Okay here is the short description:
I connected a new battery, the car doesn't start, it doesn't crank. I can here the fuel pump kicking in and no cranking.
I am getting A0B4 CAS: Engine start, starter operation error.
And here is the problem in more detail..
I was having problems with my replacement battery for a while now.(for more then 6-8 months) . The dashboard was showing the yellow battery icon for a while. Inpa was also reporting lower cranking amps for the battery.
I did register that battery I got from Walmart last year into the system and I remember manipulating the amp value with NCS Expert although I couldn't really find out the ah value for the battery. So I did a guesstimate. The reason I mention this is I don't know why the battery died prematurely in less then 16 months. I live in SoFla so weather here maybe a factor.
Lately the engine was starting a little hesitant, possibly because of the low cranking amps the battery could generate.
During the past weeks I was out of town and I left my car to my gf, and she couldn't start the engine after her grocery shopping. She did try to start the engine (I am guessing quite a few times) and from what she tells me it was cranking until it couldn't crank anymore
The roadside assitance couldn't jump start the car and it was towed to my house.
Once I got back back the first thing I did was replacing the battery, I did retrofit a sears diehard AGM EP-49 battery.
I registered the AGM retrofit battery with ISTA-P (I changed from a lead based standard battery) and let the ISTA-P code all the other modules and reinitialize the windows etc. completing the registration successfully.
Of course there were lots of low voltage errors that were thrown in from modules when the battery died but once ISTA-P cleared them they never came back.
I still see the yellow battery error when I stop the ignition on the dashboard.
I have a good power supply, battery charger and the battery seems to be fully charged with good voltage. I highly doubt the brand new battery is the problem.
I unplugged the black IBS cable with the blue socket from the negative terminal to rule out a possible IBS problem and the car still did not crank.
From my understanding the likely cause is a bad starter, but I just wanted to get second opinion before I order a new starter and spend a day replacing it.
I know I probably need to check the voltage at the starter when the start button is pressed to diagnose if it is the starter, but I don***8217;t have the diagnostic tool for that which can attach to the cable and the starter is in a very bad place to reach as far as I see.
Can it also be an alternator problem, since the previous battery somewhat died prematurerly and had lower cranking amps then expected.
Any input is appreciated.. Thanks..
