The center soldered contact is making intermittent contact. I had the same problem. The bulb is good, but the contact has been compressed by the spring over the years. Now, you can get a new bulb or add solder to the existing one. :thumbup:
I don't know anything about the clicking noise from the glove box.
Sound like a fuse about to go Bad, Check the fuse box, You might need a flashlight because the numbers are hard to see. Open the glove box and pull the white tabs to open box then look close.The passenger side tail light and turn signal stopped working this morning. When I left work, they were working again, the stopped working again before I got home. I have a 2001xi and I noticed a weird clicking noise coming from the glove box area this morning. Anybody have an idea what the problem could be? And how to fix it? I called Foreign Performance here in town, and they want to refer me to the stealership to check for a recall. The recall doesn't cover my year model.
