speed moving and rotating parts.
I suggest to go through the diagnosis phase again to make sure you have your symptoms properly characterized. An inaccurate description will void any possible analysis of your problem.
The noise is only generated when moving. If i lightly press the accel pedal, it will make the noise, however pressing harder down the noise does not generate. This happens cold or hot. I was thinking originally it was my fan...but if it was it would make the sound all the time would it not? just to affirm its only when car is in D, and light acceleration is applied.
