This problem has started a year ago what happens is:
The car (520i 2002) runs normally without any problems, temp gauge drops on high speed... and sometimes specially when I put some load on the engine such as accelerating to high RPM the water circulation gets locked then water starts to get out from the radiator cap and overheats and the hose gets very tough.
Parts changed:
1- radiator cap
2- water pump
3- thermostat
4- Front fan
5- Fan clutch
anyone faced or repaired the same, is there any other procedure I can do before changing the engine?
Parts changed:
1- radiator cap
2- water pump
3- thermostat
4- Front fan
5- Fan clutch
