Searched the forums and didn't find a thread with my symptoms, so throwing this out there:
97 528i: >229,000 miles
production date: 11/96
-Rack and pinion was making noises at 228,500 miles. changed the PS resevior hoses (supply and return), and flushed fluids.
-Changed the rack and pinion (new Atlantic Enterprises unit)at 229,000 miles as well as the power steering pump (LUK reman).
-Pulleys and belts were changed ~225,000 miles
symptoms: :violent: involuntary steering from 11:00 to 1:00 position while I was at a standstill in a driveway. At one point, the steering locked up when I restarted the car. no visible problems at the PS pump, resevior or under the car. After a few minutes of turning the motor on/off, I was able to have somewhat of manual steering. More force was required compared to tryning to turn the wheels with the engine off.
with the front end on jackstands, I'm able to get somewhat of smooth turning to the left, but the system feels like its bindind turning to the right.
There's fluid going to the pump from the resevior, so I've eliminated the resevior filter.
I wasn't able to get the M14 banjo bolt off at the rack and pinion to check the supply line from the pump, but I was ble to disconnect it at the pump. there's fluid in the line.
I believe I've elimiated the PS Pump, and it's the rack and pinion, but wanted to see if anyone has experienced a similar problem, and what their fix was.
Other than what i've checked, could there be any other parts which could effect the system to react this way?
Thanks in advance!
Thanks in advance!
