What are the pros and cons of having staggered wheels?
I have staggered on there right now, but I'm in the market for some new wheels and I can't decide what to get. The downside I'm hearing about staggered wheels is the inability to rotate the tires (you don't want to change the direction of a rotating tire).
Yes, it does increase the minimum turning radius. It also unnecessarily increases the unsprung mass which is not good for dynamics and handling. Plus, you may be facing a rubbing issue if the tire is too wide.Does it hurt turing radii or anything else if you have two wide tires in the front as well as the back?
:dunno:
Tire rotation is not recommended by BMW regardless of the tires being staggered or not. It is clearly stated in your car's user manual.
Wider front tires do not change the turning radius. The turning radius is static and determined when the car is designed, it doesn't change just because you put different tires on.
I have staggered on there right now, but I'm in the market for some new wheels and I can't decide what to get. The downside I'm hearing about staggered wheels is the inability to rotate the tires (you don't want to change the direction of a rotating tire). What are the downsides to having two wide wheels on the front and back? I'm looking at at least 9" wheels in the back (love the wide look).
:dunno:
First of all, you can rotate staggered wheels, you just do it side to side instead of front to back. You can always do that as long as the tires are not directional.
I could be wrong, but the wider rears are usually done for more forward traction as a primary consideration which is why Porsche has such big wide rears.
The point of it being? Sure, you can rotate them that way if you happen to have non-directional tires, but what would the gain be, unless your car is part of NASCAR...
Pardon my ignorance, but what are directional tires?
Honestly, I can't answer this question. I know that the tire rotation pattern for my car has been back to front, and then side to side. So, at least according to the Firestone/Bridgestone dealer - there are advantages as far as wear is concerned with moving a tire from one side of the car to the other. I can't really see why that would be the case though because I wouldn't really expect one side of the car to wear differently than the other.
Tires that go in only one direction. With a "directional tire" you are supposed to put them on the car rotating in only the direction specified. So, you can't do side-to-side rotations. With nondirectional tires, like the RFT Turanzas that come on some Non-ZSP, you can put them on either side of the car interchangeably.
so what youre sayin is i could get 9"s or 9.5"s all around and it wont make any noticeable driving difference unless im on the race track?
