1 - 5 of 5 Posts
Greetings!
Help, please, with the following-
1988 325ix.
Was running fine, changed oil/filter, valve cover gasket.
Poking around trying to get cruise control to work and found
the clutch switch was not making contact with the clutch pedal
(clutch master cylinder replaced Feb., mechanic apparently didn't
adjust switch.)
Now the starter does not turn over, click, etc.
Charged battery, cleaned all contacts, etc.
Could jiggling the clutch switch have caused this?
Any suggestions/ideas will be greatly appreciated.
GR
Keeping it surreal
Does the car start/run when bump-started? If so, then it`s the clutch/starter interlock switch that`s failing to engage....also, you should take this over to the E30 Forum, that`s where it belongs....good luck !
Hello and Welcome :hi:
1 - 5 of 5 Posts
