While your tire is definitely in need of repair/replacement, the shudder is caused by warped brake rotors. They're covered under the maintenance warranty so setup an appointment to get 'em replaced.
I agree:thumb:webguy330i said:While your tire is definitely in need of repair/replacement, the shudder is caused by warped brake rotors. They're covered under the maintenance warranty so setup an appointment to get 'em replaced.
I would hesitate to jump all over the rotors right away. From what he described of the tire problem, he's either got a bad leak or un-even wear due to bad leak. I'd say swap the tires (they're at 24,000 miles? My Touranzas were shot at 20) and see if that fixes the problem. If not then I'd blame the rotors.webguy330i said:While your tire is definitely in need of repair/replacement, the shudder is caused by warped brake rotors. They're covered under the maintenance warranty so setup an appointment to get 'em replaced.
actually it does vibrate only when I brake at highway speeds (over 60). I'm settng up an appointment to have them look at it. I'll ask them to check the balancing as well as the rotors. And I guess its time for me to get new tires too....SONET said:I have actually had the same problem you are describing, but it turned out to be poorly balanced tires. I *swore* it was the rotors, but when I had new tires put on and balanced, the problem disappeared completely. You have to remember that when you brake, it puts more stress on the [front] tires and the vibration just gets amplified, making it feel like rotors. Who knows, it could be both the tires and the rotors!
Since you're getting the vibration even when you aren't braking, have your tires balanced first and checked for deformation. IMHO your dealer will appreciate it if you attempt the cheap fix first before fighting for expensive rotors. If the problem doesn't go away, at least then it won't be such a fight for you to get the rotors if it needs them.
--SONET
Allright this is whats going down. I emailed [email protected] and asked him when they can ship the tires. Once I find out, I'm calling the dealer to let them know they're getting my tires and I'll ask them for anappointment when they get them. I live in an apartment complex and I don't want to go through the hassle of collecting 5 tires from the leasing office and loading em up in my car. So once my dealer has the tires, I'm taking my car in, getting the tires replaced, balanced, aligned, rotors checked. ALso have to get couple of other problems sorted out, including a rattling/vibration noise coming from the center of the steering wheel when going over bumps (oneof the pieces...the plastic or airbag cover is loose I think. When I hold my hand on the center area the noise goes away) I asked them to fix it last time, but they didn't. They didn't even testdrive the car to listen to the problem. Changed some part when they did the retrofit and told me its fixed.webguy330i said:Yeah tirerack will drop-ship them wherever you want; the only thing I'd be careful about is making sure someone at the dealership doesn't just accept the shipment as inventory and then sell/use/take them. I've done this twice but I always ship the tires to my house and then take them to the dealership myself.
Just to echo this a bit....another option to consider is getting your wheels checked to make sure they're true. It's possible you may have a slight bend in one or more wheels. Find a shop near you that has a Hunter GSP 9700 machine. This is a great device that makes diagnosing wheel/tire issues much easier.The HACK said:
Always diagnose an auto problem from the easiest to fix to the hardest to fix, eliminate one possiblity at a time until your problem is fixed.
Since this is an old thread, I'll be brief. Just a suggestion to check tire wear on the front wheels to make sure it's even. I had similar apparent disc-warp symptoms on my old car, and it turned out to be the difference in wear of 1,000 miles and one trackday between the front tires.robg said:Teej-
I have the exact same car (2001 325, w/ a similar amount of mileage) and recently started having this problme (braking vibration but only over 60). What was the problem you were having? Rotors?
Could be. I have about 22k on my Contisports-- no track time though. Were you getting vibration only on braking or while cruising too? I would think if it was the tires, i'd feel vibration during braking and cruising; not just braking. But, I may be mistaken?norihaga said:Since this is an old thread, I'll be brief. Just a suggestion to check tire wear on the front wheels to make sure it's even. I had similar apparent disc-warp symptoms on my old car, and it turned out to be the difference in wear of 1,000 miles and one trackday between the front tires.
