Bimmer Utility Very good.
I updated the version today.
v1.0.35 Release Notes
--Updated mapping to 4.35.21
--Allow to save FA file to different file name in FA editor.
--Display file name in FDL editor.
--Cheat editor can now accept NCD files.
--Changed cheat code trigger from dropdown to checkbox.
--Allow drag and drop of ncd / cafd files into cheat editor.
I tried it right away.
I found a little bug.
(1)
The file name is displayed in the FDL editor.
but,
For example, if you drag and drop KOMBI's CAF directly from the folder after modifying the BCO's CAF.
The display of the file name does not change.
The selection from the MY file is displayed correctly.
(2)
If you select "00,0A" etc. in the cheat code editor, the code will not be reflected.
It works when numbers such as "0A" and "01" are used alone.
I like Bimmer Utility because it's convenient.
Since it is a separate system, there are no runtime errors like Esys Launcher, which is very convenient.
I posted it because I wanted it to be improved.
Also, BImmerFest has no discussion about Bimmer Utility, so I posted it.
However, it is convenient to be able to use it on a sub PC like the new tokenmaster Launcher V5.
Ideal for temporary use in the event of a failure of the main PC.
It would be nice if the Bimmer utility could be used on other PCs with a password. (Like a cloud system)
(1)
but,
(2)
