1 - 7 of 7 Posts
Hey , i have swapped the steering wheel to heated but with LIM button instead of Set.
Coded for heating , and works great. Only issue that when scanning for errors with BimmerLink shows 030411 Multifunction steering wheel (MFL): Wrong Variant.
VO coded option 248 . And coded Dkombi , body and Nbt.
Found a post about f30 with same issue he solved it by Coding in fem_body >lin_variante_mfl to correct one. But i cant locate anything close to this in g30 .
Any help is appreciated.
2013 535xi
Being such a new car there probably isn't anyone who has done this retrofit yet.
Why not use the right button setup?
Discussion Starter #4
I coded in LIM to work. And like it.
Dont really want to take a part and swap buttons as well.
When it will be warm out ill try to search thru modules.
2013 535xi
There are some knowledgeable coding guru's around.
You should post in the Coding sub forum also.
I'm sure you will also be questioned why you didn't order it to begin with.
The people that help with coding issues, don't usually ask that question - they know there are a range of reasons and its totally irrelevant anyway.
The people that ask that question, are usually the ones that can't help with the answer because they don't know about coding. They just want to say "you should have just ordered it to begin with" and be of no help at all. F**k those guys.
Discussion Starter #7
Ill post there. Thanks
Well just to answer why because i saved about 1/4 of cost and didnt have to switch parts from original. Easy in and out if need be.
1 - 7 of 7 Posts
