My rear driver side brakes started squealing the other day when I apply the brake, and it's REALLY annoying. I tried some spray stuff, it worked for like a day then it starts up again. I did my brakes like 10k ago. Any suggestions?
I did perform a brake bedding procedure.Did you perform a brake bedding procedure when you had new brakes?
Is your anti-rattle clip still in place?
Where did you spray the "spray stuff"? If you get some anti-squeak paste/spray, you have to take off the pads to spray the back of them...
+1 ... don't need it to set overnight. Remove pads, smear on back, replace pads, done!if you didn't use plastilube then that is your problem right there. with plastilube you do not need to wait for it to set over night or at all. just apply reassemble then you're done.
really? well i'll have to pick some up, i'm doing my front brakes this weekend and i'll smear some on the rear pads while she is in the air.+1 ... don't need it to set overnight. Remove pads, smear on back, replace pads, done!
remember to put it on the back side of the pads (not on the side that makes contact with the rotor) and also the caliper where the pad makes contact.really? well i'll have to pick some up, i'm doing my front brakes this weekend and i'll smear some on the rear pads while she is in the air.
I have the same problem too ... check your brake shoe cos when i ask my mechanic to tighten the e-brake the problem got away ... just my 2 centsMy rear driver side brakes started squealing the other day when I apply the brake, and it's REALLY annoying. I tried some spray stuff, it worked for like a day then it starts up again. I did my brakes like 10k ago. Any suggestions?
humm...that is interesting because my e-brake is loose, like i have to pull it so far up for it to actually do anything.I have the same problem too ... check your brake shoe cos when i ask my mechanic to tighten the e-brake the problem got away ... just my 2 cents
except your foot brake and the parking brakes are completely separate and independent systems. only thing they sort of share is the rear rotors but the parking brakes are dumb type and do not touch the same surface as the foot brake.humm...that is interesting because my e-brake is loose, like i have to pull it so far up for it to actually do anything.
