TAB & StPike75 Reset Coolant Bomb & Trek through the Valley for Guides to 300k miles
TAB has reached the danger zone of 150-175,000 miles for the M62TU. No significant noises on start up, but realizing the odds are stacked to "when, not if" I have decided to tackle the guides while conducting a cooling system overhaul with Valley Pan Gasket. The cooling system is pushing 80k and the Valley Pan has a weep resulting in an occasional temperature foray to 110 before going back to 106-108. I will be replacing the Valley Pan and upgrading to the Zionsville system. So while I am in there... And as long as I am doing this I might as well do some other things (oil separator, vacuum lines, VANOS, ...).
StPike75 hasn't any cooling system or valley pan issues but did have the "every 5th start" rattle at 121k miles on the iT. That has since quieted with an oil swap to 0w40. The final listing of components for StPike75 may be significantly shorter.
We have decided to go as a team: he will assist me and I will assist him. Not simultaneously as out schedules won't allow for that but having two sets of eyes and hands should make the job a little easier. Not to mention that having two people should make documentation better and easier.
As for the materials I have gone for the FCPEURO kits and supplemental items and will be getting the GAS Master Cam Timing Tool Kit. The procedures are being assembled/condensed/created from an amalgamation of the sources at the bottom of the post and will be attached when completed. As I am expecting to go in August, I wanted to double check with the forum before the procedures so as to avoid the "when I guess I need to overnight that..."
So the questions for the community:
Vehicle Information
Sources of Inspiration, Information, and Procedures:
Around the M62TU in 80 Hours More or Less
GAS Master Instructions
m62 diy lower timing case removal and chain guide parts list
And of course the Bentleys.
Table of Parts
- are we missing anything in our material lists?
- anything else while we are in there?
- anyone in the Northern Virginia area have the various supplemental tools (crank/pulley holder(s), VANOS press, etc)? I say NoVA for geography reference but can work with shipping.
- (when added) any points on our procedures?
Vehicle Information
Vehicle | Year | Model | Mileage |
TAB | 2003 | 540iA | 160k |
StPike75 | 1999 | 540iT | 121k |
Table of Parts
System | Nomenclature | Part# | QTY |
