I have a 2005 X5 3.0i. I lost compression on cylinder #2. My leak down test seems to indicate the leakage is the rings and not valves. I've tried some seafoam first and second I used GM 19355198 Top Engine Cleaner in the cylinders thinking the piston rings may be sticking. I'm letting the pistons soak a second time with the GM cleaner.
I ordered some GM UPPER ENGINE AND FUEL INJECTOR CLEANER 88861802 to try as a third resort.
Has anyone been though this with their M54 engine?
This occured after I replaced the CCV valve and hoses. I think it could have caused a bunch of accumulated oil slime to go through the intake. The first 15 miles the car ran better than ever. Now this thing runs so crappy I can't use it.
I am getting direction from this video.
