fullcombat said:Well, just picked me up a 2002 330xi which is an automatic and has the steptronic transmission. I never used the steptronic before, so looking for some guidance. I also never drove a manual before.
Thoughts appreciated..
Mike
Mike
JonathanIT said:I absolutely love my Steptronic, and I think it's a blast. The only thing I would say is: Don't be afraid to use it! i.e. instead of what most people do (simply put it in drive and don't touch it until parking), don't be afraid to use the manual/sport shift mode and go back and forth from right to left. I love sport mode, but find myself manually ticking up or down quite frequently. Also a neat trick I learned in sport mode is to quickly tap on the accelerator (and let go) to downshift, without even touching the shift knob. The gear will hold until you hit the accelerator again and it needs to upshift. Really cool; try it!
--J.
BMW4phillygirl said:That copper ruined a perfectly good drive down PCH tonight...![]()
Frank Rizzo said:I'm with him.....it aint a manual, but it's a lot of fun. You can "double clutch" once you get the hang of it.
Also - you have a 330, so I dont think you have a "GM" tranz....
dwette said:I think all the E39/E46 steptronics are GM. But that's a good thing because they are very good transmissions.
Nevetheless, I'll never get a step again. It was just too boring after driving manuals for so long.
--J.
BMW4phillygirl said:I have an '01, and my steptronic is backwards compared to yours. In my car, you push forward to go up, and pull backwards to go down. In '02's and later, you pull back to go up and push forward to go down... it's really easy though, if you want to drive in manual, but it hardly feels anything close to MT. I've done it maybe twice in my car. But, I always drive in sport mode. You just have to get used to pulling the shift gear out of sport when you're putting the car in park and turning off the ignition...
cdebnil said:this might be a dumb question...what exactly is sport mode? i have the steptronic too...is it another term for putting it in the steptronic mode?
I have not heard this before... can you elaborate and tell me why you should never "downshift into 1st while moving?" I do it frequently. :dunno:icemanjs4 said:And if you're not used to choosing your own gears, only go into first from a stop - you should never really downshift into 1st while moving (BMW prefers to start in 2nd gear if you notice).
JonathanIT said:II have not heard this before... can you elaborate and tell me why you should never "downshift into 1st while moving?" I do it frequently. :dunno:
--J.
icemanjs4 said:As for fist gear, its primary purpose in life is to get the car moving from a stop, or to assist you in launching with ridiculous 0-60 times. 2nd is the utility acceleration gear, and 3rd is the power gear. Downshifting: If you notice that you are at fairly low RPMS (ie less than 3K), and you downshift, the car will kind of buck suddenly unless you are giving it some gas at the time,. without applying gas (ie to accelerate quicker), the car will pull it self slower. IT will almost feel like you applied the brakes. For this reason I can't imagine ever downshifting into 1st. It would almost pull the car to a complete stop, or it would force your RPMs to go really high, forcing an upshift to 2nd moments later.
