The reason why you HAVE to disconnect the battery is a) You can't possibly set off the airbag by accident and b) you won't trigger the airbag warning light. If you disconnect the battery then you don't have to worry about that.Cliff330i said:
The reason why you HAVE to disconnect the battery is a) You can't possibly set off the airbag by accident and b) you won't trigger the airbag warning light. If you disconnect the battery then you don't have to worry about that.Cliff330i said:Guys, I got the DYI instructions from the 330ci site. It says that because the battery is disconnected, the trip computer and clock have to be reset. I was wondering, does the air bag light come on and have to reset at the dealer? I also have the navigation system. Bascially, I don't want to make any trips to the dealer. So, anyone that knows, please share your info. :thumb:
Regards -Cliff
Your question sounds a little confusing to me, so I'm going to answer to the best of my abilities and what I know:Cliff330i said:The whole reason for me asking this question is because the wheel is not centered correctly. The car is in alignment after the dealer did so. After they gave me the car back, it was off to the right so I asked them to fix it. They gave it back to me and now they over compensated and it's turned too much to the left. Basically, when I remove the center bolt, and I see the spline marks, will the wheel spin freely around the center or do I have to take the wheel off and put it back on straight? Do you get me? When I look at pics of this process on 330ci.com, I see something resembling gear teeth like there is some mesh that keeps it in place. Could you clarify this for me? Thanks Hack. -Cliff![]()
