Okay after alot of research and being pissed that I need new tires already on my 2011 325i I have decided to go with the Bridgestone RE960AS RFT. My 325i has the sport/M pkg so currently the tires are staggered. When I get the new tires can I get them all the same size and not staggered? I want to get the most wear out of them and having them staggered will cause them to wear faster and you can't rotate them. Need to order tires tomorrow so I need help with this question soon. Thanks Bev
Congrats, the BS RE960AS RFT PP is the 'GEN3' runflat tire promising a much more comfortable ride, higher tread life (written 5 year/40,000 mile warranty), with all-season performance. Even though you can't rotate the staggered fitment, Bridgestone's warranty does acknowledge this:
"some vehicles may have different size tires/wheels on front and rear wheels which restrict rotation." In addition, Bridgestone's warranty states that tire rotation should be conducted according to the "vehicle manufacturer's recommendations." In BMW's case, this means no rotation. This is a better deal than the Michelin PSS which IIRC
penalizes your mileage warranty for staggered fitments.
In other words, the Bridgestone warranty will not penalize you for no rotation.
The downside of the B'Stone warranty is that they consider "worn out" for mileage consideration to be 2/32nd" vs. BMW's recommended 3mm.
There's another "catch." With no rotation, if your front tires wear out before your rear tires, NOBODY is going to recommend replacing the front two tires alone (and Bridgestone emphasizes that in their warranty; it's a safety issue). This happened to me, but after some "negotiations" with Bridgestone Consumer Relations Dept., a satisfactory solution was found.
