1 - 5 of 5 Posts
· D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
The steering shaft universal joint is worn out, or so it seems. Get someone to move the wheel like that while you observe the U joint. It's right below the firewall, between the steering shaft and steering rack input shaft. There should be ZERO slop in it. If it clicks, it's scrap.
· D'oh, You Kids!
It could be either of these joints, or both of them.
· Registered
Discussion Starter · #4 · (Edited)
Thanks guys. I've been searching around to see how to replace the u
-joint. Some suggest first tightening the large nut on the steering column. Could that potentially work?
Mine did that, and I tightened the big nut on the steering column that allows the column to collapse AS TIGHT AS I COULD POSSIBLY GET IT (!!!) and that took care of it.
I'd try that first since it's free and only take a few minutes
· Registered
In addition to number 1 on the diagram, the rubber guibo, number 3, is common fail item for our cars. Open the hood and have an assistant shake the steering wheel. Observe the movement of the universal joint and the guibo. You will have to drill out or cut the four rivets to replace the guibo. They sell the OEM style rubber one or uprated polyurethane and aluminum ones for racing setups.
To remove the universal joint, first make sure the steering wheel is straight. Make alignment marks on the steering shaft and universal joint before undoing both bolts. Next loosen the adjustment nut on the steering column, this will allow the steering shaft to move up. Now gentle tap the universal joint off of the steering rack and shaft. You might need to spread the groove in the univerdal joint to accomplish this. Prevent the steering wheel from turning to prevent any wiring damage.
1 - 5 of 5 Posts
