1 - 4 of 4 Posts
Hi, I'm new member here from Indonesia
I had a issue with 8mm bolt for Coil Pack ground (the orange cable), this bolt is overthighten with the older workshop. My question is... How to break this bolt ?
I need to replace the valve cover gasket quick
Thanks before
1030520
that's an 8mm nut threaded onto a stud. Not sure what is on top of that nut. The wire strap is supposed to go underneath the nut. Did someone weld the strap onto your stud and on top of the nut?
So problem is getting that wire off? Or that bolt which is holding head cover?
Cut the wire and then get bolt off all together?
2003 BMW Z4 3.0i 6-spd Manual
penetration fluid and then tighten the nut and then loosen, then tighten, then loosen. Go back and forth till it starts to come off. If you round the head you can buy some socket extractors.
1 - 4 of 4 Posts
