1 - 7 of 7 Posts
Hi All
I need some advice re BMW X5 2005 e53.
For the past 2 months Heavy vibration in steering wheel.
Had rear tyres changed and all 4 wheels balanced and wheel alignment done.
Still no joy. :-(
It vibrates extremely as soon as I hit 56mph - 70mph. There is still a vibration beyond this.
It then vibrates hard if I hit the brakes at any speed.
My local garage is useless.
BMW garage will rip me off hence why I have come on here to seek advice from you people who will know (I Hope) what I'm going through.
Thank you.
Hi All
Still no joy. :-(
Thank you.
Sounds like you need new thrust arms and control arms. How many miles on your X5?
I had a similar issue - specifically the very heavy vibration under braking - and it ended up being the CV axle. Swapped those out and the vibration went away. About 8 months later I had a very light vibration start to come back. At that point I swapped out upper and lower control arms and ball joints and I've had zero vibration since.
Same issue fixed with a new inner n outer tie rod passenger side and then took her in for an alignment...that part will be covered in a different post. Took me 15 minutes and the part was 80. From my local napa shop. I have a lifetime alignment program. (A necessity)...
1 - 7 of 7 Posts
