1 - 6 of 6 Posts
livin large
heres everything that will cause play in the steering when bad: tie rods, rack and pinion, pump, control arm bushings, wheel bearings, struts, steering shaft joints, and ball joints. always start with the easiest tie-rods, then go to the ball joints, control arm bushings, wheel bearing, rack and pinion and so on. also, under inflated tires can cause play.
Discussion Starter · #3 ·
thanks for ur good reply.
livin large
I had a little play in my steering too...found out it was a bad tire. Bought 4 new tires and it seem to have taking the shimmy away???
yea i had the same, the belts started to seperate giving the front end a shimmy. also i had bad control arm bushings and bad ball joints. still need to do the rack and tie rods:(
1 - 6 of 6 Posts
