Was coming off the highway on my way to work today, (Seems a common theme from what I've read) when suddenly the car lost nearly all power. Idle must be kept above 2k to keep it from stalling. Running much ruffer than the previous time when a spark plug went out. The check engine light flashed for a bit, then stays on all the time. Car shakes like a RUB at the DEM convention, or, like a DEM at the RUB convention, which ever way you would like to see it.
I just bought the Torque Pro app, but my phone can't see the the bluetooth i bought for it and so I have another on the way but it's not here yet. Think I'll try and limp it down to AZ at lunch and see what codes may be there waiting for me. Don't think they are able to read fuel trims for me.
Was reading a thread on power loss, etc., and ran into one where bluebee said she hoped her legacy would be debugging, not a long list of parts she had changed.
From what I have read from her, I think she accomplished her goal and then some.
From the symptoms I'd guess it's, fuel pump, vacuum, maf, cam position sensor. Seems to be both sides of the motor (global in nature) and has the hp down to at most 100hp. Not sure if it would even be able to limp home if need be.
Any thoughts appreciated,
Jim
Jim
