1 - 2 of 2 Posts
If in doubt, go flat out.
Hi Guys,
Ok, I have an update - but still really need your help.
I've managed to change over my SZL today and broadly speaking everything is ok - apart from 1 thing...
My paddle shifts have stopped working.
If you pull on both paddles then the dash switches to manual and increases by 1 change UP - but individually neither work.
Obviously the SZL didn't have a CAFD file at first, I detected CAFD to inject, and went with:
F010-13-03-505
CAFD_0000033D_001_009_002
It was coded to the car with success, and the paddles are set to activ.
Anyone have any suggestions?
:cry::cry::cry::cry::cry::cry::cry::cry::cry:
Discussion Starter · #2 ·
Further to my earlier post, I should add, I injected the CAFD version and coded according to VO using the lite version of PSdZdata...
Should I have flashed the SZL ECU using full data?:dunno:
I'm just in the process of trying to get a hold of the full data now to consider flashing the ecu... :eeps:
1 - 2 of 2 Posts
