I've got a strange issue which has started recently, the car works fine when driving normally but if you push the car to the red line and make it shift gear its feels like a misfire kind of jolt as its changes gear. normal gear changes are fine when the revs are not at the limit, has anyone got any ideas what might cause the issue.
If there was a clutch slipping i wouldn't have expected the jolt that happens and also if I push the car and manually shift around 5000 rpm the issue doesn't happen.
I've also brought carly for my iphone and done a scan which is not showing any errors being reported
