41 - 60 of 69 Posts
Seek to understand,^Value
Discussion Starter #41 (Edited)
An unusual question was asked today about "oem tires":
> E39 (1997 - 2003) > e39 oem tires???
the dealer is telling me that my 525i needs oem tires only..and do not rotate them?????this is my first bmw and i am a lil green to all this...i have the 16 in wheel package...any help out there?????
My original tires were all-season 225/55R 95H tires on 16 x 7.0 in. wheels, but I don't remember the brand or model. Do you?
I once saw a chart with common E39 wheel sizes and a speed error column. I cannot find it anymore. :(
Does anyone remember the thread it is hidden in?
Discussion Starter #43
I don't know what chart you mean, but it might be this PDF found by typing /wheel f3 in the bestlinks?
See also:
- BMW wheel specs (1) (2) & BMW & replica rim styles (1) (2) (3) (4) & the difference between cast vs forged rims (1) & how to choose the right size wheel spacers (1) (2) & where to go when you bend or otherwise damage your wheels (1) & wheel terminology (1) & Tire circumference, diameter, offset, & clearance calculators (1) (2) (3) (4) (5)
Discussion Starter #45
BMW cars usual burn through tires so auditioning a new set every couple of years gets easy.
Eventually you find a set you like. Right now, I'm loving my Conti DW tires.
I don't seem to get more than something like 20K out of mine!
- One users quest to diagnose uneven tire wear on the inside edge due to excessive and uneven alignment camber & toe (1) (2)
So, since the most-often recommended tire is that Conti DW, that's what I think I'll get soon.
Discussion Starter #47 (Edited)
Yeeeeeees! That's exactly it. I searched, I swear! ;)
Just to give you a hint on finding PDFs in the bestlinks (of which there are at least a hundred good ones), all you need to do is add an underscore to your search, and it will only look for PDFs.
So, for example, had you searched for /wheels f3, you would have gotten links to reference threads on the topic.
But, had you searched for /wheels_ or _wheels, you get the reference PDFs.
The entire bestlinks process is kindergarten simple, and always attempts to be logically the first thing you'd think of, by design (but it's always improving, over time, by the inexorable process of incessant incrementalism).
EDIT:
Since the chart was a multi-page PDF, I took the liberty of converting it to a single-page graphic image; and since the graphic image was white on black, I took the additional liberty of inverting the colors (so that the chart is more easily printable).
Discussion Starter #49
This thread today has useful information...
> E46 (1999 - 2006) > Tire help, Please?
Hello - I have an E46 2004 330ci convertible that needs new tires. My old ones were Pirellis, but dealer just told me that Pirellis are no longer available in my size. My 2015 650xi has Goodyears. What's the best performance tire? Not looking for long wear (and a lousy ride). TIA for your input - I have to get back to the dealer ASAP. Dealer tried to talk us into continentals, and sorry if this offends anybody, but I thought they looked like crap (even if that's what sold with the cars as dealers states). Had to replace original tires when car was less than 2 years old. That's when we got the Pirellis - should also mention less than 30,000 miles on the 2004 (won't drive it with the top up ;)
While I couldn't fathom anyone buying tires at the stealer either, what I observe in the tens of thousands of threads that I've experienced over the years here, is that the less something matters, the more religious the discussion.
Or, put in economics terms, the more the item is a commodity, the more the marketing teams will sow FUD and try, at the same time, to make meaningless differences worth something to you, such that people are worried about a decision as mundane as buying tires (which I buy by the book - but - having said this is a religious issue - I'll leave "my" book out of this discussion).
The PLACE I recommend you get tires is "tire_rack", but, you pick whatever place you want. I have five of them sitting in my front yard at this very moment, in fact, because I'm gonna try mounting them myself (and I'll probably fail - but I want to try once, in my life).
How you buy tires?
Since it's a religious issue, there is no right answer.
Start here...
- How to logically choose tires by the numbers (1) or by Bimmerfest user recommendations (1)
See also:
- How to logically choose tires by the numbers (1) (2) or by Bimmerfest user recommendations (1) (2) & where to buy your tires in the USA (0) (1) (2) (3) (4) (5) (6) & tire plant codes (1) (2) (3) & tire safety (1) & recommended tire pressures (1) (2) (3) & the claimed benefits of nitrogen gas (1) (2) & choosing the right BMW tire/tyre size (1) (2) & tire circumference, diameter, offset, & clearance calculators (1) (2) (3) (4) (5) & a torque conversion calculator (1) & tire terminology (1) (2) & wheel terminology (1) & BMW wheel specs (1) & BMW & replica wheel styles (1) (2) (3) (4) & the difference between cast vs forged wheels (1) & where to find the wheel markings for proper match mounting (1) & the best products for cleaning wheels (1) & how to choose the right size wheel spacers (1) (2) & where to go when you bend or otherwise damage your wheels (1)
Discussion Starter #50 (Edited)
The question came up again today how to buy tires...
Choosing tires always depend on what you want and need from them.
Actually, I must correct that (and here is where we start getting religious, I know).
Choosing tires is like choosing a mail-order husband.
The problem is not so much that there are a lot out there, and that they are all just about the same.
The problem is that you really don't know how they will SUIT YOU.
You will NEVER know this information, until you live with them for a while.
And, that's impossible, for a tire that you've never owned, mail ordering on the net.
Sure, you can ask all his prior friends what he was like, and that will always be data, but, rest assured, some will love him, some will hate him, but all will have ridden him DIFFERENTLY than you will, as they may be a different size, weight, they may be lowered, they might like to track, they may not be sensitive to road perturbations, etc.
So, effectively, you can't realistically choose tires by any other method than the facts.
1. Do they fit (is he the right size and weight, yes, people care about height, for example just as much as the tires need to have the right sidewall-to-width ratio).
2. Are they the right color (is he the same "race" as you are, if whitewalls matter to you for example or are they the right tread to match with the other tires on the car including the spare).
3. What are the bare basic (and I mean BASIC MINIMUM) performance metrics that are STANDARD (as much as anything can be standardized), such as: AA/A/400.
That is, where does he live, what language does he speak, how old is he, what's his profession, how much money does he make (yes, that's important to many people), etc.
For that, there's only TRACTION/TREADWEAR/SPEED (aka TEMPERATURE).
EDIT: Notice the warranty is almost always meaningless (except as a fantastic FUD marketing gimmick) and only useful, if he has a twin brother, and you can switch between them for no cost if you're unhappy with the first twin.
Check out Tire Rack, as has been suggested....There are also extensive reviews and specs on the site that will help you make your decision.
The main problem with those reviews is it's like reading the diary of every woman who ever went out with your prospective mail-order husband.
99.98% of the people who write those reviews are idiots.
The other 0.02% don't back up their claims with *any* data other than the buttmeter.
Hence, I find the reviews far worse than worthless, as they waste my time which would be better spent comparing reliably OBJECTIVE standardized measurements, admittedly few as they are (and admittedly flawed as they are).
YMMV, of course.
Someone wants to marry Charles Manson even though they can't possibly consummate nor form a real relationship for a test drive.
I don't get it.
But, there's a mail-order tire for everyone.
Discussion Starter #51
I almost always buy my tires from Tire Rack, but I just found out that there is an outfit that is ony 7 years old (I spoke to the owner today) who says they strive to compete with Tire Rack on prices.
That's a good thing, so, here's the information, if you need tires (I would have saved over fifty bucks on the six that I bought last week).
  • Tire Buyer 866-961-8668 (M-F 5am-6pm, Sat 6am-4pm Pacific time
See also:
- One users quest to diagnose uneven tire wear on the inside edge due to excessive and uneven alignment camber & toe (1) (2) & how one user selects a tire (1) & what are the most common bimmerfest tire recommendations (1) & where to buy your tires in the USA (1) & recommended tire pressures (1) & the claimed benefits of nitrogen gas (1) what tire changing tools do you need to break the bead on the rim and set the bead back on the wheel when changing a tire at home (1) (2) (3) & where are the marks on the wheel and on the tire for proper tire match mounting and wheel balancing to eliminate vibration (1) & what tools do you need to balance a tire and rim at home to eliminate shimmy or vibration at speed (1) & how do you properly dispose of your old car tires (1) & where to get bent or damaged wheel rims repaired (1) (2).
This sounds a bit mad...
But go to your local BMW dealership and have them price some tires for you. I am looking for some new tires for my 1999 528i and am running 225/55/R16. I found good tires that would fit at a place in town and the cheapest they wanted was 130 a tire installed. I went to my BMW dealer to price some parts and while I was there a rep told me to check out there tires so I did. I found V rated tires (the others weren't) for 63 dollars a piece although that was not the installed price. I asked the mechanic and they said 30 a tire to install so I figure I will buy my tires there then go to a place that I know installs tires for 15 each. That is what I plan to do.
I hope this helps,
Cheers.
Hope this doesn't sound like trolling, but I'm very sceptical of a selection method which resulted in using the cheapest possible tyres (Fuzion Touring) that will fit the E39!
As far as grip goes, the method seems to rely heavily on the UTQG wet traction rating. From the data in post 25, I struggle to believe that a cheap-arse Sumitomo or Kuhmo has the same wet grip as, say, a Pirelli P7. So I question the accuracy of the UTOG measure, and its relevance for cars with ABS (the test method involves a locked tyre)
And while wet braking performance is important (it is my top criteria in tyre selection), there are other factors such as wet cornering, dry braking, dry cornering and breakaway progressiveness which are pretty important for driver enjoyment errr... I mean safety :angel:. Unfortunately, there is very little measured data for these characteristics. Personally, I select tyres based on user reviews... and some bro-science I guess!
Sorry for muddying the waters. Motor Magazine does an annual tyre test, which has some detailed info on the various aspects of tyre performance. If you like, I can scan it?
Discussion Starter #54 (Edited)
This is a good point. But, it requires data to exercise your point.
Data that you might not have.
In fact, if you read the $250,000 study, commissioned by Arnold Schwarzenegger in 2003 about consumer's tire buying habits (see attached), you'll be appalled at HOW most consumers select tires!
- Publication # 622-03-004, Consumers' Tire-Buying Habits and Their Knowledge of Tire Maintenance, Recycling, and Disposal (MS Word, PDF)
While that 182-page PDF explains how most people in California select tires, I buy them purely by the numbers.
Clearly, to me, tires are a commodity; while, to many others, they are not (and that makes all the difference in "emotional" or "stylish" selections). Of course, with commodities, emotion and style isn't part of the equation, so, all that matters is bare bones known repeatable reliable statistically valid data, of which, there is precious little available to the consumer.
As an aside, I should clarify that the espoused method doesn't necessarily RESULT in the cheapest possible tire, since you can use ANY selection method you want, once you're armed with the comparison data. In fact, I would NEVER select a tire, even if it were cheaper, that has a "B" rating on straight traction.
And, of course, SOME people use warranty (of all things) as a selection method; or the thousands of reviews from the hoi polloi (which I find unbearable to read, for their lack of attention to scientific methods).
However, to your point, it is true that "I" selected the cheapest wet traction=A, Speed/Temperature=A tire that Tire Rack had in stock, which was the Fuzion, which is a subsidiary of Bridgestone. I have had those same tires for the last 20K miles, and they work fine by me (albeit, the 400 treadwear rating turned into 50 miles per point, or 5,000 miles per 100 point).
> E39 (1997 - 2003) > How many miles do you get per UTQG treadwear point? Mine wear at ~50 miles per point.
Furthermore, I should mention that Tire Rack "did" have a CHEAPER A/A tire, but, they didn't have 5 in stock, so, I would have bought a cheaper A/A tire had they only had them in stock.
I just checked now, and they ARE the cheapest now, but they weren't the cheapest a few weeks ago.
You have me here, and you have defined the WEAKNESS in both your selection method, and in mine.
Unfortunately, we don't have any reliable scientifically repeatable DATA for dry traction.
Let's look at that perfectly valid statement, and look at it scientifically (which this thread is all about):
  1. "cheap-arse Sumitomo or Kuhmo"
    • The price of a commodities has a LOT to do with the actual quality of the commodity; however, the price of a non-commodity can fluctuate wildly based on the PERCEPTION of the quality of the commodity.
  2. "same wet grip as a Pirelli P7"
    • The wet grip of an A tire is as good as the wet grip of any other A tire, assuming the test conditions are valid and applicable to the real world (and assuming test scores within the range for B < A < AA). Period. This is fact. You can't deny fact. This is what the science of accuracy and repeatability are all about.
    • You can deny the test. You can deny the applicability of the test to the real world. You can assume corruption and payoffs, etc., but, assuming that the test was valid, then an A tire stops in straight-line locked condition as well as any other A tire. Period.
  3. ABS relevance
    • Ah, you are now hitting upon the problem with the UTQG tests, which we all know and recognize, which is that they are extremely limited.
    • There is no reliable repeatable accurate data for what you seek.
    • Lord knows, I'm all for data. Good data. Real data. Scientific data. Repeatable data. Accurate data.
    • However, where are you going to get the DATA you seek?
  4. other factors
    • Again, you hit upon the weakness of UTQG selection methods, which is there is no data for the other things that matter.
    • But, how is YOUR system (or any one else's system) going to get that data?
    • Remember, I'm all for data. This thread is about choosing tires by the numbers, which means by the data.
But, where are you going to get reliable repeatable accurate usable applicable data for what you need?
Here in California, it doesn't rain from about May to November, usually not once. So, I agree, wet traction isn't the ONLY traction criterion to consider.
If you give me reliable DATA for dry braking (and the other factors you mention) that I can apply to my selection of all tires, then I'd use that in my selection "by the numbers".
But where are you gonna get this scientifically valid repeatable data for all tires you are considering?
Bingo!
The reviews are all over the map.
For example, here are the Tire Rack consumer summaries for the same "cheap" tires above:
The problem with reviews by Motor Trend, Car & Driver, Consumer Reports, etc., is that they are never inclusive of the tires you select.
There's nothing wrong with reviews, other than they're not always scientifically repeatable (what if, for example, they review using a Corvette and you're driving a Chevette?).
So, if you have a review for tires for a BMW sedan (which most E39s are), then those reviews would certainly be additional DATA that is applicable.
EDIT: I ran a quick search for that motor-trend article, but only found these:
If one wants an approved BMW tire, which by BMW standards will stick to the road, will handle in the appropriate climate, will be good for the car's speed, etc. you need to look for the STAR. The STAR is BMW's stamp that the tire is approved for their vehicles. There are also tires from the same manufacturer, which will have the same size, name designation, etc, one with the STAR and the same seemingly identical tire without the star. These 2 "identical" tires are actually different, the one with the STAR costs more, and has a different rubber compound. Some stuff is in this linky, but for the more detailed intricacies, one has to do some searches.
This is what you want:
Discussion Starter #56
This is GREAT information!
Truth be told, I never heard of this BMW-approved 'star' before., and I love the idea of the Marketing tool (they're extremely clever people):
Trying the link you provided, unfortunately, it won't handle the 2002 5 series:
- Online tire selector for BMW approved tires:
The best it can do is the 3 series, but that makes no sense and it finds nothing as a result.
Here's more about the star, from BMW's own Marketing web pages:
While I deplore such gimmicks, I agree that it makes your average BMW mom and pop owner "feel" much safer already, knowing that their tire "meets BMW specifications", so, it's a good thing, overall (since presumably, BMW tests these things first); but it's no substitute for knowing the qualities of the tires by more objective (i.e., non BMW Marketing) methods.
Discussion Starter #57
While I was looking up how to read everything on the tire sidewall, I realized all the links in the bestlinks for tire plant codes were defunct.
So, I include the current codes below, for posterity:
- U.S. DOT adds 44 tire plant codes
- Tire DOT Plant Codes – Sorted by Plant Code
- All the D.O.T. Tire Plant Codes
Here are the 44 new companies, as of February 2015:
The firms that were issued new codes, and the corresponding plants and codes, are:
  • Anhui Heding Tires Technology Co. Ltd., Bengbu, Anhui Province, China — YW
  • Balkrishna Industries Ltd., Gujarath, India — FY
  • China National Tyre & Rubber Guilin Co. Ltd., Suqiao, Guilin, China — UJ
  • Chongqing Hankook Tire Co. Ltd., Chonging City, Chongqing, China — BB
  • Joint Stock Co. Cordiant-Vostok, Omsk, Russia — HF
  • Double Coin Group (Xinjiang) Kunlun Tyre Co. Ltd., Urumqi City, Xinjiang, Weiweur, China — DB
  • Goodyear Tire & Rubber Co., Hebron, Ohio — P1
  • Hebei Xiemei Rubber Products Co. Ltd., Pingxiang, Hebei, China — E4
  • Hubei Aulice Tyre Co. Ltd., Huangshi, Hubei Province, China — BD
  • Linglong (Guangxi) Tire Co. Ltd., Liuzhou City, Guangxi, China— E7
  • LLIT (Thailand) Co. Ltd. (Shandong Linglong Tyre Co. Ltd.), Chonburi, Thailand — YC
  • Nizhnekamsk All Steel Tires Plant Ltd. (NASTP), Nizhnekamsk, Tartastan, Russia — YY
  • Nizhnekamsk Truck Tire Plant Ltd., Nizhnekamsk, Tartastan, Russia — YX
  • Numsiam Rubber (Laos) Co. Ltd., Spen District, Savannakhet Province, Laos — YH
  • Petroshina Joint Stock Co., St. Petersburg, Russia — 3D
  • P.T. Evoluzione Tyres (Pirelli), Wanakerta Purwadadi, Suban, Indonesia — XD
  • P.T. Hankook Tire Indonesia, Lippo Cikarang, Bekasi, Indonesia — BC
  • Qingdao Fuyingda Rubber Co. Ltd., Jimo, Shandong, China — AK
  • Qingdao Lidingwei Rubber Tyres Co. Ltd., Linyi City, Shandong, China — AM
  • Qingdao Longhua Special Hand Truck Co. Ltd., Jiaonan City, Qingdao, Shandong, China — BA
  • Qingdao Taihao Tyre Co. Ltd., Pingdu City, Qingdao, China — MK
  • Sailun (Vietnam) Co. Ltd., Dong Ward, Go Dau, Tay Ninh, Vietnam —YJ
  • Schefer Comercio Internacional, Pinhais, Parana, Brazil — LJ
  • Service Industries Ltd., Gujarat, Punjab, Pakistan — E8
  • Shandong Anchi Tyres Co. Ltd., Zhucheng City, Shandong, China — YK
  • Shandong Chuanghua Tire Co. Ltd., Rizhao City, Shandong, China — BN
  • Shandong Deruta Tyre Technology Co. Ltd., Yinan, Shandong, China — AL
  • Shandong Duratti Rubber Corp. Ltd., Qingzhou, Shandong, China — CT
  • Shandong Futaier Tire Co. Ltd., Linyi, Shandong, China — AU
  • Shandong Havstyear Rubber Technology Co. Ltd., Dongying City, Shandong, China — M9
  • Shandong Huasheng Rubber Co. Ltd., Dongying City, Shandong, China — AC
  • Shandong Jinwangda Tire Co. Ltd., Dongying City, Shandong, China — YV
  • Shandong New Continent Tire Co. Ltd., Yishui, Shandong, China — AJ
  • Shandong Sheg****ailai Rubber Technology Co. Ltd., Qingzhou City, Shandong, China — AN
  • Shandong Xinghongyuan Tyre Co. Ltd., Linyi City, Shandong, China — HK
  • Shandong Yongfeng Tyres Co. Ltd., Linyi City, Shandong, China — AD
  • Shandong Yongjin Rubber Co. Ltd., Guangrao, Shandong, China — HL
  • Shandong Zhentai Group Co. Ltd., Gaomi City, Shandong, China — LP
  • Shandong Zhongchuang Tyres Co. Ltd., Linyi City, Shandong, China—BT
  • Shouguang Firemax Tyre Co. Ltd., Shouguang, Shandong, China—BU
  • Sumitomo Rubber AKO Lastik Sanayi Ticaret A.S., Tuney, Cankiri, Turkey—AH
  • Techking Tires Ltd., Shandong, China—C1
  • Weifang Yuelong Rubber Co. Ltd., Shougugang, Shandong, China—7P
  • Wuyi Qiangnai Rubber Manufacture Co. Ltd., Wuyi County, Zhejiang, China—EW
  • Xuzhou Tongfei Tyre Co. Ltd., Xuzhou City, Jiangsu, China — BH
Here are all the tire plant codes:
Code:
<table>*******><tr><td>[URL="http://www.tiresafetygroup.com/?p=810"]MANUFACTURER[IMG]http://www.tiresafetygroup.com/wp-content/uploads/2014/01/tirearrow.png[/IMG][/URL]</td> <td>PLANT CODE</td> <td>[URL="http://www.tiresafetygroup.com/?p=824"]CITY[IMG]http://www.tiresafetygroup.com/wp-content/uploads/2014/01/tirearrow.png[/IMG][/URL]</td> <td>[URL="http://www.tiresafetygroup.com/?p=825"]STATE[IMG]http://www.tiresafetygroup.com/wp-content/uploads/2014/01/tirearrow.png[/IMG][/URL]</td> <td>[URL="http://www.tiresafetygroup.com/?p=828"]COUNTRY[IMG]http://www.tiresafetygroup.com/wp-content/uploads/2014/01/tirearrow.png[/IMG][/URL]</td> </tr> <tr> <td>CHINA MANUFACTURERS ALLIANCE</td> <td>01</td> <td>VALENCIA</td> <td>CALIFORNIA</td> <td>UNITED STATES</td> </tr> <tr> <td>CAOXIAN GUIDESTONE TYRE CO. LTD.</td> <td>02</td> <td>CAOXIAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TANGSHAN LINGFENG TIRE CO.</td> <td>03</td> <td>TANGSHAN</td> <td>HEBEI</td> <td>CHINA</td> </tr> <tr> <td>WENDENG SANFENG TYRE CO., LTD.</td> <td>04</td> <td>WENDENG CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BETICA COMERCIAL IMPORTADORA LTD.</td> <td>05</td> <td>SANTO ANDRE</td> <td>SAO PAULO</td> <td>BRAZIL</td> </tr> <tr> <td>HIHERO CO., LTD.</td> <td>06</td> <td>PHATUM THANI</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>RINALDI S.A.</td> <td>07</td> <td>BENTO GONCALVES</td> <td>RIO GRANDE DO SOL</td> <td>BRAZIL</td> </tr> <tr> <td>AHCOF INTERNATIONAL DEV. CO., LTD.</td> <td>08</td> <td>HEFEI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>PT ELANGPERDANA TYRE INDUSTRY</td> <td>09</td> <td>BOGOR</td> <td>JAWA BARAT</td> <td>INDONESIA</td> </tr> <tr> <td>SIAM RUBBER LTD.</td> <td>0A</td> <td>KRANTHUMBAN</td> <td>SAMUTSAKHON</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>0B</td> <td>WILSON</td> <td>NORTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>MICHELIN SIAM CO., LTD.</td> <td>0C</td> <td>CHONBURI</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>GUIZHOU TYRE FACTORY</td> <td>0D</td> <td>GIYANG</td> <td>GUIZHOU</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE HISPANIA</td> <td>0E</td> <td>TORRELAVEGA</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>INNOVA RUBBER (PINGHU) CO.</td> <td>0F</td> <td>PINGHU CITY</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>TRIANGLE TIRE CO., LTD.</td> <td>0H</td> <td>WEIHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>BEIJING CAPITAL TIRE CO., LTD.</td> <td>0J</td> <td>FANGSHAN DISTRICT, BEIJING</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>GUANGZHOU PEARL RIVER RUBBER TYRE LTD</td> <td>0K</td> <td>HUADU</td> <td>GUANGZHOU</td> <td>CHINA</td> </tr> <tr> <td>MRF LIMITED</td> <td>0L</td> <td>KOTTAYAM</td> <td>KERALA</td> <td>INDIA</td> </tr> <tr> <td>TRANSPORTATION & ENGINEERING CO.</td> <td>0M</td> <td>SMOUHA, ALEXANDRIA</td> <td>PROVINCE</td> <td>EGYPT</td> </tr> <tr> <td>ZHCJIANG HUNTINGTON FORLONG RUBBER CO.,LTD.</td> <td>0N</td> <td>FUYANG</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>B.F. GOODRICH DO BRAZIL</td> <td>0P</td> <td>ESTADO DE SAO PAULO</td> <td>CAMPINAL</td> <td>BRAZIL</td> </tr> <tr> <td>CHENG SHIN RUBBER (TIANJIN DAFENG) IND. CO., LTD.</td> <td>0R</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SUMITOMO RUBBER (SUZHOU) CO., LTD.</td> <td>0T</td> <td>CHANGSHU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG LINGLONG TYRE CO., LTD.</td> <td>0U</td> <td>ZHAOYUAN CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>HANGZHOU PLANT</td> <td>0V</td> <td>HANZHOU ECONOMIC & TECHNOLOGIC</td> <td>HANGZHOU</td> <td>CHINA</td> </tr> <tr> <td>VORONEZH OPCO</td> <td>0W</td> <td>VORONEZH</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>ACHIEVOR TIRE</td> <td>0X</td> <td>MINTO</td> <td>NEW BRUNSWICK</td> <td>CANADA</td> </tr> <tr> <td>CHINA QINADAO NO. 6 GROUP 6 LTD.</td> <td>0Y</td> <td>QINGDAO, SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>NANKANG RUBBER INDUSTRIAL, CO. LTD.</td> <td>10</td> <td>
</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG HAWK INTERNATIONAL RUBBER INDUSTRY CO.</td> <td>11</td> <td>LAIZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO SHENGDA TIRE MANUFACTURE CO., LTD.</td> <td>12</td> <td>QINGDAO, PINGDU CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO HENGDA TIRE CO., LTD.</td> <td>13</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CHENG SHIN TIRE (XIAMEN) CO., LTD.</td> <td>14</td> <td>XIAMEN</td> <td>FUJIAN</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG JINYU TYRE CO., LTD.</td> <td>15</td> <td>DONGYING</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>GOODTIME RUBBER CO, LTD.</td> <td>16</td> <td>AN TINK VILLAGE</td> <td>TRAY BANG DISTRICT</td> <td>VIETNAM</td> </tr> <tr> <td>DA TSEN TYRE FACTORY</td> <td>17</td> <td>SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>DONG HAI RUBBER FACTORY</td> <td>18</td> <td>SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO TIANGCHI TIRES CO., LTD.</td> <td>19</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>UNION RUBBER INDUSTRIES COMPANY, LTD.</td> <td>1A</td> <td>TAIPEI</td> <td>TAIWAN</td> <td>CHINA</td> </tr> <tr> <td>PIRELLI DE VENESUELA, C.A.</td> <td>1B</td> <td>VALENCIA</td> <td>ESTADO CARABOBO</td> <td>VENEZUELA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>1C</td> <td>OKLAHOMA CITY</td> <td>OKLAHOMA</td> <td>UNITED STATES</td> </tr> <tr> <td>BRIDGESTONE SHIMONOSEKI PLANT</td> <td>1D</td> <td>SHIMONOSEKI</td> <td>YAMAGUCHI 752</td> <td>JAPAN</td> </tr> <tr> <td>LIANOING TYRE FACTORY</td> <td>1E</td> <td>LONGCHENG DIS. CHAQ YANG</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>INDUSTRIA COLOMBIANA DE LLANTAS</td> <td>1F</td> <td>
</td> <td>
</td> <td>COLOMBIA</td> </tr> <tr> <td>HANKOOK TIRE (JIAXING) CO. LTD.</td> <td>1G</td> <td>JIAXING</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>COMPANIA ECUATORIANA DEL CAUCHO S.A.</td> <td>1H</td> <td>CUENCA</td> <td>ECUADOR</td> <td>ECUADOR</td> </tr> <tr> <td>XIAMEN PETREL RUBBER CO., LTD.</td> <td>1J</td> <td>XIAMEN</td> <td>FUJIAN</td> <td>CHINA</td> </tr> <tr> <td>DOUBLESTAR DONGFENG TYRE CO., LTD.</td> <td>1K</td> <td>SHI YAN CITY</td> <td>HUBEI</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL TYRE SA (PTY) LTD</td> <td>1L</td> <td>NEW BRIGHTON WEST</td> <td>PORT ELIZABETH</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>SHANDONG TAISHAN TYRE FACTORY</td> <td>1M</td> <td>FEICHENG CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>TIANJIN KINGS GLORY TIRE CO., LTD</td> <td>1N</td> <td>XI QING QU</td> <td>TIANJIN</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG HAOHUA TIRE CO., LTD.</td> <td>1P</td> <td>SHOUGUANG</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>CHAOYANG LONG MARCH TYRE CO., LTD</td> <td>1R</td> <td>CHAOYANG</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>THAI SIN RUBBER INDUSTRY LTD., PART</td> <td>1S</td> <td>KRATUMBAN</td> <td>SAMUTSAKORN</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE TIRE MANUFACTURING VIETNAM LLC</td> <td>1T</td> <td>HAI PHONG CITY</td> <td>
</td> <td>VN</td> </tr> <tr> <td>BRIDGESTONE (TIANJIN) TIRE CO., LTD.</td> <td>1U</td> <td>BEICHEN -GU</td> <td>TIANJIN</td> <td>CHINA</td> </tr> <tr> <td>THAI BRIDGESTONE NONG KHAE PLANT CO., LTD.</td> <td>1V</td> <td>AMPHUR NONG KHAE</td> <td>SARABURI</td> <td>THAILAND</td> </tr> <tr> <td>GOODYEAR INDIA LTD</td> <td>1W</td> <td>WALUJ AURANGABAD</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>SICHUAN LION TYRE CO., LTD.</td> <td>1X</td> <td>JIANYANG</td> <td>SICHUAN</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG HUATAI TYRE CO., LTD.</td> <td>1Y</td> <td>LAIWU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>OTANI TIRE CO, LTD.</td> <td>1Z</td> <td>
</td> <td>NAKORNPATHOM</td> <td>THAILAND</td> </tr> <tr> <td>MAXXIS INTERNATIONAL (THAILAND) CO., LTD.</td> <td>20</td> <td>TASIT SUB-DISTRICT, PLUAK DIST</td> <td>RAYONG</td> <td>THAILAND</td> </tr> <tr> <td>ADKINS TIRE SERVICE</td> <td>21</td> <td>OAK HILL</td> <td>OH</td> <td>UNITED STATES</td> </tr> <tr> <td>LLC MICHELIN RUSSIAN TYRE MANUFACTURING CO.</td> <td>22</td> <td>OREKHOVO-ZOUEVE</td> <td>MOSCOW</td> <td>RUSSIA</td> </tr> <tr> <td>GITI TIRE (CHON GQING) COMPANY, LTD.</td> <td>23</td> <td>YIN CHUAN</td> <td>NINGXIA</td> <td>CHINA</td> </tr> <tr> <td>JSC NIZHNEKAMSKSHINA</td> <td>24</td> <td>NIZHNEKAMSK</td> <td>TATARSTAN</td> <td>RUSSIA</td> </tr> <tr> <td>SHANDONG YONGTAI CHEMICAL INDUSTRY GROUP</td> <td>25</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MALHOTRA RUBBERS LTD.</td> <td>26</td> <td>NODIA</td> <td>DIST. GAUTAM BUDH NAGAR</td> <td>INDIA</td> </tr> <tr> <td>PYEONG TAEK PLANT</td> <td>27</td> <td>PYEONG TAEK</td> <td>KYEONGGI-DO</td> <td>KOREA</td> </tr> <tr> <td>QINGDAO HONGGUANG CHEMICAL CO., LTD.</td> <td>28</td> <td>JIAOZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GENERAL TRANSWORD MANUFACTURING CJSE</td> <td>29</td> <td>YEREVAN</td> <td>
</td> <td>ARMENIA</td> </tr> <tr> <td>JIUH SHUENN ENTERPRISE CO., LTD.</td> <td>2A</td> <td>TAICHUNG</td> <td>TAIWAN</td> <td>CHINA</td> </tr> <tr> <td>DEESTONE LTD.</td> <td>2B</td> <td>OAMNOI</td> <td>SAMUTSAKOM</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>2C</td> <td>MORRISON</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>SILVERSTONE TIRE & RUBBER COMPANY SDN BHD</td> <td>2D</td> <td>TAIPING</td> <td>PERAK</td> <td>MALAYSIA</td> </tr> <tr> <td>FEDERAL TIRE (JIANGXI) LTD.</td> <td>2E</td> <td>NANCHANG</td> <td>JIANGXI PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>INDUSTRIA COLOMBIANA DE LLANTAS S.A.</td> <td>2F</td> <td>CALI-VALLE</td> <td>
</td> <td>COLOMBIA</td> </tr> <tr> <td>PT MEGA RUBBER LTD SEMARANG</td> <td>2G</td> <td>SEMARANG</td> <td>JAVA</td> <td>INDONESIA</td> </tr> <tr> <td>DEWAN TYRES LTD.</td> <td>2H</td> <td>MEERUT</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>QINDAO GLEN GROUP CO.</td> <td>2I</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DOUBLE COIN HEAVY-DUTY TIRE CO.</td> <td>2J</td> <td>SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>LIAONING LONG MARCH TYRE CO., LTD.</td> <td>2K</td> <td>CHAOYANG CITY</td> <td>LIAONING PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>QINDAGO TONGTAI RUBBGER FACTORY</td> <td>2L</td> <td>QINGDAO CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>2M</td> <td>BLOOMINGTON</td> <td>ILLINOIS</td> <td>UNITED STATES</td> </tr> <tr> <td>QINGDAO ZHENHUA BARROW MANUFACTURING CO., LTD.</td> <td>2N</td> <td>QINGDAO</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>VIETNAM PLANT</td> <td>2P</td> <td>THUAN AN DISTRICT</td> <td>BINH DUONG</td> <td>VIETNAM</td> </tr> <tr> <td>KENDA RUBBER INDUSTRIAL CO., LTD.</td> <td>2Q</td> <td>LONG HWA TOWN</td> <td>GUANGDON</td> <td>CHINA</td> </tr> <tr> <td>P.T. BRIDGESTONE TIRE INDONESIA KARAWANG FACTORY</td> <td>2R</td> <td>KARAWANG</td> <td>WEST JAVA</td> <td>INDONESIA</td> </tr> <tr> <td>VREDESTEIN FKR (M’SIA) SDN BHD</td> <td>2S</td> <td>KLANG</td> <td>SELANGOR</td> <td>MALAYSIA</td> </tr> <tr> <td>WUXI FAR EAST TYRE CO., LTD.</td> <td>2T</td> <td>WUXI</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>CHENG SHIN – TOYO TIRE & RUBBER (CHINA) CO., LTD.</td> <td>2U</td> <td>KUNSHAN</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>TRIANGLE (WEIHAI)HUASHENG TYRE CO., LTD.</td> <td>2V</td> <td>WEIHAI</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>YANTAI TYRE FACTORY</td> <td>2W</td> <td>ZHAOYUAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>HANKOOK TIRE HUNGARY LTD.</td> <td>2X</td> <td>RACALMAS</td> <td>
</td> <td>HUNGARY</td> </tr> <tr> <td>YUNNAN TIRE FACTORY</td> <td>2Y</td> <td>KUNMING YUNNAN PROVINCE</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>COMMERCIAL TIRE SERVICE CO., INC.</td> <td>30</td> <td>DUBLIN</td> <td>OH</td> <td>UNITED STATES</td> </tr> <tr> <td>WUXI</td> <td>31</td> <td>WUXI</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>CHONBURI</td> <td>32</td> <td>CHONBURI</td> <td>CHONBURI</td> <td>THAILAND</td> </tr> <tr> <td>SICHUAN TYRE & RUBBER GROUP CO. LTD.</td> <td>33</td> <td>JIANYANG CITY</td> <td>SICHUAN</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO DALU PLASTIC CO., LTD.</td> <td>34</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TRELLEBORG LANKA (PVT) LTD.</td> <td>35</td> <td>SAPUGASKANDA, MAKOLA</td> <td>WP</td> <td>SRI LANKA</td> </tr> <tr> <td>MIDLAND SPECIALTY TIRE CO., LTD.</td> <td>36</td> <td>XUZHOU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>ZAO CONTINENTAL TIRES OF MOSCOW</td> <td>37</td> <td>MOSCOW</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>QINGDAO TENGJIANG TYRE CO., LTD.</td> <td>38</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO FUYUAN TYRE CO., LTD.</td> <td>39</td> <td>PINGDU CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GITI TIRE(HUA LIN) COMPANY,LTD.</td> <td>3A</td> <td>MU DAN JIANG</td> <td>HEI LONG JIANG PROVENCE</td> <td>CHINA</td> </tr> <tr> <td>TIANJIN UNITED TIRE & RUBBER INTL. CO., LT</td> <td>3B</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>GTY TIRE CO., MT. VERNON PLANT</td> <td>3C</td> <td>MT. VERNON</td> <td>ILLINOIS</td> <td>UNITED STATES</td> </tr> <tr> <td>PETROSHINA JOINT-STOCK COMPANY</td> <td>3D</td> <td>SAINT-PETERSBURG</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>QINGDAO YELLOWSEA RUBBER CO., LTD.</td> <td>3E</td> <td>CHENGYANG DISTRICT, QINGDAO</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>HEBEI TYRE FACTORY</td> <td>3F</td> <td>XINGTAI</td> <td>HEBEI PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>TITAN TIRE CORP. OF TEXAS</td> <td>3G</td> <td>BROWNSVILLE,</td> <td>TX</td> <td>UNITED STATES</td> </tr> <tr> <td>BIRLA TYRES</td> <td>3H</td> <td>BALASORE</td> <td>ORISSA</td> <td>INDIA</td> </tr> <tr> <td>RHODEN (M) SDN BHD</td> <td>3J</td> <td>PORT KLANG,</td> <td>SELANGOR DARUL EHSAN</td> <td>MALAYSIA</td> </tr> <tr> <td>MARANGONI TYRE S.P.A.</td> <td>3K</td> <td>ANAGNI</td> <td>FROSINONE</td> <td>ITALY</td> </tr> <tr> <td>SIAM TYRE INDUSTRY COMPANY, LTD.</td> <td>3L</td> <td>NONGPLAMORE, NONGKAE</td> <td>SARABURI</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>3M</td> <td>BLOOMINGTON</td> <td>ILLINOIS</td> <td>UNITED STATES</td> </tr> <tr> <td>CHONGQING JINDUN RUBBER PRODUCTS CO., LTD.</td> <td>3N</td> <td>CHONGQING</td> <td>CHONGQING</td> <td>CHINA</td> </tr> <tr> <td>HWA FONG RUBBER (THAILAND) CO., LTD</td> <td>3P</td> <td>BANQPOO INDUSTRIAL ESTATE</td> <td>SAMUTPRAKARN</td> <td>THAILAND</td> </tr> <tr> <td>CONTINENTAL AG</td> <td>3Q</td> <td>
</td> <td>USA</td> <td>GERMANY</td> </tr> <tr> <td>SOCIEDADE MICHELIN DE PARTICIPACOES IND. E COM. LTD.</td> <td>3R</td> <td>ITATIAIA – RJ</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>CONTINENTAL DO BRASIL PRODUTOS AUTOMOTIVOS LTDA.</td> <td>3S</td> <td>PONTA GROSSA PR</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>PT MEGA SAFE TYRE INDUSTRY</td> <td>3T</td> <td>SALATIGA</td> <td>JAWA TENGAH</td> <td>INDONESIA</td> </tr> <tr> <td>SPECIALTY TIRES OF AMERICA (TENNESSEE) INC.</td> <td>3U</td> <td>UNICOI</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>BALKRISHNA INDUSTRIES LTD</td> <td>3V</td> <td>WALUJ</td> <td>AURANGADAD</td> <td>INDIA</td> </tr> <tr> <td>SHANDONG QI XIA TIRE FACTORY</td> <td>3W</td> <td>QI XIA</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TIANJIN TYRE & RUBBER INDUSTRY CO., LTD.</td> <td>3X</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE POLAND SP.Z.O.O.</td> <td>3Y</td> <td>POZNAN</td> <td>POZNAN</td> <td>POLAND</td> </tr> <tr> <td>SUPERKING MFRS.(TYRE) PVT.LTD.</td> <td>40</td> <td>GHAZIABAD</td> <td>U.P.</td> <td>INDIA</td> </tr> <tr> <td>METRO TYRES OF NORTH AMERICA</td> <td>41</td> <td>LUDHIANA</td> <td>PUNJAB</td> <td>INDIA</td> </tr> <tr> <td>XUZHOU HANDBAND TIRE CO., LTD.</td> <td>42</td> <td>XUZHOU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>KYOTO JAPAN TIRE CORP. LTD.</td> <td>43</td> <td>BEIJING</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO XINGHUA GROUP CO., LTD.</td> <td>44</td> <td>JIAONAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>JISNG XI CHARIOT TYRE CO., LTD.</td> <td>45</td> <td>DE AN</td> <td>JIANG XI</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL SIME TYRES SDN BHD. DMIB BERHAD</td> <td>46</td> <td>46050 PETALING JAYA</td> <td>SELANGOR</td> <td>MALAYSIA</td> </tr> <tr> <td>YOKOHAMA TIRE MANUFACTURING (THAILAND) CO.,LTD.</td> <td>47</td> <td>AMPHUR PLUARDANG</td> <td>RAYONG</td> <td>THAILAND</td> </tr> <tr> <td>KOLSAN KOCAELI LASTIK SANAYI A.S.</td> <td>48</td> <td>KOCAELI</td> <td>IZMIT</td> <td>TURKEY</td> </tr> <tr> <td>LAIZHOU LU QING RUBBER INDUSTRY CO., LTD.</td> <td>49</td> <td>LAIZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>VEE RUBBER COMPANY, LTD.</td> <td>4A</td> <td>
</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>GOODYEAR CANADA, INC.</td> <td>4B</td> <td>NAPANEE</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>SOUTH PACIFIC TYRES</td> <td>4C</td> <td>SOMERTON</td> <td>VICTORIA</td> <td>AUSTRAILIA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>4D</td> <td>MORRISON</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>ANHUI KAIYUAN TIRE CO., LTD.</td> <td>4E</td> <td>HEFEI</td> <td>ANHUI</td> <td>CHINA</td> </tr> <tr> <td>CIA HULERA TORNEL</td> <td>4F</td> <td>FRACC. SAN FRANCISCO CHILPAN</td> <td>TULTITLAN</td> <td>MEXICO</td> </tr> <tr> <td>HENAN TYRE FACTORY</td> <td>4G</td> <td>JIAOZUO</td> <td>HENAN</td> <td>CHINA</td> </tr> <tr> <td>SOUTH CHINA TIRE & RUBBER COMPANY, LTD.</td> <td>4H</td> <td>PANYU</td> <td>GUANGZHOU</td> <td>CHINA</td> </tr> <tr> <td>SVERDLOVSK TIRE MAKING WORKS</td> <td>4J</td> <td>
</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>TIANJIN TYRE MANFACTURING PLANT</td> <td>4K</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>CARLISLE TIRE & RUBBER CO., LTD</td> <td>4L</td> <td>BU JI TOWN</td> <td>SHENZHEN</td> <td>CHINA</td> </tr> <tr> <td>MICHELIN NORTH AMERICA, INC.</td> <td>4M</td> <td>GREENVILLE</td> <td>SOUTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>HWA FONG RUBBER CO.(SUZHOU) CO. LTD.</td> <td>4N</td> <td>CHANGSHU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>PT SURYARAYA RUBBERINDO INDUSTRIES</td> <td>4P</td> <td>CILEUNGSI, BOGOR</td> <td>
</td> <td>INDONESIA</td> </tr> <tr> <td>FABRICA URUGUAYA DE NEUMATICOS S.A. (FUNSA)</td> <td>4Q</td> <td>MONTIEVIDEEO</td> <td>
</td> <td>URUGUAY</td> </tr> <tr> <td>RUMAGUMA A.D.</td> <td>4R</td> <td>BELGRADE</td> <td>
</td> <td>SERBIA</td> </tr> <tr> <td>BELARUS TYRE WORKS BELSHINA</td> <td>4S</td> <td>BOBRUISK</td> <td>
</td> <td>BELARUS</td> </tr> <tr> <td>NANJING KUMHO TIRE CO., LTD.</td> <td>4T</td> <td>NANJING</td> <td>JIANGSOO</td> <td>CHINA</td> </tr> <tr> <td>YOKOHAMA TIRE PHILIPPINES INC.</td> <td>4U</td> <td>CLARK FIELD</td> <td>PAMPANGA</td> <td>PHILIPPINES</td> </tr> <tr> <td>CHONCHE AUTO DOUBLE HAPPINESS TYRE CORP., LTD.</td> <td>4V</td> <td>TAIYUAN CITY</td> <td>SHANXI</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE ACC INDIA LTD.</td> <td>4W</td> <td>POST SAGORE 454774, DIST.DHAR</td> <td>MADHYA PRADESH</td> <td>INDIA</td> </tr> <tr> <td>SUPER EAST INDUSTRIAL COMPANY, LTD.</td> <td>4X</td> <td>PEITSUN YUNG CHING HIANG</td> <td>CHANG-HWA</td> <td>TAIWAN</td> </tr> <tr> <td>SHANDONG CHENGSHAN TIRE CO., LTD.</td> <td>4Y</td> <td>RONG CHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG SHENGTAI RUBBER GROUP CO., LTD.</td> <td>50</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>PIRELLI TYRE CO. LTD.</td> <td>51</td> <td>YANZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO AONUO TYRE CO., LTD.</td> <td>52</td> <td>PINGDU CITY, QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SAILUN CO., LTD.</td> <td>53</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MITAS A.S.</td> <td>54</td> <td>CZ-76531 OTROKOVICE</td> <td>
</td> <td>CZECH REPUBLIC</td> </tr> <tr> <td>QINGDAO YELLOWSEA TIRE CO., LTD.</td> <td>55</td> <td>JIAOZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO QIHANG TYRE CO., LTD.</td> <td>56</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>HWA FONG RUBBER (THAILAND) PUBLIC COMPANY LIMITED</td> <td>57</td> <td>MUANG</td> <td>SAMUTRAKAN</td> <td>THAILAND</td> </tr> <tr> <td>ZHEJIANG QINGDA RUBBER CO., LTD.</td> <td>58</td> <td>YONGKANG CITY</td> <td>ZHEJIANG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>S.R. TYRE COMPANY LTD.</td> <td>59</td> <td>AMPHUR SRIMAHOSOD</td> <td>PRACHINBURI</td> <td>THAILAND</td> </tr> <tr> <td>VEE RUBBER INTERNATIONAL COMPANY, LTD.</td> <td>5A</td> <td>
</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>TIANJIN CENTURY RUBBER CO., LTD.</td> <td>5B</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE HISPANIA</td> <td>5C</td> <td>BILBAO</td> <td>E-48080</td> <td>SPAIN</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>5D</td> <td>MORRISON</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>MANFACTURE FRANCAISE DES PNEUMATIQUES MICHELIN</td> <td>5E</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>CIA HULERA TORNEL</td> <td>5F</td> <td>APARTADO POSTAL 16-020</td> <td>AZCAPOTZALCO</td> <td>MEXICO</td> </tr> <tr> <td>HOC MON</td> <td>5G</td> <td>HO CHI MINH</td> <td>
</td> <td>VIETNAM</td> </tr> <tr> <td>DEERUBBER CO., LTD</td> <td>5H</td> <td>OAMMOL</td> <td>SAMUTSAKORN</td> <td>THAILAND</td> </tr> <tr> <td>SHANGHAI DA FU RUBBER PLANT</td> <td>5J</td> <td>SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>PT MULTISTRADA ARAH SARANA</td> <td>5K</td> <td>BEKASI</td> <td>JAWA BARAT</td> <td>INDONESIA</td> </tr> <tr> <td>GUILIN SOUTH RUBBER INTERN’L CORP.</td> <td>5L</td> <td>GUILIN</td> <td>GUANGXI</td> <td>CHINA</td> </tr> <tr> <td>HANKOOK TIRE KUMSAN PLANT</td> <td>5M</td> <td>KUMSAN KUN</td> <td>CHUNG CHONG NAM DO</td> <td>KOREA</td> </tr> <tr> <td>CHENG SHIN RUBBER (VIETNAM) IND. CO., LTD.</td> <td>5N</td> <td>NHON TRACH</td> <td>DONG NAI</td> <td>VIETNAM</td> </tr> <tr> <td>BALKRISHNA INDUSTRIES LTD.(UNIT:BALKRISHNA TYRES)</td> <td>5P</td> <td>CHOPANKI,BHIWADI II</td> <td>DIST.ALWAR(RAJASTHAN)</td> <td>INDIA</td> </tr> <tr> <td>RONGCHENG GUOTAI TYRE CO., LTD.</td> <td>5Q</td> <td>RONGCHENH SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>FALCON TYRES LTD</td> <td>5R</td> <td>MYSORE</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>LANYU AIRCRAFT TIRE DEVELOPMENT CO.</td> <td>5S</td> <td>GUILLIN</td> <td>GUANGXI</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE DO BRAZIL</td> <td>5T</td> <td>SANTO ANDRE-EST. SAO PAULO</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>JIANGSU FEICHI CO., LTD.</td> <td>5U</td> <td>YANCHENG</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>SOCIETE DE DEV MECANIQUE-SODEMECA</td> <td>5V</td> <td>NOYELLES-LES SECLIN</td> <td>WATTIGNIES</td> <td>FRANCE</td> </tr> <tr> <td>GITI TIRE (FUJIAN) COMPANY, LTD.</td> <td>5W</td> <td>PUTIANCITY</td> <td>FUJIAN PROVENCE</td> <td>CHINA</td> </tr> <tr> <td>AEOLUS TYRE CO., LTD.</td> <td>5X</td> <td>JIAOZUO</td> <td>HENAN</td> <td>CHINA</td> </tr> <tr> <td>TIANJIN WANDA TYRE GROUP CO., LTD.</td> <td>5Y</td> <td>YIXINGBU TOWN, BEICHEN DIST.</td> <td>TIANJIN</td> <td>CHINA</td> </tr> <tr> <td>REFACCIONARIA VALATI S.A. DE C.V.</td> <td>5Z</td> <td>CIUDAD JUAREZ</td> <td>CHIHUAHUA</td> <td>MEXICO</td> </tr> <tr> <td>OOO ‘NOKIAN’ TYRES’</td> <td>60</td> <td>LENINGRAD REGION, VSEVOLOZHSK</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>EU-RETEC (PVT.) LTD.</td> <td>61</td> <td>NAGODA</td> <td>KALUTARA</td> <td>SRI LANKA</td> </tr> <tr> <td>CHINA RUIAN LIWANG TYRE MANUFACTORY CO., LTD.</td> <td>62</td> <td>RUIAN</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>ZHCJIANG HUNTINGTON BULL RUBBER CO., LTD.</td> <td>63</td> <td>FUYANG</td> <td>ZHEJIAN</td> <td>CHINA</td> </tr> <tr> <td>HORIZON-ADDIS TYRE SHARE COMPANY</td> <td>64</td> <td>ADDIS ABABA</td> <td>
</td> <td>ETHIOPIA</td> </tr> <tr> <td>CONTINENTAL DO BRASIL PRODUTOS AUTOMOTIVOS LTDA.</td> <td>65</td> <td>CAMACARI</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>XINGYUAN TIRE GROUP CO., LTD.</td> <td>66</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>ANLAS LASTIK SANAYI VE TICARET A.S.</td> <td>67</td> <td>DUZCE</td> <td>
</td> <td>TURKEY</td> </tr> <tr> <td>GUMONDER INDUSTRIAL CORP.</td> <td>68</td> <td>JYI JYI TOWN</td> <td>NAN TOU HSIEN</td> <td>TAIWAN</td> </tr> <tr> <td>QINGDAO XIYINGMEN DOUBLE CAMEL TYRE CO., LTD.</td> <td>69</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>ROADSTONE TYRE & RUBBER COMPANY, LTD.</td> <td>6A</td> <td>NONTABURI BANGKOK</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>MT. VERNON PLANT OF GENERAL TIRE, INC.</td> <td>6B</td> <td>MT. VERNON</td> <td>ILLINOIS</td> <td>UNITED STATES</td> </tr> <tr> <td>FIRESTONE TIRE & RUBBER CO.</td> <td>6C</td> <td>BURGOS</td> <td>E-48080</td> <td>SPAIN</td> </tr> <tr> <td>HENAN TYRE PLANT</td> <td>6D</td> <td>JIAOZUO</td> <td>HENA PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>DOUBLE HAPPINESS TYRE IND. CORP., LTD.</td> <td>6E</td> <td>TAIYUAN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>CIA HULERA TORNEL</td> <td>6F</td> <td>APARTADO POSTAL 16-020</td> <td>AZCAPOTZALCO</td> <td>MEXICO</td> </tr> <tr> <td>CONTINENTIAL AUTOMOTIVE PRODUCTS S.R.L.</td> <td>6G</td> <td>TIMISOARA</td> <td>
</td> <td>ROMANIA</td> </tr> <tr> <td>SRICHAKRA TYRES LTD.</td> <td>6H</td> <td>MADURAI DISTRICT</td> <td>TAMILNADU</td> <td>INDIA</td> </tr> <tr> <td>TAURUS AGRICULTURAL TYRES LTD.</td> <td>6I</td> <td>NYIREGYHAZA</td> <td>
</td> <td>HUNGARY</td> </tr> <tr> <td>MITAS A.S.</td> <td>6J</td> <td>ZLIN</td> <td>
</td> <td>CZECH REPUBLIC</td> </tr> <tr> <td>CEAT LIMITED</td> <td>6K</td> <td>AURANGABAD</td> <td>MAHARASHTRA</td> <td>INDIA</td> </tr> <tr> <td>MABOR DE MOCAMBIQUE, SARL</td> <td>6L</td> <td>MAPUTO</td> <td>
</td> <td>MOZAMBIQUE</td> </tr> <tr> <td>VEE TYRE AND RUBBER CO., LTD.</td> <td>6M</td> <td>TAMBOL CHAIMONGKOL, AMPHUR MUA</td> <td>SAMUTSAKORN</td> <td>THAILAND</td> </tr> <tr> <td>MEWAT TIRE & RUBBER (P) LTD.</td> <td>6N</td> <td>ALWAR</td> <td>RAJASTHAN</td> <td>INDIA</td> </tr> <tr> <td>AMTEL KIROV</td> <td>6P</td> <td>KIROV</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>WEIHAI ZHONGWEI RUBBER CO., LTD.</td> <td>6Q</td> <td>WEIHAI CITY, SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO ZHENHUA INDUSTRIAL GROUP CORPORATION</td> <td>6R</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE DO BRAZIL INDUSTRIAL E COMERCIO LTDA.</td> <td>6T</td> <td>SANTO ANDRE-EST.</td> <td>SAO PAULO</td> <td>BRAZIL</td> </tr> <tr> <td>SODG</td> <td>6U</td> <td>CLERMONT-FERRAND</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>INDUSTRIAS DEL NEUMATICO S.A.</td> <td>6V</td> <td>E-03680 ASPE (ALICANTE)</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>HWA FONG RUBBER (CHINA) CO., LTD.</td> <td>6W</td> <td>CHANGSHU JIANG SU</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>GUANGZHOU BOLEX TYRE LTD.</td> <td>6X</td> <td>HUADA CITY</td> <td>GUANGDONG</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL MATADOR TIRES S.R.O.</td> <td>6Y</td> <td>
</td> <td>
</td> <td>SLOVAKIA</td> </tr> <tr> <td>SHANDONG SATTAI RUBBER CO., LTD.</td> <td>70</td> <td>DONGYING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>OLIVER RUBBER COMPANY</td> <td>71</td> <td>ATHENS</td> <td>GA</td> <td>UNITED STATES</td> </tr> <tr> <td>LAIZHOU XIONGYING RUBBER IND., CO. LTD.</td> <td>72</td> <td>LAIZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TOYO TIRE NORTH AMERICA MANUFACTURING, INC.</td> <td>73</td> <td>WHITE</td> <td>GA</td> <td>UNITED STATES</td> </tr> <tr> <td>TIANCI CHEMICAL CO. LTD.</td> <td>74</td> <td>SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG ZHONGCHE TYRE CO., LTD.</td> <td>75</td> <td>SHANDONG</td> <td>SHOUGUANG</td> <td>CHINA</td> </tr> <tr> <td>DOUBLE COIN GROUP RUGAO TYRE CO., LTD.</td> <td>76</td> <td>RUGAO</td> <td>JIANG SU</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG CHENGSHAN TYRE CO.</td> <td>77</td> <td>RONGCHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>XINTAI RUBBER CO., LTD.</td> <td>78</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CHENG SHIN-PETREL TIRE (XIAMEN) CO., LTD. XIAMEN BRANCH</td> <td>79</td> <td>XIAMEN</td> <td>FUJIAN</td> <td>CHINA</td> </tr> <tr> <td>KINGS TIRE INDUSTRIES CO., LTD.</td> <td>7A</td> <td>CHAUGHUA</td> <td>TAIWAN</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG LONGYUE RUBBER CO., LTD</td> <td>7B</td> <td>HEZE CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>LAIWU SUNSHINE TYRE CO., LTD.</td> <td>7C</td> <td>LAIWU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>HANGZHOU GENERAL RUBBER FACTORY</td> <td>7D</td> <td>HANGZHOU</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>LIMA CAUCHO S.A.</td> <td>7E</td> <td>
</td> <td>
</td> <td>PERU</td> </tr> <tr> <td>CHENG SHIN RUBBER (XIAMEN)</td> <td>7F</td> <td>XIAMEN SEZ</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE POLAND SP.Z.O.O.</td> <td>7G</td> <td>POZNAN</td> <td>
</td> <td>POLAND</td> </tr> <tr> <td>SHENYANG SUNSHINE TYRE CO., LTD.</td> <td>7H</td> <td>SHENYANG</td> <td>LIAONING PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>P.T. HUNG – A INDONESIA</td> <td>7I</td> <td>WEST JAWA</td> <td>
</td> <td>INDONESIA</td> </tr> <tr> <td>NORTHWEST GENERAL RUBBER FACTORY</td> <td>7J</td> <td>XIANYANG CITY</td> <td>SHAANXI</td> <td>CHINA</td> </tr> <tr> <td>FRIENDSHIP RUBBER INDUSTRY (M) SDN BHD</td> <td>7K</td> <td>SELANGOR DARUL EHSAN</td> <td>
</td> <td>MALAYSIA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER CO.</td> <td>7L</td> <td>SHAHEKOU DISTRICT</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>WOLBER S.A.</td> <td>7M</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>HAOHUA SOUTH (GUILIN) RUBBER, LTD.</td> <td>7N</td> <td>GUILIN</td> <td>GUANGXI</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG YUELONG RUBBER CO., LTD.</td> <td>7P</td> <td>SHOUGUANG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DONGYING WEIDE TYRE CO., LTD.</td> <td>7R</td> <td>DONGYING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>P.T. SUMI RUBBER INDONESIA</td> <td>7T</td> <td>CIKAMPEK, JAWA BARAT</td> <td>
</td> <td>INDONESIA</td> </tr> <tr> <td>NANJING KUMHO TIRE CO., LTD TBR</td> <td>7U</td> <td>NANJING</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>MICHELIN SHENYANG TIRE CO., LTD.</td> <td>7V</td> <td>SHENYANG</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>SIAMESE TYRE CO., LTD.</td> <td>7W</td> <td>MINBURI (SANSAEB)</td> <td>BANGKOK</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>7X</td> <td>GRANITEVILLE</td> <td>SC</td> <td>UNITED STATES</td> </tr> <tr> <td>KENDA RUBBER CHINA CO., LTD.</td> <td>7Y</td> <td>KUNSHAN, JIANGSU</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>RONGCHENG RONGDA RUBBER CO., LTD.</td> <td>7Z</td> <td>SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG WANDA BOTO TYRE CO., LTD.</td> <td>80</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CHENGDE XIANGYAN TYRE CORP. LTD.</td> <td>81</td> <td>PINGQUAN</td> <td>HEBEI</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG WANSHINE TIRE CO., LTD.</td> <td>82</td> <td>ZIBO</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG HENGFENG RUBBER & PLUSTIC CO., LTD.</td> <td>83</td> <td>GUANGRAO COUNTY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHIFENG JUXING TIRE CO., LTD.</td> <td>84</td> <td>GAOTANG</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>CHONGQING WEIXING RUBBER INDUSTRY CO., LTD.</td> <td>85</td> <td>CHONGQING</td> <td>CHONGQING</td> <td>CHINA</td> </tr> <tr> <td>TECHNIC TYRE</td> <td>86</td> <td>BURTON-ON-TRENT</td> <td>STAFFORDSHIRE</td> <td>UNITED KINGDOM</td> </tr> <tr> <td>SHANDONG HONGSHENG RUBBER CO., LTD.</td> <td>87</td> <td>GUANGRAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO OIZHOU RUBBER CO., LTD.</td> <td>88</td> <td>PINGDU,QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MONOTONA TYRES LTD</td> <td>89</td> <td>TALUKA WAD DIST THANE</td> <td>MAHARASTRA</td> <td>INDIA</td> </tr> <tr> <td>ZAPATER DIAZ I.C.S.A. TIRE CO.</td> <td>8A</td> <td>MUNRO PROV. DE BUENOS AIRES</td> <td>
</td> <td>ARGENTINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>8B</td> <td>DES MOINES</td> <td>IOWA</td> <td>UNITED STATES</td> </tr> <tr> <td>FIRESTONE- FRANCE FRANCE</td> <td>8C</td> <td>F-62401 BETHUNE CEDEX</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>HANGZHOU GENERAL RUBBER FACTORY</td> <td>8D</td> <td>JIANDE</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>NEXEN TIRE CORPORATION</td> <td>8E</td> <td>KYUNGSANGNAM-DO</td> <td>
</td> <td>SOUTH KOREA</td> </tr> <tr> <td>APOLLO TYRES LTD.</td> <td>8F</td> <td>VADODARA</td> <td>GUJARAT</td> <td>INDIA</td> </tr> <tr> <td>HAIKOU HAIHUA TYRE CO., LTD.</td> <td>8G</td> <td>HAIKOU</td> <td>HAINAN</td> <td>CHINA</td> </tr> <tr> <td>CEAT LTD.</td> <td>8H</td> <td>NASIK</td> <td>MAHARASHTRA</td> <td>INDIA</td> </tr> <tr> <td>JIANGSU HANTA TIRE BIAS PLANT</td> <td>8J</td> <td>HUAIYIN</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>CHONGGING TYRE CHEIF FACTORY</td> <td>8K</td> <td>CHONGQING</td> <td>SICHUAN</td> <td>CHINA</td> </tr> <tr> <td>CARLISLE TIRE & RUBBER CO.</td> <td>8L</td> <td>POINT FORTIN</td> <td>
</td> <td>TRINIDAD</td> </tr> <tr> <td>DEESTONE INTERNATIONAL CO., LTD.</td> <td>8M</td> <td>NAKORNPRATOM</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>LIANGSHAN DAHUA TYRE CO., LTD.</td> <td>8N</td> <td>JINING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>RONGCHENG FENGFU RUBBER CO., LTD.</td> <td>8P</td> <td>RONGCHENG CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO DOUBLESTAR TIRE INDUSTRIAL CO., LTD.</td> <td>8R</td> <td>JIAONAN DEVELOPMENT ZONE</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>PETLAS TIRE INDUSTRY AND TRADE CO.</td> <td>8S</td> <td>KIRSEHIR</td> <td>
</td> <td>TURKEY</td> </tr> <tr> <td>FIRESTONE SOUTH AFRICA (PTY) LTD.</td> <td>8T</td> <td>BRITS</td> <td>
</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>PIRELLI TYRE S.P.A</td> <td>8U</td> <td>BICOCCA</td> <td>MILAN</td> <td>ITALY</td> </tr> <tr> <td>CHINA HUHHOT RUBBER PLANT</td> <td>8V</td> <td>HUHHOT</td> <td>INNER MONGOLIA</td> <td>CHINA</td> </tr> <tr> <td>YUNNAN RUBBER GROUP IMP & EXP CORP.</td> <td>8W</td> <td>XINGYING DISTRICT KUNMING</td> <td>YUNNAN</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>8X</td> <td>GRANITEVILLE</td> <td>SC</td> <td>UNITED STATES</td> </tr> <tr> <td>KENDA RUBBER (VIETNAM) CO., LTD.</td> <td>8Y</td> <td>HUYEN THONG NHAT</td> <td>TINH DONG NAI</td> <td>VIETNAM</td> </tr> <tr> <td>YOKOHAMA RUBBER CO., LTD. ONOMICHI PLANT</td> <td>8Z</td> <td>ONOMICHI</td> <td>HIROSHIMA</td> <td>JAPAN</td> </tr> <tr> <td>TOYO TIRE (ZHUCHENG) CO., LTD.</td> <td>90</td> <td>ZHUCHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO HUATIAN HAND TRUCK CO., LTD</td> <td>91</td> <td>JIAO NAN QING DAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TENGZHOU BRONCHO TYRE CO., LTD.</td> <td>92</td> <td>TENGZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>S.C. PIRELLI TYRES ROMANIA S.R.L.</td> <td>93</td> <td>SLATINA</td> <td>OLT</td> <td>ROMANIA</td> </tr> <tr> <td>QINGDAO LONGHAI TIRE MANUFACTURING CO., LTD.</td> <td>94</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>JIANGSU GENERAL SCIENCE TECHNOLOGY CO., LTD.</td> <td>95</td> <td>WUXI</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE FIRESTONE DO BRASIL INDUSTRIA E COMERCIO LTDA. FABRICA – BAHIA</td> <td>96</td> <td>CAMACARI</td> <td>BAHIA</td> <td>BRAZIL</td> </tr> <tr> <td>SHANGHAI RHODEN RUBBER CO., LTD.</td> <td>97</td> <td>QING PU DISTRICT</td> <td>SHANGHAI</td> <td>CHINA</td> </tr> <tr> <td>HUIZHOU PLANT</td> <td>98</td> <td>HUIZHOU</td> <td>GUANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO MALIK INT’L TRADE CO., LTD.</td> <td>99</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SIEMESE RUBBER CO., LTD</td> <td>9A</td> <td>MINBURI</td> <td>BANKOK</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE CANADA INC.</td> <td>9B</td> <td>JOLIETTE</td> <td>QUEBEC</td> <td>CANADA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE ITALIA S.P.A.</td> <td>9C</td> <td>7-26 BODUGNO (BARI)</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>P.T. INDUSTRI KARET DELI</td> <td>9D</td> <td>MEDAN</td> <td>
</td> <td>INDONESIA</td> </tr> <tr> <td>FIVE STARS INDUSTRIAL CO., LTD</td> <td>9E</td> <td>
</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>J.K. INDUSTRIES LTD.</td> <td>9F</td> <td>
</td> <td>MADHYA PRADESH</td> <td>INDIA</td> </tr> <tr> <td>WEIFANG YONGGU MFG. CO., LTD.</td> <td>9G</td> <td>GAOMI CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>JIANGSU TYRE FACTORY</td> <td>9H</td> <td>XUZHOU</td> <td>JIANGSU PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>SUNTEC TYRES LTD.</td> <td>9I</td> <td>TRICHUR</td> <td>KERALA</td> <td>INDIA</td> </tr> <tr> <td>GITI (NINGXIA YIN CHUAN) RUBBER FACTORY</td> <td>9J</td> <td>YIN CHUAN</td> <td>NINGXIA</td> <td>CHINA</td> </tr> <tr> <td>RONGCHENG GUOTAI TYRE COMPANY, LTD.</td> <td>9K</td> <td>RONGCHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MRF LIMITED</td> <td>9L</td> <td>SADASIVAPED</td> <td>ANDHRA PRADESH</td> <td>INDIA</td> </tr> <tr> <td>ALEXANDRIA TIRE CO., S.A.E.</td> <td>9M</td> <td>AMRIA</td> <td>ALEXANDRIA</td> <td>EGYPT</td> </tr> <tr> <td>BALKRISHNA INDUSTRIES LTD.(UNIT.BALKRISHNA TYRES)</td> <td>9N</td> <td>CHOPANKI,BHIWADI</td> <td>ALWAR,RAJASTHAN</td> <td>INDIA</td> </tr> <tr> <td>QINGDAO TAIFA GROUP CP., LTD.</td> <td>9P</td> <td>JIONAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CHANGCHUN TIRE LTD. LIABILITY CO.</td> <td>9Q</td> <td>CHANGCHUN</td> <td>JILIN</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO JIAONAN ZHONGTAI TYRE CO., LTD.</td> <td>9R</td> <td>QINGDAO JIAONAN CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>KEE LIBERTY TIRE, INC.</td> <td>9S</td> <td>SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>CHENG SHIN TIRE & RUBBER (CHINA) CO., LTD.</td> <td>9T</td> <td>KUNSHAN</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>GITI TIRE(ANHUI) COMPANY, LTD.</td> <td>9U</td> <td>HEFEI</td> <td>ANHUI PROVENCE</td> <td>CHINA</td> </tr> <tr> <td>GENERAL TYRE EAST AFRICA, LTD.</td> <td>9V</td> <td>ARUSHA</td> <td>TANZANIA</td> <td>AFRICA</td> </tr> <tr> <td>SHANDONG HONGYU RUBBER CO., LTD.</td> <td>9W</td> <td>SHANDONG</td> <td>CHINA</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC</td> <td>9X</td> <td>GRANITEVILLE</td> <td>SC</td> <td>UNITED STATES</td> </tr> <tr> <td>LANXI FUCHUEN RUBBER CO., LTD</td> <td>9Y</td> <td>LANXI</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO LIANYI TYRES CO., LTD.</td> <td>A0</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>PNEUMATICS MICHELIN</td> <td>A1</td> <td>86-POTIERS</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>QINGDAO GREAT RUBBER FACTORY</td> <td>A2</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GENERAL TIRE & RUBBER CO</td> <td>A3</td> <td>MOUNT VERNON</td> <td>ILLINOIS</td> <td>UNITED STATES</td> </tr> <tr> <td>HUNG-A CO., LTD.</td> <td>A4</td> <td>PUSAN</td> <td>
</td> <td>KOREA</td> </tr> <tr> <td>T.C. DEBICA S.A.</td> <td>A5</td> <td>DEBICA</td> <td>
</td> <td>POLAND</td> </tr> <tr> <td>APOLLO TYRES LTD.</td> <td>A6</td> <td>COCHIN 682016</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>THAI BRIDGESTONE CO., LTD.</td> <td>A7</td> <td>AMPHUR KLONG LUANG</td> <td>PATHUMTHANI</td> <td>THAILAND</td> </tr> <tr> <td>P.T. BRIDGESTONE TIRE INDONESIA</td> <td>A8</td> <td>KELURAHAN HARAPAN JUYA BEKASI</td> <td>JAWA BARAT</td> <td>INDONESIA</td> </tr> <tr> <td>GENERAL TIRE CO</td> <td>A9</td> <td>BRYAN</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>TIANJIN NORMANDY RUBBER CO., LTD.</td> <td>AA</td> <td>QIAO SAN DAO</td> <td>TIANJIN</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG RUBBER FACTORY</td> <td>AB</td> <td>WEIFANG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GENERAL TIRE CO.</td> <td>AC</td> <td>CHARLOTTE</td> <td>NORTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>GENERAL TIRE CO.</td> <td>AD</td> <td>MAYFIELD</td> <td>KENTUCKY</td> <td>UNITED STATES</td> </tr> <tr> <td>GENERAL FABRICA ESPANOIA DEL CAUCHO S.A.</td> <td>AE</td> <td>TORRELAVEGO</td> <td>SANTANDER</td> <td>SPAIN</td> </tr> <tr> <td>CONTINAL MABOR-INDUSTRIA DE PNEUS, S.A.</td> <td>AF</td> <td>
</td> <td>
</td> <td>PORTUGAL</td> </tr> <tr> <td>CIA HULERS TORNEL S.A. DE C.V.</td> <td>AG</td> <td>LAGO AULLAGAS 60</td> <td>
</td> <td>MEXICO</td> </tr> <tr> <td>GENERAL POPO S.A.</td> <td>AH</td> <td>MEXICO CITY 17</td> <td>
</td> <td>MEXICO</td> </tr> <tr> <td>LONGKOU XINGLONG HICON TYRE CO.</td> <td>AI</td> <td>LONGKOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>UNIROYAL TIRE COMPANY</td> <td>AJ</td> <td>DETROIT</td> <td>MICHIGAN</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL TIRE COMPANY</td> <td>AK</td> <td>CHICOPEE FALLS</td> <td>MASSACHUSETTS</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE COMPANY</td> <td>AL</td> <td>EAU CLAIRE</td> <td>WISCONSIN</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL TIRE COMPANY</td> <td>AM</td> <td>LOS ANGELES</td> <td>CALIFORNIA</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE MANUFACTURING</td> <td>AN</td> <td>OPELIKA</td> <td>ALABAMA</td> <td>UNITED STATES</td> </tr> <tr> <td>WEARWELL TIRE & TUBE CO. (PVT) LTD.</td> <td>AO</td> <td>BHOPAL</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE MANUFACTURING</td> <td>AP</td> <td>ARDMORE</td> <td>OKLAHOMA</td> <td>UNITED STATES</td> </tr> <tr> <td>CARLISLE TIRE & WHEEL CO. LTD.</td> <td>AQ</td> <td>MEIXIAN, GUANGDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>O.J.S.C. ORDENS OF LENIN AND OCT REVOL. YAROSLAVL</td> <td>AR</td> <td>YAROSLAVL</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>QINGDAO QIANJIN RUBBER GROUP</td> <td>AS</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>COOPER-AVON TYRES, LTD.</td> <td>AT</td> <td>MELKSHAM</td> <td>WILTSHIRE</td> <td>ENGLAND</td> </tr> <tr> <td>UNIROYALLTD, KITCHENER, ONTARIO CANADA</td> <td>AU</td> <td>KITCHENER</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>SHANDONG WOSEN RUBBER CO., LTD.</td> <td>AV</td> <td>SHANDONG PROVINCE</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SAMSON TIRE & RUBBER COMPANY, LTD.</td> <td>AW</td> <td>TEL AVIV</td> <td>
</td> <td>ISRAEL</td> </tr> <tr> <td>PHOENIX GUMMIWERKE, A. G.</td> <td>AX</td> <td>2000 HAMBURG 90</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>SHANDONG LUHE GROUP GENERAL CO.</td> <td>AY</td> <td>ZHUCHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SICHUAN YUAN XING RUBBER CO., LTD.</td> <td>B0</td> <td>DAYI DISTRICT</td> <td>SICHUAN PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>PNEUMATICS MICHELIN</td> <td>B1</td> <td>LA ROCHESUR-YON</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>CONTINENTAL SIME TYRE PJ SDN BERHAD</td> <td>B2</td> <td>SELANGOR DARUL EHSAN</td> <td>
</td> <td>MALAYSIA</td> </tr> <tr> <td>MICHELIN NORTH AMERICA (CANADA), INC.</td> <td>B3</td> <td>BRIDGEWATER</td> <td>NOVA SCOTIA</td> <td>CANADA</td> </tr> <tr> <td>TAURUS HUNGARIAN RUBBER WORKS</td> <td>B4</td> <td>BUDAPEST</td> <td>
</td> <td>HUNGARY</td> </tr> <tr> <td>OLSZTYNSKIE ZALADY OPON SAMOCHODOWYCH</td> <td>B5</td> <td>OLSZTYN</td> <td>
</td> <td>POLAND</td> </tr> <tr> <td>MICHELIN NORTH AMERICA, INC.</td> <td>B6</td> <td>SPARTANBURG</td> <td>SOUTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>MICHELIN NORTH AMERICA, INC.</td> <td>B7</td> <td>DOTHAN</td> <td>ALABAMA</td> <td>UNITED STATES</td> </tr> <tr> <td>CIA BRASAILIERA DE PNEUMATICOS</td> <td>B8</td> <td>RIO DE JANEIRO</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>MICHELIN NORTH AMERICA, INC.</td> <td>B9</td> <td>LEXINGTON</td> <td>SOUTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE MANUFACTURING</td> <td>BA</td> <td>AKRON</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>CHONGQING HANKOOK TIRE CO., LTD.</td> <td>BB</td> <td>CHONGQING CITY</td> <td>OKLAHOMA CHONGQING</td> <td>CHINA</td> </tr> <tr> <td>PT HANKOOK TIRE INDONESIA</td> <td>BC</td> <td>LIPPO CIKARANG</td> <td>BEKASI</td> <td>INDONESIA</td> </tr> <tr> <td>B.F. GOODRICH TIRE COMPANY</td> <td>BD</td> <td>MIAMI</td> <td>OKLAHOMA</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE MANUFACTURING</td> <td>BE</td> <td>TUSCALOOSA</td> <td>ALABAMA</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE MANUFACTURING</td> <td>BF</td> <td>WOODBURN</td> <td>INDIANA</td> <td>UNITED STATES</td> </tr> <tr> <td>UNIROYAL GOODRICH TIRE MANUFACTURING</td> <td>BH</td> <td>KITCHENER</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>JIANGSU HANTA TIRE RADIAL PLANT</td> <td>BJ</td> <td>HUAIYIN</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>ANSHAN TYRE FACTORY</td> <td>BK</td> <td>ANSHAN CITY</td> <td>LIAONING PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>CORPORATION FIANCIARA DEL VALLE S.A.</td> <td>BL</td> <td>CALI</td> <td>
</td> <td>COLOMBIA</td> </tr> <tr> <td>B.F. GOODRICH AUSTRALIA PTY., LTD.</td> <td>BM</td> <td>CAMPBELLIFIELD</td> <td>VICTORIA</td> <td>AUSTRAILIA</td> </tr> <tr> <td>B.F. GOODRICH PHILLIPPINES, INC.</td> <td>BN</td> <td>MAKTI</td> <td>RIZAL</td> <td>PHILIPPINES</td> </tr> <tr> <td>GENERAL TIRE & RUBBER CO. OF MOROCCO</td> <td>BO</td> <td>CASABLANCA – 02</td> <td>
</td> <td>MOROCCO</td> </tr> <tr> <td>SHANDONG YINBAO TYRE GROUP</td> <td>BP</td> <td>SHOUGAUNG CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SDF RUBBER CO., LTD.</td> <td>BR</td> <td>PUDONG</td> <td>SHANGHAI</td> <td>CHINA</td> </tr> <tr> <td>SEMPERIT, A.G.</td> <td>BT</td> <td>
</td> <td>
</td> <td>AUSTRAILIA</td> </tr> <tr> <td>SEMPERIT IRELAND LTD.</td> <td>BU</td> <td>BALLYFERMONT</td> <td>DUBLIN</td> <td>IRELAND</td> </tr> <tr> <td>INTERNATIONAL RUBBER INDUSTRIES</td> <td>BV</td> <td>JEFFERSONTOWN</td> <td>KENTUCKY</td> <td>UNITED STATES</td> </tr> <tr> <td>GATES RUBBER COMPANY</td> <td>BW</td> <td>DENVER</td> <td>COLORADO</td> <td>UNITED STATES</td> </tr> <tr> <td>GATES RUBBER COMAPNY</td> <td>BX</td> <td>NASHVILLE</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>GATES RUBBER COMPANY</td> <td>BY</td> <td>LITTLETON</td> <td>COLORADO</td> <td>UNITED STATES</td> </tr> <tr> <td>KUMHO TIRE TIANJIN CO., INC.</td> <td>C0</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>MICHELIN (NIGERIA) LTD.</td> <td>C1</td> <td>PORT-HARCOURT</td> <td>
</td> <td>NIGERIA</td> </tr> <tr> <td>SHANDONG BAYI SAILUN TYRE MANUFACTURE CO. LTD.</td> <td>C2</td> <td>ZAOZHUANG CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>MCCREARY TIRE & RUBBER COMPANY</td> <td>C3</td> <td>BALTIMORE</td> <td>MARYLAND</td> <td>UNITED STATES</td> </tr> <tr> <td>CARLISLE TIRE & WHEEL CO.</td> <td>C4</td> <td>CLINTON</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>POZNANSKIE ZAKLADY OPON SAMOCHODOWYCH</td> <td>C5</td> <td>POZNAN</td> <td>
</td> <td>POLAND</td> </tr> <tr> <td>MITAS, A.S.</td> <td>C6</td> <td>PRAHA 10 – SVEHLOVA 1900</td> <td>
</td> <td>CZECH REPUBLIC</td> </tr> <tr> <td>IRONSIDES TIRE & RUBBER CO.</td> <td>C7</td> <td>LOUISVILLE</td> <td>KENTUCKY</td> <td>UNITED STATES</td> </tr> <tr> <td>BRIDGESTONE TAIWAN CO., LTD.</td> <td>C8</td> <td>
</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>SEVEN STAR RUBBER COMPANY, LTD.</td> <td>C9</td> <td>PIN-TOU HSIAND CHANG</td> <td>HUA</td> <td>TAIWAN</td> </tr> <tr> <td>MOHAWK RUBBER COMPANY</td> <td>CA</td> <td>AKRON</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>MOHAWK RUBBER COMPANY</td> <td>CB</td> <td>HELENA</td> <td>ARKANSAS</td> <td>UNITED STATES</td> </tr> <tr> <td>YOKOHAMA TIRE CORPORATION</td> <td>CC</td> <td>SALEM</td> <td>VIRGINIA</td> <td>UNITED STATES</td> </tr> <tr> <td>ALLIANCE TIRE & RUBBER COMPANY, LTD.</td> <td>CD</td> <td>HADERA</td> <td>
</td> <td>ISRAEL</td> </tr> <tr> <td>PIRELLI GERMANY A.G.</td> <td>CE</td> <td>HOECHST/ODENWALD</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>TITAN TIRE CORPORATION</td> <td>CF</td> <td>DES MOINES</td> <td>IOWA</td> <td>UNITED STATES</td> </tr> <tr> <td>PIRELLI ARMSTRONG TIRE CORPORATION</td> <td>CH</td> <td>HANFORD</td> <td>CALIFORNIA</td> <td>UNITED STATES</td> </tr> <tr> <td>INOUE RUBBER CO., LTD.</td> <td>CJ</td> <td>IBI-GUN, GIFU-PREF.</td> <td>
</td> <td>JAPAN</td> </tr> <tr> <td>PIRELLI ARMSTRONG TIRE CORPORATION</td> <td>CK</td> <td>MADISON</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>INOUE RUBBER VIETNAM CO., LTD.</td> <td>CL</td> <td>ME LINH DISTRICT</td> <td>VINH PHUC</td> <td>VIETNAM</td> </tr> <tr> <td>TOYO TYRE MANUFACTURERING (MALAYSIA) SDN BHD</td> <td>CM</td> <td>TAIPING</td> <td>PERAK</td> <td>MALAYSIA</td> </tr> <tr> <td>CONTINENTAL FRANCE S.N.C.</td> <td>CN</td> <td>SARREGUEMINES CEDEX</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>GOODYEAR LASTIKLERI TAS</td> <td>CO</td> <td>ADOPOZARI</td> <td>
</td> <td>TURKEY</td> </tr> <tr> <td>CONTINENTAL AG WERK KORBACH</td> <td>CP</td> <td>KORBACH</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>GUANGMING TYRE GROUP CO.</td> <td>CR</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL GUMMI-WERKE, A.C.</td> <td>CT</td> <td>DANNENBERG</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>CONTINENTAL AG WERK STOECKEN</td> <td>CU</td> <td>
</td> <td>HANNOVER</td> <td>GERMANY</td> </tr> <tr> <td>ARMSTRONG RUBBER COMPANY</td> <td>CV</td> <td>NATCHEZ</td> <td>MS</td> <td>UNITED STATES</td> </tr> <tr> <td>TOYO TIRE & RUBBER CO, LTD.</td> <td>CW</td> <td>ITAMI</td> <td>HYOGO</td> <td>JAPAN</td> </tr> <tr> <td>TOYO TIRE & RUBBER CO, LTD.</td> <td>CX</td> <td>NATORI-GU</td> <td>MIYAGI</td> <td>JAPAN</td> </tr> <tr> <td>MCCREARY TIRE & RUBBER COMPANY</td> <td>CY</td> <td>INDIANA</td> <td>PENNSYLVANIA</td> <td>UNITED STATES</td> </tr> <tr> <td>KUMHO TIRE (CHANGCHUN ) CO., INC.</td> <td>D0</td> <td>CHANGCHUN</td> <td>JILIN</td> <td>CHINA</td> </tr> <tr> <td>VIKING ASKIM</td> <td>D1</td> <td>ASKIM</td> <td>
</td> <td>NORWAY</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>D2</td> <td>LAVERGNE</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>UNITED TIRE & RUBBER MANUFACTURING COMPANY</td> <td>D3</td> <td>COBOURG</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>DUNLOP INDIA, LTD.</td> <td>D4</td> <td>WEST BENGAL</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>DUNLOP INDIA, LTD.</td> <td>D5</td> <td>AMBATTUR</td> <td>MADRAS</td> <td>INDIA</td> </tr> <tr> <td>FUJIAN HAIAN RUBBER CO. LTD.</td> <td>D6</td> <td>PUTIAN CITY</td> <td>FUJIAN</td> <td>CHINA</td> </tr> <tr> <td>APOLLO TYRES SOUTH AFRICA (PTY) LTD.</td> <td>D7</td> <td>LADYSMITH</td> <td>NATAL</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>APOLLO TYRES SOUTH AFRICA (PTY) LTD.</td> <td>D8</td> <td>DURBAN</td> <td>NATAL</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>UNITED TIRE & RUBBER COMPANY, LTD.</td> <td>D9</td> <td>ETOBICOKE</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>DUNLOP TIRE CORPORATION</td> <td>DA</td> <td>BUFFALO</td> <td>NEW YORK</td> <td>UNITED STATES</td> </tr> <tr> <td>XINJIANG KUNLUN TYRE CO., LTD</td> <td>DB</td> <td>URUMQI CITY</td> <td>XINJIANG WEIWUER AUTONOMO</td> <td>CHINA</td> </tr> <tr> <td>DUNLOP TIRE CANADA, LTD.</td> <td>DC</td> <td>WHITBY</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>SP TYRES UK LTD.</td> <td>DD</td> <td>BIRMINGHAM</td> <td>
</td> <td>ENGLAND</td> </tr> <tr> <td>JIANGSU ROC TYRES CO., LTD.</td> <td>DE</td> <td>XUZHOU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO NEWHAWK TIRES CO., LTD.</td> <td>DF</td> <td>JIMO QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE (SHENYANG) TIRE CO LTD</td> <td>DH</td> <td>SHENYANG</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO ANLI RUBBER CO., LTD.</td> <td>DJ</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DUNLOP FRANCE S.A.</td> <td>DK</td> <td>MONTLUCON CEDEX</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>DUNLOP FRANCE S.A.</td> <td>DL</td> <td>AMIENS CEDEX</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>DUNLOP GMBH</td> <td>DM</td> <td>HANAU AM MAIN</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>DUNLOP GMBH</td> <td>DN</td> <td>JUSTUS VON</td> <td>LIEBIGSTRASSE</td> <td>GERMANY</td> </tr> <tr> <td>MATADOR-OMSKSHINA</td> <td>DP</td> <td>OMSK</td> <td>OMSK</td> <td>RUSSIA</td> </tr> <tr> <td>WEIFANG ANTAI TYRE</td> <td>DR</td> <td>CHANGLE COUNTY, WEIFANG,</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO FUYUAN TYRE CO., LTD.</td> <td>DT</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GITI TIRE (YIN CHUAN-GREATWALL) TYRE COMPANY, LTD.</td> <td>DU</td> <td>YINCHUAN</td> <td>NINGXIA HUI</td> <td>CHINA</td> </tr> <tr> <td>N.V. VEDERLANDSCH-AMERIKAANSCHE</td> <td>DV</td> <td>ENSCHNEDE</td> <td>
</td> <td>NETHERLANDS</td> </tr> <tr> <td>RUBBERFABRIEK VREDESTEIN</td> <td>DW</td> <td>DOETINCHEM</td> <td>
</td> <td>NETHERLANDS</td> </tr> <tr> <td>N.V. BATAAFSCHE RUBBER INDUSTRIE RADIUM</td> <td>DX</td> <td>MAASTRICHT</td> <td>
</td> <td>NETHERLANDS</td> </tr> <tr> <td>DENMAN TIRE CORPORATION</td> <td>DY</td> <td>LEAVITTSBURG</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>CHONGGING HENSION GROUP</td> <td>E0</td> <td>JIULONGPO DISTRICT, CHONGQING</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>CHUNG HSING INDUSTRIAL CO., LTD</td> <td>E1</td> <td>TAIPEI</td> <td>TAICHUNG HSIEN</td> <td>TAIWAN</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE DO BRAZIL INDUSTRIAL E COMERCIO LTDA.</td> <td>E2</td> <td>SANTO ANDRE-EST</td> <td>SAO PAULO</td> <td>BRAZIL</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC</td> <td>E3</td> <td>LEVERGNE</td> <td>TN</td> <td>UNITED STATES</td> </tr> <tr> <td>HEBEI XIEMEI RUBBER PRODUCTS CO., LTD.</td> <td>E4</td> <td>PINGXIANG</td> <td>HEBEI</td> <td>CHINA</td> </tr> <tr> <td>FIRESTONE SOUTH AFRICA (PTY) LTD.</td> <td>E5</td> <td>PORT ELIZABETH</td> <td>
</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>OTANI RADIAL TIRE CO., LTD.</td> <td>E6</td> <td>BANGKAEW NAKORNCHAISRI</td> <td>NAKORNPATHORN</td> <td>THAILAND</td> </tr> <tr> <td>SAMEER AFRICA</td> <td>E7</td> <td>NAIROBI</td> <td>
</td> <td>KENYA</td> </tr> <tr> <td>SERVICE INDUSTRIES LIMITED</td> <td>E8</td> <td>GUJRAT</td> <td>PUNJAB N</td> <td>PAKISTA</td> </tr> <tr> <td>FIRESTONE SOUTH AFRICA (PTY) LTD.</td> <td>E9</td> <td>BRITS</td> <td>
</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>METZLER, A.G.</td> <td>EA</td> <td>8 MUNCHEN 2</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>PIRELLI GERMANY A.G.</td> <td>EB</td> <td>BREUBERG</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>PIRELLI GERMANY A.G.</td> <td>EC</td> <td>BREUBERG</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>MICHELIN – OKAMOTO TIRE CORPORATION</td> <td>ED</td> <td>BUNKYO-KU</td> <td>TOKYO</td> <td>JAPAN</td> </tr> <tr> <td>NITTO TIRE COMPANY, LTD.</td> <td>EE</td> <td>SAMUKAWA-MACHI</td> <td>KANAGAWA-KEN</td> <td>JAPAN</td> </tr> <tr> <td>HUGH AH TIRE COMPANY, LTD.</td> <td>EF</td> <td>CHUNG-KU</td> <td>SEOUL</td> <td>KOREA</td> </tr> <tr> <td>BRIDGESTONE KURUME PLANT</td> <td>EH</td> <td>KURUME</td> <td>FUKUOKA 830</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE TOSU PLANT</td> <td>EJ</td> <td>TOSU</td> <td>SAGA 841</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE AMAGI PLANT</td> <td>EK</td> <td>AMAGI</td> <td>FUKUOKA 838</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE HIKONE PLANT</td> <td>EL</td> <td>HIKONE</td> <td>SHIGA 522-02</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE TOKYO PLANT</td> <td>EM</td> <td>KODAIRA, TOKYO</td> <td>JAPAN</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE NASU PLANT</td> <td>EN</td> <td>KUROISO</td> <td>TOCHIGI 325</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE TOCHIGI PLANT</td> <td>EP</td> <td>KUROISO</td> <td>TOCHIGI 329-31</td> <td>JAPAN</td> </tr> <tr> <td>QINGDAO DOUBLESTAR TYRE INDUSTRY CO., LTD.</td> <td>ER</td> <td>JIAONAN, QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SUMITOMO RUBBER INDUSTRIES, LTD.</td> <td>ET</td> <td>CHUO-KO</td> <td>KOBE</td> <td>JAPAN</td> </tr> <tr> <td>SUMITOMO RUBBER INDUSTRIES, LTD.</td> <td>EU</td> <td>TOYOTA</td> <td>AICHI PREFECTURE</td> <td>JAPAN</td> </tr> <tr> <td>QINGDAO YELLOWSEA RUBBER CO., LTD.</td> <td>EV</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>PNEUMATIQUES KLEBER, S.A.</td> <td>EW</td> <td>TOUL (MEURTHE-ET-MOSELLE)</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>PNEUMATIQUES KLEBER, S.A.</td> <td>EX</td> <td>LA CHAPELLE ST LUC</td> <td>AUBE</td> <td>FRANCE</td> </tr> <tr> <td>PNEUMATIQUES KLEBER, S.A.</td> <td>EY</td> <td>SAAR</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>FIDELITY TIRE MANFACTURING CO</td> <td>F0</td> <td>NATCHEZ</td> <td>MISSISSIPPI</td> <td>UNITED STATES</td> </tr> <tr> <td>MICHELIN TYRE COMPANY, LTD.</td> <td>F1</td> <td>DUNDEE</td> <td>
</td> <td>SCOTLAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE VENEZOLANA, C.A.</td> <td>F2</td> <td>VALENCIA</td> <td>ESTADO CARABOBO</td> <td>VENEZUELA</td> </tr> <tr> <td>MANFACTURE FRANCAISE PNEUMATIQUES</td> <td>F3</td> <td>ROANNE</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>CNB-COMPANHIA NACIONAL DE BORRACHAS</td> <td>F4</td> <td>39-1 OPORTO</td> <td>
</td> <td>PORTUGAL</td> </tr> <tr> <td>FATE S.A.I.C.I.</td> <td>F5</td> <td>BUENOS AIRES</td> <td>
</td> <td>ARGENTINA</td> </tr> <tr> <td>TORRELAVEGA FIRESTONE HISPANIA S.A.</td> <td>F6</td> <td>TORRELAVEGA</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>FIRESTONE HISPANIA S.A. PUENTE SAN MIGUEL</td> <td>F7</td> <td>PUENTE SAN MIGUEL</td> <td>TORRELAVEGA</td> <td>SPAIN</td> </tr> <tr> <td>VIKRANT TYRES LIMITED</td> <td>F8</td> <td>MYSORE</td> <td>KARNATAKA</td> <td>INDIA</td> </tr> <tr> <td>DUNLOP NEW ZEALAND, LTD.</td> <td>F9</td> <td>UPPER HUTT</td> <td>
</td> <td>NEW ZEALAND</td> </tr> <tr> <td>YOKOHAMA RUBBER COMPANY, LTD.</td> <td>FA</td> <td>HIRATSUKA</td> <td>KANAGAWA-PERF</td> <td>JAPAN</td> </tr> <tr> <td>YOKOHAMA RUBBER COMPANY, LTD.</td> <td>FB</td> <td>WATERI-GUN</td> <td>MIYE-PREF</td> <td>JAPAN</td> </tr> <tr> <td>YOKOHAMA RUBBER COMPANY, LTD.</td> <td>FC</td> <td>
</td> <td>
</td> <td>JAPAN</td> </tr> <tr> <td>YOKOHAMA RUBBER CO., LTD</td> <td>FD</td> <td>
</td> <td>
</td> <td>JAPAN</td> </tr> <tr> <td>KUMHO TIRE(CHANGCHUN) CO., INC.</td> <td>FE</td> <td>CHANGCHUN</td> <td>JILIN PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>MANUFACUTRE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FF</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>LONGKOU XINGLONG TYRE CO., LTD.</td> <td>FG</td> <td>LONGKOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FH</td> <td>CLEMONT FERRAND</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FJ</td> <td>BOURGES</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FK</td> <td>CHOLET</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FL</td> <td>45-MESMIN ORLEANS</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FM</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>FN</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>STE. D’APPLICATIONS TECHNIQUES</td> <td>FP</td> <td>ALGIERS</td> <td>
</td> <td>ALGERIA</td> </tr> <tr> <td>COAXIAN GUIDESTONE TYRE CO., LTD.</td> <td>FR</td> <td>CAOXIAN, SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>JINZHOU XIN XING RUBBER PRODUCTION CO., LTD.</td> <td>FS</td> <td>INVESTMENT BUREAU</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>MICHELIN REIFENWERKE, A.G.</td> <td>FT</td> <td>BAD KREUZNACH</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>MICHELIN REIFENWERKE, A.G.</td> <td>FU</td> <td>BAMBERG</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>MICHELIN REIFENWERKE, A.G.</td> <td>FV</td> <td>HOMBURG</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>MICHELIN REIFENWERKE, A.G.</td> <td>FW</td> <td>KARLSRUHE</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>S.A. BELGE DU PNEUMATIQUE MICHELIN</td> <td>FX</td> <td>LEEUW-ST. PIERRE</td> <td>ZUEN</td> <td>BELGIUM</td> </tr> <tr> <td>N.V. NEDERLANDSCHE BANDEN</td> <td>FY</td> <td>S’HERTOGENBOSCH</td> <td>BOIS-LE-DUC</td> <td>HOLLAND</td> </tr> <tr> <td>GENERAL TYRE & RUBBER COMPANY</td> <td>H0</td> <td>KARACHI</td> <td>
</td> <td>PAKISTAN</td> </tr> <tr> <td>DELA S.A.F.E. NEUMATICOS MICHELIN</td> <td>H1</td> <td>VALLADOLID</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>KUMHO TIRE CO., INC.</td> <td>H2</td> <td>GWANGSAN-GU</td> <td>GWANGJU</td> <td>KOREA</td> </tr> <tr> <td>SAVATECH D.O.O.</td> <td>H3</td> <td>KRANJ</td> <td>
</td> <td>SLOVENIA</td> </tr> <tr> <td>BRIDGESTONE HOFU PLANT</td> <td>H4</td> <td>HOFU</td> <td>YAMAGUCHI 747</td> <td>JAPAN</td> </tr> <tr> <td>HUTCHINSON-MAPA</td> <td>H5</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>SHIN HUNG RUBBER COMPANY, LTD.</td> <td>H6</td> <td>JINJU</td> <td>KYUNG NAM</td> <td>KOREA</td> </tr> <tr> <td>LI HSIN RUBBER INDUSTRIAL CO.</td> <td>H7</td> <td>CHI-HU</td> <td>CHANG-HWA</td> <td>TAIWAN</td> </tr> <tr> <td>HSING KWO RUBBER MFG., CO., LTD.</td> <td>H8</td> <td>TSZTUNG SHIANG TAIWAN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>REIFEN-BERG</td> <td>H9</td> <td>CLEVISCHER RING</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>S.A.F.E.N.M. (MICHELIN)</td> <td>HA</td> <td>ARANDA</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>FABRICA DE LASARTE</td> <td>HB</td> <td>LASARTE-ORIA</td> <td>GUIPUZCOA</td> <td>SPAIN</td> </tr> <tr> <td>S.A.F.E.N.M. (MICHELIN)</td> <td>HC</td> <td>VITORIA</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>SOCIETA PER AZONI, MICHELIN ITALIANA</td> <td>HD</td> <td>CUNEO</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>SOCIETA PER AZONI, S.P.A. (MICHELIN ITALIANA)</td> <td>HE</td> <td>MARENGO</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>SOCIETA PER AZONI (MICHELIN ITALIANA)</td> <td>HF</td> <td>TURIN</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>CHINA SHENMA GROUP RUBBER TYRE CO., LTD.</td> <td>HG</td> <td>PINGDINGSHAN CITY</td> <td>HENAN PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>SOCIETA PER AZONI (MICHELIN ITALIANA)</td> <td>HH</td> <td>TURIN</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>MICHELIN TYRE COMPANY, LTD.</td> <td>HJ</td> <td>BALLYMENA</td> <td>
</td> <td>IRELAND</td> </tr> <tr> <td>MICHELIN TYRE COMPANY, LTD.</td> <td>HK</td> <td>BURNLEY(LANE)</td> <td>
</td> <td>ENGLAND</td> </tr> <tr> <td>MICHELIN TYRE COMPANY, LTD.</td> <td>HL</td> <td>BURNLEY</td> <td>
</td> <td>ENGLAND</td> </tr> <tr> <td>MICHELIN TYRE COMPANY, LTD.</td> <td>HM</td> <td>STOKE-ON-TRENT</td> <td>
</td> <td>ENGLAND</td> </tr> <tr> <td>MICHELIN NORTH AMERICA (CANADA), INC.</td> <td>HN</td> <td>NEW GLASGOW</td> <td>NOVA SCOTIA</td> <td>CANADA</td> </tr> <tr> <td>MANFACTURE SAIGONNAISE DES PNEUMATIQUES MICHELIN</td> <td>HP</td> <td>SAIGON</td> <td>
</td> <td>SOUTH VIETNAM</td> </tr> <tr> <td>QINGDAO TAIFA GROUP, LTD.</td> <td>HR</td> <td>QINGDAO</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>CEAT, S.P.A. PNEUMATICI VIA LEONCAVALLO</td> <td>HT</td> <td>TORINO</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>CEAT 10036</td> <td>HU</td> <td>SETTIMO TORINESE</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>GENTYRE S.P.A.</td> <td>HV</td> <td>
</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>BARUM CONTINENTAL</td> <td>HW</td> <td>OTROKOVICE</td> <td>
</td> <td>CZECH REPUBLIC</td> </tr> <tr> <td>DOUBLE COIN GROUP (ANHUI) WARIOR TIRE CO., LTD.</td> <td>HX</td> <td>ANHUI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN</td> <td>HY</td> <td>OKLAHOMA CITY</td> <td>OKLAHOMA</td> <td>
</td> </tr> <tr> <td>KOREA INOCEE KASEI CO., LTD.</td> <td>J0</td> <td>MASAN</td> <td>
</td> <td>KOREA</td> </tr> <tr> <td>PHILLIPS PETROLEUM COMPANY</td> <td>J1</td> <td>BARTLESVILLE</td> <td>OKLAHOMA</td> <td>UNITED STATES</td> </tr> <tr> <td>SHANDONG HAOLONG RUBBER TYRE CO., LTD.</td> <td>J2</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MATADOR RUBBER S.R.O.</td> <td>J3</td> <td>PUCHOV</td> <td>
</td> <td>SLOVAKIA</td> </tr> <tr> <td>RUBENA, N.P.</td> <td>J4</td> <td>547 36 NACHOD</td> <td>
</td> <td>CZECH REPUBLIC</td> </tr> <tr> <td>Q TIRES, INC.</td> <td>J5</td> <td>GREENVILLE</td> <td>SOUTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>JAROSLAVI TIRE CO.</td> <td>J6</td> <td>JAROSLAVI, CZECH REPUBLIC</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>HOOSIER TIRE & RUBBER CORP.</td> <td>J7</td> <td>LAKEVILLE</td> <td>IN</td> <td>UNITED STATES</td> </tr> <tr> <td>DA CHUNG HUA RUBBER INDUSTRIAL CO</td> <td>J8</td> <td>SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>P.T. INTIRUB</td> <td>J9</td> <td>BESAR</td> <td>JAKARTA</td> <td>INDONESIA</td> </tr> <tr> <td>LIAONING PERMANENT TYRE CO., LTD.</td> <td>JA</td> <td>CHAOYANG CITY</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG ZHENGXING TYRES CO., LTD.</td> <td>JB</td> <td>LINYI</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QRT</td> <td>JC</td> <td>QING DAO</td> <td>SHAN DONG</td> <td>CHINA</td> </tr> <tr> <td>PT SURYARAYA RUBBERINDO INDUSTRIES</td> <td>JD</td> <td>BOGOR</td> <td>WEST JAVA</td> <td>INDONESIA</td> </tr> <tr> <td>SHANDONG YONGSHENG RUBBER CO., LTD.</td> <td>JE</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MILLER TIRE</td> <td>JF</td> <td>ADAIRSVILLE</td> <td>GA</td> <td>UNITED STATES</td> </tr> <tr> <td>JILIN PROVINCE CHUNWEI TYRE CO., LTD.</td> <td>JG</td> <td>GONGZHULING</td> <td>JILIN PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG SHUANWANG RUBBER CO., LTD.</td> <td>JH</td> <td>DONGYING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>NEXEN TIRE CORPORATION</td> <td>JJ</td> <td>LAIXISHI</td> <td>QUINGDAO</td> <td>CHINA</td> </tr> <tr> <td>TOVIC TIRE CO., LTD.</td> <td>JK</td> <td>CHANGWON-CITY</td> <td>
</td> <td>KOREA</td> </tr> <tr> <td>SHANDONG BAYI SAILAN TYRE MANUFACTURER CO., LTD.</td> <td>JL</td> <td>ZAO ZHUANG CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>SUZHOU PLANT</td> <td>JM</td> <td>SUZHOU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>DONGYING FANGXING RUBBER CO., LTD.</td> <td>JN</td> <td>DONGYING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>ANHUL PRIMWELL RUBBER & PLASTICS CO., LTD.</td> <td>JP</td> <td>HEFEI E & T DEVELOPMENT ZONE</td> <td>ANHUI</td> <td>CHINA</td> </tr> <tr> <td>PIRELLI</td> <td>JR</td> <td>ROME</td> <td>GA</td> <td>UNITED STATES</td> </tr> <tr> <td>K.R.M. TYRES</td> <td>JT</td> <td>BADDI</td> <td>H.P.</td> <td>INDIA</td> </tr> <tr> <td>HANGZHOU ZHONGCE RUBBER CO., LTD.</td> <td>JU</td> <td>HANGZHOU</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>FULLRUN TYRE TECH CORP., LTD.</td> <td>JV</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>AMTEL VORONEZH</td> <td>JW</td> <td>VORONEZH</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>DONGYING XINJINSHAN RUBBER CO., LTD.</td> <td>JX</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE STARGARD</td> <td>JY</td> <td>STARGARD SZCZECINSKI</td> <td>
</td> <td>POLAND</td> </tr> <tr> <td>MICHELIN KOREA TIRE COMPANY, LTD.</td> <td>K0</td> <td>YANG SAN- KUN</td> <td>KYUNGSANGNAM, DO</td> <td>KOREA</td> </tr> <tr> <td>PHILLIPS PETROLEUM COMPANY</td> <td>K1</td> <td>STOW</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>KUMHO TIRE (VIETNAM) CO. LTD.</td> <td>K2</td> <td>BINH DUONG PROVINCE</td> <td>
</td> <td>VIETNAM</td> </tr> <tr> <td>KENDA RUBBER INDUSTRIAL CO., LTD.</td> <td>K3</td> <td>YULIN</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>INDUSTRIAS MICHELIN, S.A. de C.V.</td> <td>K4</td> <td>BENITO JUAREZ C.P. SANTIAGO</td> <td>QUERETARO</td> <td>MEXICO</td> </tr> <tr> <td>VEB REIFENKOMBINAT FURSTENWALDE</td> <td>K5</td> <td>
</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>QINGZHOU HUA HAN RUBBER CO. LTD.</td> <td>K6</td> <td>QINZHOU CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>FOSHAN SHUNDE TIAN DI RUBBER CO., LTD.</td> <td>K7</td> <td>FOSHAN</td> <td>GUANG DONG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG ZHENGFANG TYRE CO., LTD.</td> <td>K8</td> <td>TAIAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TECH RUBBER C0., LTD.</td> <td>K9</td> <td>SHETOU, CHANGHUA</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>SVIZZ-ONE CORPORATION LIMITED</td> <td>KA</td> <td>BANGLANE</td> <td>NAKOMPATHOM</td> <td>THAILAND</td> </tr> <tr> <td>ZHAOQING JUNHONG CO., LTD.</td> <td>KB</td> <td>ZHAOQING</td> <td>(PROVINCE) GUANGDONG</td> <td>CHINA</td> </tr> <tr> <td>ROSAVA</td> <td>KC</td> <td>BELAYA TSERKOV</td> <td>KIEV REGION</td> <td>UKRAINE</td> </tr> <tr> <td>VALSA</td> <td>KD</td> <td>BELAYA TSERKOV</td> <td>KIEV REGION</td> <td>UKRAINE</td> </tr> <tr> <td>SHANDONG JINYU INDUSTRIAL CO. LTD.</td> <td>KE</td> <td>DONGYIN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG LINGLONG TYRE CO., LTD.</td> <td>KF</td> <td>ZHAOYUAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG SANGONG RUBBER CO., LTD.</td> <td>KH</td> <td>SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG PROVINCE SANLI TIRE MANUFACTURED CO., LTD.</td> <td>KJ</td> <td>CAOXIAN</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DALIAN TYRE FACTORY CO., LTD.</td> <td>KK</td> <td>DALIAN</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>ANLAS ANADOLU LASTIK SANAYI VE TICARET A.S.</td> <td>KL</td> <td>ULUS</td> <td>ISTANBUL</td> <td>TURKEY</td> </tr> <tr> <td>LEE TIRE & RUBBER CO.(GOODYEAR S.A. COLMAR-BERG)</td> <td>KM</td> <td>
</td> <td>
</td> <td>GRAND DUCHY OF LUXEMBOURG</td> </tr> <tr> <td>HANGZHOU CHAOYANG RUBBER CO., LTD.</td> <td>KN</td> <td>HANGZHOU</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG ZHUSHENGHUA RUBBER CO., LTD.</td> <td>KP</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>WUXI DOUBLE FLYING</td> <td>KR</td> <td>WUXI</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>AUTOMOBILE TYRE AND TUBE</td> <td>KT</td> <td>DANANG</td> <td>
</td> <td>VIETNAM</td> </tr> <tr> <td>WEIFANG DAWANG RUBBER PRODUCTS CO., LTD.</td> <td>KU</td> <td>CHANGYI</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>NANJING TIRE CO., LTD. TBR</td> <td>KV</td> <td>NANJING</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>SHENGTAI GROUP CO., LTD.</td> <td>KW</td> <td>DONGYING</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>NEW DONG YUE GROUP CO., LTD.</td> <td>KX</td> <td>DONGPING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DONGYING TIANTONG RUBBER & PLASTIC CO., LTD.</td> <td>KY</td> <td>DONGYING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN</td> <td>L0</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>GOODYEAR TAIWAN LTD.</td> <td>L1</td> <td>TAIPEI</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>WOOSUNG TIRE CORP. -YANGSAN PLANT</td> <td>L2</td> <td>YANSAN-KUN, KYUNGSANGNAM-DO</td> <td>
</td> <td>SOUTH KOREA</td> </tr> <tr> <td>TONG SHIN CHEMICAL PRODUCTS LTD.</td> <td>L3</td> <td>SEOUL</td> <td>
</td> <td>KOREA</td> </tr> <tr> <td>S.C. DANUBIANA S.A.</td> <td>L4</td> <td>COMUNA POPESTI LEORDENI</td> <td>SOS. OLTENI EI NR.181</td> <td>ROMANIA</td> </tr> <tr> <td>BRISA BRIDGESTONE SABANCI</td> <td>L5</td> <td>IZMIT</td> <td>ALIKAHYA</td> <td>TURKEY</td> </tr> <tr> <td>CONTINENTAL INDIA LIMITED</td> <td>L6</td> <td>MEERUT UP</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>SC SILVANIA SA</td> <td>L7</td> <td>ZALAU</td> <td>SALAJ COUNTY</td> <td>ROMANIA</td> </tr> <tr> <td>DUNLOP ZIMBABWE LTD.</td> <td>L8</td> <td>BOMINGTON</td> <td>BULAWAYE</td> <td>ZIMBABWE</td> </tr> <tr> <td>PANTHER TYRES, LTD.</td> <td>L9</td> <td>AINTEE</td> <td>LIVERPOOL</td> <td>UNITED KINGDOM</td> </tr> <tr> <td>WUXI YUANGFANG RUBBER ENGINEERING CO. LTD.</td> <td>LA</td> <td>WUXI</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG FENGYUAN TIRE MANUFACTURING CO., LTD</td> <td>LB</td> <td>ZAOZHUANG CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CASUMINA</td> <td>LC</td> <td>HO CHI MINH</td> <td>
</td> <td>VIETNAM</td> </tr> <tr> <td>ZHEJIANG WANXIN RUBBER CO., LTD.</td> <td>LD</td> <td>XIANJU</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG LUTONG RUBBER CO., LTD.</td> <td>LE</td> <td>WEIFANG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL AKTIENGESELLSCHAFT</td> <td>LF</td> <td>VAHRENWALDER STRASSE 9</td> <td>HANNOVER</td> <td>GERMANY</td> </tr> <tr> <td>SPEEDWAYS RUBBER COMPANY</td> <td>LH</td> <td>JALANDHAR</td> <td>PUNJAB</td> <td>INDIA</td> </tr> <tr> <td>PNEU UNIROYAL ENGLEBERT S.A.</td> <td>LJ</td> <td>B-4040 HERSTAL</td> <td>
</td> <td>BELGIUM</td> </tr> <tr> <td>PRODUCTORS NIACIONAL DE LLANTAS S.A.</td> <td>LK</td> <td>CALI</td> <td>
</td> <td>COLOMBIA</td> </tr> <tr> <td>SICUP S.N.C. USINE UNIROYAL</td> <td>LL</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>CONTINENTAL AG WERK AACHEN</td> <td>LM</td> <td>AACHEN</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>UNIROYAL S.A. DE C.V.</td> <td>LN</td> <td>
</td> <td>MEXICO, D.F.</td> <td>MEXICO</td> </tr> <tr> <td>UNIROYAL ENGLENERT TYRES LTD.</td> <td>LP</td> <td>NEWBRIDGE</td> <td>
</td> <td>GREAT BRITAIN</td> </tr> <tr> <td>TVS SRICHAKRA LTD.</td> <td>LR</td> <td>MELUR TALUK MADURAI</td> <td>TAMIL NADU</td> <td>INDIA</td> </tr> <tr> <td>UNIROYAL ENDUSTRI TURK ANONIM SIRKETI</td> <td>LT</td> <td>ADAPAZARI</td> <td>
</td> <td>TURKEY</td> </tr> <tr> <td>UNIROYAL, C.A.</td> <td>LU</td> <td>VALENCIA</td> <td>
</td> <td>VENEZUELA</td> </tr> <tr> <td>GENERAL TIRE CANADA, LTD.</td> <td>LV</td> <td>BARRIE</td> <td>ONTARIO</td> <td>CANADA</td> </tr> <tr> <td>TRELLEBORG UMMIFARIKS AKTIEBOLAG</td> <td>LW</td> <td>TRELLEBORG</td> <td>
</td> <td>SWEDEN</td> </tr> <tr> <td>MITSUBOSHI BELTING LTD.</td> <td>LX</td> <td>NAGATAKU</td> <td>KOBE</td> <td>JAPAN</td> </tr> <tr> <td>MITSUBOSHI BELTING LTD.</td> <td>LY</td> <td>SHIKOKU</td> <td>
</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE CHILIE</td> <td>M0</td> <td>BARRIO INDUSTRIAL</td> <td>COQUIMBO</td> <td>CHILE</td> </tr> <tr> <td>LAOLING VHEAL RUBBER CO., LTD.</td> <td>M1</td> <td>LAOLING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DONGYING HUANTAI RUBBER CO., LTD.</td> <td>M2</td> <td>DONGYING</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>MICHELIN NORTH AMERICA, INC.</td> <td>M3</td> <td>GREENVILLE</td> <td>SOUTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>GCR RETREAD SHOP</td> <td>M4</td> <td>FONTANA</td> <td>CA</td> <td>UNITED STATES</td> </tr> <tr> <td>MICHELIN NORTH AMERICA (CANADA), INC.</td> <td>M5</td> <td>KENTVILLE</td> <td>NOVA SCOTIA</td> <td>CANADA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>M6</td> <td>LAWTON</td> <td>OKLAHOMA</td> <td>UNITED STATES</td> </tr> <tr> <td>GOODYEAR DE CHILE, S.A.I.C.</td> <td>M7</td> <td>SANTIAGO</td> <td>
</td> <td>CHILE</td> </tr> <tr> <td>PREMIER TYRES LTD.</td> <td>M8</td> <td>LALAMASSERY</td> <td>KERALA STATE</td> <td>INDIA</td> </tr> <tr> <td>UNIROYAL TIRE CORPORATION</td> <td>M9</td> <td>MIDDLEBURY</td> <td>CONNETICUT</td> <td>UNITED STATES</td> </tr> <tr> <td>ZHEJIANG BEST RUBBER CO., LTD.</td> <td>MA</td> <td>SHAOXING</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>MB</td> <td>AKRON</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>MC</td> <td>DANVILLE</td> <td>VIRGINIA</td> <td>UNITED STATES</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>MD</td> <td>GADSDEN</td> <td>ALABAMA</td> <td>UNITED STATES</td> </tr> <tr> <td>ZHEJIANG YIZHENG TYRE CO.</td> <td>ME</td> <td>RUIAN</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>DANANG RUBBER JOINT STOCK COMPANY</td> <td>MF</td> <td>DANANG</td> <td>
</td> <td>VIETNAM</td> </tr> <tr> <td>WEIFANG JINGTONG DA TYRE CO., LTD.</td> <td>MH</td> <td>GOOMI CITY</td> <td>SHAN DONG</td> <td>CHINA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>MJ</td> <td>TOPEKA</td> <td>KANSAS</td> <td>UNITED STATES</td> </tr> <tr> <td>QINGDAO TAIHAO TYRE CO., LTD.</td> <td>MK</td> <td>PINGDU CITY</td> <td>QINGDAO</td> <td>CHINA</td> </tr> <tr> <td>PT. BANTENG PRATAMA RUBBER</td> <td>ML</td> <td>CITEURREUP-BOGOR</td> <td>JAWA BARAT</td> <td>INDONESIA</td> </tr> <tr> <td>KENDA TIRE (TIANJIN) CO., LTD.</td> <td>MM</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>DONG NAI RUBBER FACTORY</td> <td>MN</td> <td>
</td> <td>DONG NAI PROVINCE</td> <td>VIETNAM</td> </tr> <tr> <td>BINH LOI RUBBER FACTORY</td> <td>MP</td> <td>HO CHI MINH CITY</td> <td>
</td> <td>VIETNAM</td> </tr> <tr> <td>QINGDAO YELLOWSEA TIRE FACTORY</td> <td>MR</td> <td>QINGDAO, SHANDONG PROVINCE</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SUNTOP TIRE (WUXI) CO., LTD</td> <td>MT</td> <td>WUXI</td> <td>JIANG SU</td> <td>CHINA</td> </tr> <tr> <td>RUAIN JIANDA TYRE MANUFACTURE CO. LTD.</td> <td>MU</td> <td>RUIAN</td> <td>ZHENGJIANG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG WONBON RUBBER CO., LTD</td> <td>MV</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHENYANG PEACE RADIAL TYRE MANUFACTURING CO., LTD.</td> <td>MW</td> <td>SHENYANG</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>COMPANHIA GOODYEAR DO BRAZIL</td> <td>MX</td> <td>SAO PAULO</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>GOODYEAR DE COLOMBIA, S.A.</td> <td>MY</td> <td>CALI</td> <td>
</td> <td>COLOMBIA</td> </tr> <tr> <td>SOUTH PACIFIC TYRES</td> <td>N0</td> <td>WEST FOOTSCRAY</td> <td>VICTORIA</td> <td>AUSTRAILIA</td> </tr> <tr> <td>MALOJA AG. PNEU-UND GUMMIWERKE</td> <td>N1</td> <td>GELTERKINDEN</td> <td>
</td> <td>SWITZERLAND</td> </tr> <tr> <td>HURTUBLSE NETREAD, INCORPORATED</td> <td>N2</td> <td>TONAWANDA</td> <td>NEW YORK</td> <td>UNITED STATES</td> </tr> <tr> <td>TOYO TIRE & RUBBER CO., LTD</td> <td>N3</td> <td>INABE-GUN</td> <td>MIE</td> <td>JAPAN</td> </tr> <tr> <td>SC VICTORIA SA</td> <td>N4</td> <td>FLORESTI</td> <td>PRAHOVA COUNTY</td> <td>ROMANIA</td> </tr> <tr> <td>PNEUMANT</td> <td>N5</td> <td>84 RIESA</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>REIFENWERK HEIDENAU GMBH & CO.</td> <td>N6</td> <td>HAUPTSTRASSE 44</td> <td>HEIDENAU</td> <td>GERMANY</td> </tr> <tr> <td>INTREPRINDEREA DE ANVELOPE CARACAL</td> <td>N7</td> <td>
</td> <td>
</td> <td>ROMANIA</td> </tr> <tr> <td>SHANDONG CASCEN RUBBER IND., LTD.</td> <td>N8</td> <td>ZAOZHUANG CITY</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>PIRELLI PNEUS S.A.</td> <td>N9</td> <td>FEIRA DE SANTANA</td> <td>BAHIA</td> <td>BRAZIL</td> </tr> <tr> <td>SUMITOMO RUBBER DO BRASIL LTDA.</td> <td>NA</td> <td>FAZENDA RIO GRANDE. PARANA</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>GOODYEAR TYRE & RUBBER COMPANY</td> <td>NB</td> <td>WOLVERHAMPTON</td> <td>
</td> <td>ENGLAND</td> </tr> <tr> <td>GOODYEAR FRANCE S.A.</td> <td>NC</td> <td>
</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>DEUTSCHE GOODYEAR G.M.B.H.</td> <td>ND</td> <td>PHILIPSBURG BRUCHSAL</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>GUMMIWERKE FUIDA G.M.B.H.</td> <td>NE</td> <td>FULDA</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>JINYONG (QINGYUAN) RUBBER INDUSTRIAL CO., LTD</td> <td>NF</td> <td>QINGYUAN CITY</td> <td>GUANGDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO HUASHENG RUBBER CO., LTD.</td> <td>NH</td> <td>PINGDU QINGDAO CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GOODYEAR S.A.</td> <td>NJ</td> <td>
</td> <td>
</td> <td>GRAND DUCHY OF LUXEMBOURG</td> </tr> <tr> <td>GOODYEAR INDIA LTD.</td> <td>NK</td> <td>DISTRIC GURGAON</td> <td>HARIANA STATE</td> <td>INDIA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER LTD.</td> <td>NL</td> <td>BOGOR</td> <td>
</td> <td>INDONESIA</td> </tr> <tr> <td>TIANJIN XIELI RUBBER PRODUCT LIMITED CO.</td> <td>NM</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>CHONGQING DRAGON RUBBER PRODUCTS CO., LTD.</td> <td>NN</td> <td>CHANGSHOU DISTRICT OF CHONGQIN</td> <td>CHONGAING</td> <td>CHINA</td> </tr> <tr> <td>I-GREATEST RUBBER IND. CO., LTD.</td> <td>NP</td> <td>MEXICO CITY</td> <td>CHANG HUA HSIEN</td> <td>TAIWAN</td> </tr> <tr> <td>SHANDONG RONGCHENG TIRE FACTORY CO.</td> <td>NR</td> <td>RONGCHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>COMPANIA GOODYEAR DEL PERU</td> <td>NT</td> <td>LIMA</td> <td>
</td> <td>PERU</td> </tr> <tr> <td>QINGDAO HONGHUA TYRE FACTORY</td> <td>NU</td> <td>QINGDAO CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG HUADONG RUBBER CO., LTD.</td> <td>NV</td> <td>SHOUGUANG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER CO. (S.A.) (PTY) LTD.</td> <td>NW</td> <td>UITENHAGE</td> <td>
</td> <td>SOUTH AFRICA</td> </tr> <tr> <td>WEIFANG ANGU RUBBER INDUSTRY CO., LTD.</td> <td>NX</td> <td>SHOUGUANG CITY</td> <td>SHANGDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>GOODYEAR (THAILAND) LTD.</td> <td>NY</td> <td>BANGKOK</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>APOLLO TYRES LTD.</td> <td>P0</td> <td>SRIPERUMBUDUR – SINGAPERUMAL</td> <td>TAMILNADU</td> <td>INDIA</td> </tr> <tr> <td>CONTINENTAL GISLAVED DAECK AB</td> <td>P1</td> <td>GISLAVED</td> <td>
</td> <td>SWEDEN</td> </tr> <tr> <td>QINGDAO SENTURY TIRE CO., LTD.</td> <td>P2</td> <td>JIMO</td> <td>SHANDON</td> <td>CHINA</td> </tr> <tr> <td>SKEPPLANDA GUMMI, AB</td> <td>P3</td> <td>ALVAGEN</td> <td>
</td> <td>SWEDEN</td> </tr> <tr> <td>CARLISLE TIRE & WHEEL COMPANY</td> <td>P4</td> <td>JACKSON</td> <td>TN</td> <td>UNITED STATES</td> </tr> <tr> <td>GENERAL POPO S.A.</td> <td>P5</td> <td>SAN LUIS POTOSI</td> <td>S.L.P.</td> <td>MEXICO</td> </tr> <tr> <td>YONGKANG CITY HUAJIAN SILICON RUBBER CO., LTD.</td> <td>P6</td> <td>YONGKANG</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>MAGGION INDUSTRIAS DE PNEUS E MAQUINAS LTDA</td> <td>P7</td> <td>GUARULHOS</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>NO. 2 RUBBER PLANT OINGADO</td> <td>P8</td> <td>QUINGDAO</td> <td>SHANGONG</td> <td>CHINA</td> </tr> <tr> <td>MRF LIMITED PB NO.1 PONDA</td> <td>P9</td> <td>
</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>GOODYEAR LASTIKLERI TAS, PK 2</td> <td>PA</td> <td>IZMIT</td> <td>KOCAELI</td> <td>TURKEY</td> </tr> <tr> <td>CA GOODYEAR DE VENEZUELA</td> <td>PB</td> <td>VALENCIA</td> <td>EDO CARABOBO</td> <td>VENEZUELA</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY OF CANADA LTD</td> <td>PC</td> <td>MEDICINE HAT</td> <td>ALBERTA</td> <td>CANADA</td> </tr> <tr> <td>XINJIANG KUNLUN ENGINEERING TYRE CO., LTD.</td> <td>PD</td> <td>KORLE CITY</td> <td>XINJIANG</td> <td>CHINA</td> </tr> <tr> <td>MRF LTD. TRICHY (BLAS TYRE PLANT)</td> <td>PE</td> <td>PERAMBALUR DIST</td> <td>TAMIL NADU</td> <td>INDIA</td> </tr> <tr> <td>QINGDAO HUAWU RUBBER & PLASTIC CO., LTD.</td> <td>PF</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DONGYING DURUN TYRE CO., LTD</td> <td>PH</td> <td>DAWANG, DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>GISLAVED DAEK AB</td> <td>PI</td> <td>S-332 00 GISLAVED</td> <td>
</td> <td>SWEDEN</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>PJ</td> <td>FAYETTEVILLE</td> <td>NORTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>TITAN TIRE CORPORATION OF FREEPORT</td> <td>PK</td> <td>FREEPORT</td> <td>ILLINOIS</td> <td>UNITED STATES</td> </tr> <tr> <td>GOODYEAR TIRE & RUBBER COMPANY</td> <td>PL</td> <td>TYLER</td> <td>TEXAS</td> <td>UNITED STATES</td> </tr> <tr> <td>QINGDAO CHENGTAI HAND TRUCK CO, LTD</td> <td>PM</td> <td>JIAONAN QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SIFUTE INDUSTRIAL GROUP, LTD.</td> <td>PN</td> <td>SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG GUOFENG RUBBER & PLASTIC CO., LTD.</td> <td>PP</td> <td>DAWANG TOWN</td> <td>GUANGRAO</td> <td>CHINA</td> </tr> <tr> <td>WEIHAI PINGAN TYRE CO., LTD.</td> <td>PR</td> <td>RONGCHENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CEAT LTD. HALOL</td> <td>PT</td> <td>BARODA</td> <td>GUJARAT</td> <td>INDIA</td> </tr> <tr> <td>ARAI SHOJI CO., LTD.</td> <td>PU</td> <td>MINATO-KU</td> <td>TOKYO</td> <td>JAPAN</td> </tr> <tr> <td>CENCHENLYN TIRE CO., LTD.</td> <td>PV</td> <td>JIMO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TOYO TIRE & RUBBER CO., LTD.</td> <td>PW</td> <td>ZHANGJIAGANG</td> <td>JIAGANG</td> <td>CHINA</td> </tr> <tr> <td>TECHNO INNOVATIVE RUBBER ENTERPRISE INC.</td> <td>PX</td> <td>SCARBOROUGH</td> <td>ON</td> <td>CANADA</td> </tr> <tr> <td>WEIFANG HUARI RUBBER CO., LTD.</td> <td>PY</td> <td>SHOUGUANG CITY, SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>BOULDER CITY PLANT</td> <td>R0</td> <td>BOULDER CITY</td> <td>NEVADA</td> <td>UNITED STATES</td> </tr> <tr> <td>DEZHOU LINGLONG TYRE CO., LTD.</td> <td>R1</td> <td>DEZHOU</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>TIANJIN ZHENXIN RUBBER CO., LTD.</td> <td>R2</td> <td>TIAN JIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>ZHEJIANG XINCHANG ZHONGYA INDUSTRY</td> <td>R3</td> <td>XINCHANG</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG SHIFENG (GROUP) CO., LTD.</td> <td>R4</td> <td>GAOTANG</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG HENGYU RUBBER CO., LTD.</td> <td>R5</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO CHONGKUN INDUSTRIAL DEVELOPMENT CO., LTD.</td> <td>R6</td> <td>QINGDAO</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>CORPORACION DE OCCIDENTE, S.A. de C.V.</td> <td>R7</td> <td>EL SALTO</td> <td>JALISCO</td> <td>MEXICO</td> </tr> <tr> <td>SUMITOMO RUBBER (THAILAND) CO., LTD.</td> <td>R8</td> <td>AMPHUR PLUAKDAENG</td> <td>RAYONG</td> <td>THAILAND</td> </tr> <tr> <td>TAIZHOU JULUN TYRE CO., LTD.</td> <td>R9</td> <td>LUNAN,LUQIAO,TAIZHOU</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>TAIZHOU RENLI TIRE CO., LTD.</td> <td>RA</td> <td>TAIZHOU</td> <td>ZHEJING</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE NEUMATICOS DE MONTERREY</td> <td>RB</td> <td>CIENEGA DE FLORES</td> <td>NUEVO LEON</td> <td>MEXICO</td> </tr> <tr> <td>QINGAO MAO XIANG RUBBER CO., LTD.</td> <td>RC</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>COOCSA</td> <td>RD</td> <td>EL SALTO</td> <td>JALISCO</td> <td>MEXICO</td> </tr> <tr> <td>QINGDAO ELITE RUBBER CO., LTD.</td> <td>RE</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO TIANCHI TYRE CO., LTD.</td> <td>RF</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO HUASHI INDUSTRIAL PRODUCTS CO., LTD.</td> <td>RH</td> <td>QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>ANLAS ANADOLU LASTIK SANAYII VE TICARET A.S.</td> <td>RJ</td> <td>DUZCE</td> <td>
</td> <td>TURKEY</td> </tr> <tr> <td>INNOVATIVE TYRES & TUBES LTD</td> <td>RK</td> <td>HALOL (PANCHMAHAL)</td> <td>GUJARAT</td> <td>INDIA</td> </tr> <tr> <td>INTERNATIONAL MACHINERY & EQUIPMENT (ZHENGZHOU) CO. LTD.</td> <td>RL</td> <td>ZHENGZHOU</td> <td>HENAN</td> <td>CHINA</td> </tr> <tr> <td>COOPER KENDA TIRE (KUNSHAN) CO., LTD.</td> <td>RM</td> <td>KUNSHAN</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>MARANGONI PNEUMATICI</td> <td>RN</td> <td>ROVERETO</td> <td>TN</td> <td>ITALY</td> </tr> <tr> <td>TAIZHOU TAIYANGFENG RUBBER CO., LTD.</td> <td>RP</td> <td>XIANJU COUNTY</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>BELSHINA</td> <td>RR</td> <td>BOBRUISK</td> <td>
</td> <td>BELARUS</td> </tr> <tr> <td>DONGGUAN HUACHENG TYRE FACTORY</td> <td>RT</td> <td>DONGGUAN</td> <td>GUANGDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>VIZAHEM</td> <td>RU</td> <td>BELGRADE</td> <td>SERBIA</td> <td>SERBIA</td> </tr> <tr> <td>ETERNAL RISE TYRE (TIANJIN) CO., LTD.</td> <td>RV</td> <td>TIANJIN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>STIP SOCIETE TUNISIENNE DES</td> <td>RW</td> <td>KAIROUAN ROAD KM 25</td> <td>M’SAKEN, SOUSSE</td> <td>TUNISIA</td> </tr> <tr> <td>PRS TYRES LIMITED</td> <td>RX</td> <td>RASIPURAM</td> <td>TAMIL NADU</td> <td>INDIA</td> </tr> <tr> <td>SHANDONG CHANGFENG TYRES CO., LTD.</td> <td>RY</td> <td>DONGYING CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SOUTH PACIFIC TYRES</td> <td>T0</td> <td>CAMPBELIFIELD</td> <td>
</td> <td>CANADA</td> </tr> <tr> <td>HANKOOK TIRE MFG. CO., LTD.</td> <td>T1</td> <td>SEOUL</td> <td>
</td> <td>KOREA</td> </tr> <tr> <td>OZOS (UNIROYAL)</td> <td>T2</td> <td>OLSZTYN</td> <td>
</td> <td>POLAND</td> </tr> <tr> <td>DEBICKIE ZATTLDY OPON SAMOCHODOWYCH</td> <td>T3</td> <td>STOMIL</td> <td>DEVICA</td> <td>POLAND</td> </tr> <tr> <td>S.A. CARIDENG (RUBBERFACTORY)</td> <td>T4</td> <td>LANAKEN</td> <td>
</td> <td>BELGIUM</td> </tr> <tr> <td>TIGAR-PIROT</td> <td>T5</td> <td>
</td> <td>
</td> <td>YUGOSLAVIA</td> </tr> <tr> <td>QINGDAO YUANDA TYRE CO., LTD.</td> <td>T6</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>HANKOOK TIRE MFG. CO., LTD.DAEJEON PLANT</td> <td>T7</td> <td>DAEDEOK-GU</td> <td>DAEJEON</td> <td>KOREA</td> </tr> <tr> <td>GOODYEAR MALAYSIA BERHAD</td> <td>T8</td> <td>SELANGOR</td> <td>
</td> <td>MALAYSIA</td> </tr> <tr> <td>MRF LIMITED</td> <td>T9</td> <td>
</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>WENDENG SANJING CHEMISTRY CO., LTD.</td> <td>TA</td> <td>WENDENG</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SENTAIDA GROUP CO.</td> <td>TB</td> <td>JIMO QINGDAO</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>GOODYEAR DALIAN TIRE COMPANY LTD.</td> <td>TC</td> <td>PULANDIAN, DALIAN</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>ACME RUBBER IND. CO., LTD.</td> <td>TD</td> <td>TIANJHONG TOWNSHIP</td> <td>CHANGHUA</td> <td>TAIWAN</td> </tr> <tr> <td>CST RUBBER (ZHANGZHOU) IND. LTD.</td> <td>TE</td> <td>GANGWEI TOWN, LONGHAI</td> <td>FUJIAN</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO QIANZHEN TYRE CO., LTD.</td> <td>TF</td> <td>PINGDU CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG LONGSHAN TYRE CO., LTD.</td> <td>TH</td> <td>GAOMI</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CHAOYANG LONG MARCH TYRE NEW CO., LTD.</td> <td>TJ</td> <td>CHAOYANG</td> <td>LIAONING</td> <td>CHINA</td> </tr> <tr> <td>YOKOHAMA R.P.Z.</td> <td>TK</td> <td>GRYAZI</td> <td>LIPETSK REGION</td> <td>RUSSIA</td> </tr> <tr> <td>SICHUAN KALEVEI TECHNOLOGY CO., LTD.</td> <td>TL</td> <td>JIANYANG SICHUAN</td> <td>641400</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE HUIZHOU</td> <td>TM</td> <td>HUIZHOU</td> <td>GUANGDONG</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG HUANTAI RUBBER CO., LTD.</td> <td>TN</td> <td>CHANGYI CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DOUBLE COIN GROUP (CHONGQING) TIRE CO., LTD.</td> <td>TP</td> <td>MID SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO SHUANGHE TYRE CO., LTD.</td> <td>TR</td> <td>PINGDU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>DERUIBAO TIRE CO., LTD.</td> <td>TT</td> <td>GUANGRAO</td> <td>QINGDAO</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO MOREWIN RUBBERWARE CO., LTD.</td> <td>TU</td> <td>JIAONAN</td> <td>QINGDAO</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG O’GREEN TYRES CO., LTD.</td> <td>TV</td> <td>DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>WEIFANG SHUNFUCHANG RUBBER & PLASTIC CO., LTD.</td> <td>TW</td> <td>SHOUGUANG SHANGDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>WIEGEL RUBBER CO., LTD.</td> <td>TX</td> <td>HANDAN, HEBEI PROVINCE</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>WIEGEL RUBBER CO., LTD.</td> <td>TY</td> <td>QINGDAO, SHANGDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SOUTH PACIFIC TYRES</td> <td>U0</td> <td>THOMASTOWN</td> <td>VICTORIA</td> <td>AUSTRAILIA</td> </tr> <tr> <td>LIEN SHIN TIRE CO., LTD.</td> <td>U1</td> <td>TA-TSUEN HSIANG</td> <td>CHANGHUA HSIEN</td> <td>TAIWAN</td> </tr> <tr> <td>SUMITOMO RUBBER INDUSTRIES, LTD.</td> <td>U2</td> <td>SHIRAKAWA CITY</td> <td>FUKUSHIMA PREFECTURE</td> <td>JAPAN</td> </tr> <tr> <td>MILOJE ZAKIC</td> <td>U3</td> <td>
</td> <td>
</td> <td>YUGOSLAVIA</td> </tr> <tr> <td>GEO. BYERS SONS, INC.</td> <td>U4</td> <td>COLOMBUS</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>FARBENFABRIKEN BAYER GMBH</td> <td>U5</td> <td>
</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>PNEUMANT</td> <td>U6</td> <td>DRESDEN</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>PNEUMANT</td> <td>U7</td> <td>20 NEUBRANDENBURG</td> <td>INDUSTRIGELANDE</td> <td>GERMANY</td> </tr> <tr> <td>HSIN FUNG FACTORY OF NANKANG RUBBER CO.</td> <td>U8</td> <td>TAIWAN, REPUBLIC OF CHINA</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>COOPER TIRE & RUBBER CO</td> <td>U9</td> <td>TUPELO</td> <td>MISSISSIPPI</td> <td>UNITED STATES</td> </tr> <tr> <td>NEXEN TIRE CORPORATION</td> <td>UA</td> <td>CHANGNYEONG-GUN</td> <td>GYEONGSANGNAM-DO</td> <td>SOUTH KOREA</td> </tr> <tr> <td>SHANDONG HENGYU SCIENCE & TECHNOLOGY CO., LTD.</td> <td>UB</td> <td>DAWANG, GUANGRDO, DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG FUYU BLUESTONE TYRE CO., LTD.</td> <td>UC</td> <td>ZIBO SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>MITAS TIRES NORTH AMERICA, INC.</td> <td>UD</td> <td>CHARLES CITY</td> <td>IA</td> <td>UNITED STATES</td> </tr> <tr> <td>TIUMSUN RUBBER TIRE (WEI HAI) CO., LTD.</td> <td>UE</td> <td>WEIHAI</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SHAANXI YANCHANG PETROLEUM GROUP RUBBER CO.</td> <td>UF</td> <td>XIANYANG SHAANXI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG YINUO ENGINEERING TYRE CO., LTD.</td> <td>UH</td> <td>TENGZHOU CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CHINA NATIONAL TYRE & RUBBER GUILIN CO., LTD.</td> <td>UJ</td> <td>SUQIAO</td> <td>GUILIN</td> <td>CHINA</td> </tr> <tr> <td>TOYAMA TYRE CORP., LTD.</td> <td>UK</td> <td>XUANWU DISTRICT</td> <td>BEIJING</td> <td>CHINA</td> </tr> <tr> <td>CHENG SHIN TIRE & RUBBER (CHONGQING) CO., LTD.</td> <td>UL</td> <td>YANJIA INDUSTRY PARK</td> <td>CHANGSHEU, CHONGQING</td> <td>CHINA</td> </tr> <tr> <td>PIRELLII NEUMATICOS S.A. DE C.V.</td> <td>UN</td> <td>SILAO, GUANAJUATO</td> <td>
</td> <td>MEXICO</td> </tr> <tr> <td>COOPER TIRE & RUBBER CO</td> <td>UP</td> <td>FINDLAY</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>GOOD FRIEND TYRE CO., LTD.</td> <td>UR</td> <td>JIAOZUO</td> <td>HENAN</td> <td>CHINA</td> </tr> <tr> <td>COOPER TIRE & RUBBER CO</td> <td>UT</td> <td>TEXARKANA</td> <td>ARKANSAS</td> <td>UNITED STATES</td> </tr> <tr> <td>CARLISLE TIRE & RUBBER DIVISION</td> <td>UU</td> <td>CARLISLE</td> <td>PENNSYLVANIA</td> <td>UNITED STATES</td> </tr> <tr> <td>KZOWA RUBBER INDUSTRY CO., LTD.</td> <td>UV</td> <td>NISHINARIKU</td> <td>OSAKA</td> <td>JAPAN</td> </tr> <tr> <td>OKADA TIRE INDUSTRY LTD.</td> <td>UW</td> <td>KATSUSHIKA-KU</td> <td>TOKYO</td> <td>JAPAN</td> </tr> <tr> <td>FEDERAL CORPORATION</td> <td>UX</td> <td>CHUNGLI</td> <td>TAOYUAN</td> <td>TAIWAN</td> </tr> <tr> <td>CHENG SHIN RUBBER IND. CO. LTD.</td> <td>UY</td> <td>TA TSUN</td> <td>CHANG-HWA</td> <td>TAIWAN</td> </tr> <tr> <td>SOUTH PACIFIC TYRES</td> <td>V0</td> <td>UPPER HUTT</td> <td>WELLINGTON</td> <td>NEW ZEALAND</td> </tr> <tr> <td>LIVINGSTON’S TIRE SHOP</td> <td>V1</td> <td>HUBBARD</td> <td>OHIO</td> <td>UNITED STATES</td> </tr> <tr> <td>VSEOJUZNOE OJEDINENIC AVTOEXPORT</td> <td>V2</td> <td>VOLZHSK</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>TA HSIN RUBBER TIRE COMPANY, LTD.</td> <td>V3</td> <td>TUCHEN VILLAGE</td> <td>TAIPEI HSIENG</td> <td>TAIWAN</td> </tr> <tr> <td>SUMITOMO RUBBER INDUSTRIES, LTD.</td> <td>V4</td> <td>MIYAKONOJO CITY</td> <td>MIYAZAKI PREFECTURE</td> <td>JAPAN</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE DE MEXICO, S.A. DE C.V.</td> <td>V5</td> <td>MEXICO D.F.</td> <td>
</td> <td>MEXICO</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE DE MEXICO, S.A.</td> <td>V6</td> <td>APARTADO POSTAL 23D</td> <td>CUEMAVACA, MOR.</td> <td>MEXICO</td> </tr> <tr> <td>VSESOJUZNOE OJEDINERIE AVTOEXPORT</td> <td>V7</td> <td>VORONEZH</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>MICHELIN INDIA TAMILNADU TYRES PVT. LTD.</td> <td>V8</td> <td>GUMMIDIPOONDI TALUK TIRUVALLUR</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>M & H TIRE COMPANY</td> <td>V9</td> <td>GARDNER</td> <td>MASSACHUSETTS</td> <td>UNITED STATES</td> </tr> <tr> <td>SUMITOMO RUBBER (THAILAND) CO., LTD.</td> <td>VA</td> <td>AMPHUR PLUAKDAENG, RAYONG</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>ANHUI DARUI RUBBER CO., LTD</td> <td>VB</td> <td>WUHU</td> <td>ANHUI</td> <td>CHINA</td> </tr> <tr> <td>SHANDONG HAOYU RUBBER CO., LTD.</td> <td>VC</td> <td>GUANGRAO COUNTY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO HONGCHI TYRE CO., LTD.</td> <td>VD</td> <td>PINGDU, QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>VE</td> <td>DES MOINES</td> <td>IOWA</td> <td>UNITED STATES</td> </tr> <tr> <td>WEIFANG ZHENFU INDUSTRIAL CO., LTD.</td> <td>VF</td> <td>GAOMI CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SUMITOMO RUBBER (HUNAN) CO., LTD</td> <td>VH</td> <td>CHANGSHA</td> <td>HUNAN</td> <td>CHINA</td> </tr> <tr> <td>AEOLUS TYRE., LTD.</td> <td>VJ</td> <td>JIAOZUO</td> <td>HENAN</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO YUANZHOU RUBBER PRODUCTS CO., LTD.</td> <td>VK</td> <td>JIAONAN QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL KALUGA</td> <td>VL</td> <td>KALUGA</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>ZHUCHENG GUOXIN RUBBER CO., LTD.</td> <td>VM</td> <td>ZHUCHENG</td> <td>ALBERTA, SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE CANADA INC.</td> <td>VN</td> <td>JOLIETE</td> <td>QUEBEC</td> <td>CANADA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE ITALIA S.P.A.</td> <td>VP</td> <td>7-26 BODUGNO (BARI)</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>BRIDGESTONE TATABANYA MANUFACTURING LTD.</td> <td>VR</td> <td>TATABÁNYA</td> <td>
</td> <td>HUNGARY</td> </tr> <tr> <td>FIRESTONE HISPANIA, S.A.</td> <td>VT</td> <td>BILBAO</td> <td>E-48080</td> <td>SPAIN</td> </tr> <tr> <td>UNIVERSAL TIRE COMPANY</td> <td>VU</td> <td>LANCASTER</td> <td>PENNSYLVANIA</td> <td>UNITED STATES</td> </tr> <tr> <td>BRILAND RUBBER TIRE CO., LTD.</td> <td>VV</td> <td>WENZHOU</td> <td>
</td> <td>P.R. CHINA</td> </tr> <tr> <td>SUMITOMO RUBBER INDUSTRIES, LTD.</td> <td>VW</td> <td>IZUMI-OHTSU CITY</td> <td>OSAKA</td> <td>JAPAN</td> </tr> <tr> <td>WEIHAI HUAMAO RUBBER SCIENCE AND TECH.</td> <td>VX</td> <td>WEIHAI</td> <td>SHANDONG PROVIINCE</td> <td>CHINA</td> </tr> <tr> <td>CONTINENTAL TIRE – SUMPTER</td> <td>VY</td> <td>SOUTH SUMTER</td> <td>NC</td> <td>USA</td> </tr> <tr> <td>FIRESTONE TIRE & RUBBER CO.</td> <td>W</td> <td>VISKAFORS</td> <td>
</td> <td>SWEDEN</td> </tr> <tr> <td>INOCCE RUBBER CO., INC.</td> <td>W0</td> <td>PHATUMTANI</td> <td>
</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>W1</td> <td>LAVERGNE</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>W2</td> <td>WILSON</td> <td>NORTH CAROLINA</td> <td>UNITED STATES</td> </tr> <tr> <td>VREDESTEIN DOETINCHEM B.V.</td> <td>W3</td> <td>DOEFINEHEM</td> <td>
</td> <td>NETHERLANDS</td> </tr> <tr> <td>DUNLOP OLYMPIC TYRES</td> <td>W4</td> <td>SOMERTON</td> <td>VICTORIA</td> <td>AUSTRAILIA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE ARGENTINA S.A.I.C.</td> <td>W5</td> <td>1836 LIAVALLOL</td> <td>PROVINCE DE BUENOS AIRES</td> <td>ARGENTINA</td> </tr> <tr> <td>MSF TIRE AND RUBBER, INC.</td> <td>W6</td> <td>SUCAT, MUNTINLUPA CITY</td> <td>
</td> <td>PHILIPPINES</td> </tr> <tr> <td>JIANGSU CHENGTONG TIRE CO., LTD.</td> <td>W7</td> <td>XUZHOU</td> <td>JIANGSU</td> <td>CHINA</td> </tr> <tr> <td>SIAM TYRE PHRAPRADAENG CO., LTD.</td> <td>W8</td> <td>SAMSUNG KLANG,PHRAPRADAENG</td> <td>SAMUTPRAKARN</td> <td>THAILAND</td> </tr> <tr> <td>BRIDGESTONE INDIA PRIVATE LIMITED, PUNE</td> <td>W9</td> <td>MAHARASHTRA</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE FRANCE</td> <td>WA</td> <td>F-62401BETHUNE CEDEX</td> <td>
</td> <td>FRANCE</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE DE COSTA RICA</td> <td>WB</td> <td>SAN JOSE</td> <td>
</td> <td>COSTA RICA</td> </tr> <tr> <td>SUMITOMO RUBBER DO BRASIL LTDA</td> <td>WC</td> <td>SYDNEYFAZENDA RIO GRANDE</td> <td>PARANA</td> <td>BRAZIL</td> </tr> <tr> <td>HEBEI TIANRUI RUBBER CO., LTD.</td> <td>WD</td> <td>HANDAN</td> <td>HEBEI PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>NANKANG RUBBER TIRE CORPORATION</td> <td>WE</td> <td>WEST TAIPEI</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE HISPANIA, S.A.</td> <td>WF</td> <td>E-09080 BURGOS</td> <td>
</td> <td>SPAIN</td> </tr> <tr> <td>SHANDONG FENGLUN TYRE CO., LTD.</td> <td>WH</td> <td>ZAOZHUANG, SHANDONG</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>SHANGHAI HANGHONG RUBBER MANUFACTORY</td> <td>WJ</td> <td>SHANGHAI</td> <td>
</td> <td>CHINA</td> </tr> <tr> <td>WUYI FENGYUAN MINING MACHINE MANUFACTOR CO.LTD.</td> <td>WK</td> <td>WUYII</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>NINGBO HUALIN</td> <td>WL</td> <td>YUYAO</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>DUNLOP OLYMPIC TYRES</td> <td>WM</td> <td>WEST FOOTSERAY</td> <td>VICTORIA</td> <td>AUSTRAILIA</td> </tr> <tr> <td>HEBEI STARBRIGHT TIRE CO., LTD.</td> <td>WN</td> <td>XINGTAI</td> <td>HEBEI</td> <td>CHINA</td> </tr> <tr> <td>GUANGZHOU SOUTH CHINA TIRE & RUBBER CO., LTD.</td> <td>WP</td> <td>AOTOU CONGHUA</td> <td>GUANGDONG</td> <td>CHINA</td> </tr> <tr> <td>JK TYRE & INDUSTRIES LIMITED</td> <td>WR</td> <td>KANCHEEPURAM DISTRICT</td> <td>TAMIL NADU</td> <td>INDIA</td> </tr> <tr> <td>MADRAS RUBBER FACTORY LTD.</td> <td>WT</td> <td>MADRAS</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>CEAT TYRES OF INDIA LTD.</td> <td>WU</td> <td>BHANDUP,BOMBAY</td> <td>MAHARASHTRA</td> <td>INDIA</td> </tr> <tr> <td>GENERAL RUBBER CORPORATION</td> <td>WV</td> <td>TAIPEI</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>EUZKADI COMPANIA HULERA EUZKADI, S.A.</td> <td>WW</td> <td>MEXICO CITY</td> <td>
</td> <td>MEXICO</td> </tr> <tr> <td>EUZKADI COMPANIA HULERA EUZKADI, S.A.</td> <td>WX</td> <td>LA PRESA</td> <td>EO DE</td> <td>MEXICO</td> </tr> <tr> <td>EUZKADI COMPANIA HULERA EUZKADI, S.A.</td> <td>WY</td> <td>GUADAJIARA</td> <td>JALISCO</td> <td>MEXICO</td> </tr> <tr> <td>VSESOJUZNOE OJEDINENIE AVTOEXPORT</td> <td>X0</td> <td>MIZHNEKAMSK</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>TONG SHIN CHEMICAL PRODUCTS. LTD.</td> <td>X1</td> <td>YONGDONGPO-KO</td> <td>SEOUL</td> <td>KOREA</td> </tr> <tr> <td>HWA FONG RUBBER INDUSTRIAL CO., LTD.</td> <td>X2</td> <td>CHANG HUA HSIEN</td> <td>
</td> <td>TAIWAN</td> </tr> <tr> <td>CJSC “ROSAVA”</td> <td>X3</td> <td>BELAYA TSERKOV</td> <td>KIEV REGION</td> <td>RUSSIA</td> </tr> <tr> <td>PARS TYRE COMPANY</td> <td>X4</td> <td>SAVEH</td> <td>
</td> <td>IRAN</td> </tr> <tr> <td>J.K. INDUSTRIES LTD.</td> <td>X5</td> <td>KANKROLI</td> <td>RAJASTHAN</td> <td>INDIA</td> </tr> <tr> <td>VSESOJUZNOE OJEDINENIE AVTOEXPORT</td> <td>X6</td> <td>BOBRUYSK</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>VSESOJUZNOE OJEDINENIE AVTOEXPORT</td> <td>X7</td> <td>CHIMKENTSKY</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>DNEPROSHINA JOIN STOCK COMPANY (“DENEPROSHINA” JSC)</td> <td>X8</td> <td>DNEPROPETROVSK</td> <td>
</td> <td>UKRAINE</td> </tr> <tr> <td>VSESJUZNOE OJEDINENIE AVTOEXPORT</td> <td>X9</td> <td>MOSCOW</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>PIRELLI TYRE S.P.A.</td> <td>XA</td> <td>BOLLATE</td> <td>MILAN</td> <td>ITALY</td> </tr> <tr> <td>PIRELLI TYRE S.P.A.</td> <td>XB</td> <td>SETTIMO</td> <td>TORINO</td> <td>ITALY</td> </tr> <tr> <td>TRELLEBORG WHEEL SYSTEM SPA</td> <td>XC</td> <td>TIVOLI</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>INDUSTRIE PIRELLI S.P.A.</td> <td>XD</td> <td>MESSINA</td> <td>
</td> <td>ITALY</td> </tr> <tr> <td>PIRELLI PNEUS S.A.</td> <td>XE</td> <td>GRAVATAI</td> <td>RIO GRANDE DU SUL</td> <td>BRAZIL</td> </tr> <tr> <td>PIRELLI NEUMATICOS S.A.</td> <td>XF</td> <td>MANRESA</td> <td>BARCELONA</td> <td>SPAIN</td> </tr> <tr> <td>PIRELLI KIROV OPCO</td> <td>XH</td> <td>KIROV</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>TURK PIRELLI LASTKLERI, S.A.</td> <td>XJ</td> <td>KOSEKOY</td> <td>IZMIT</td> <td>TURKEY</td> </tr> <tr> <td>PIRELLI PNEUS S.A.</td> <td>XK</td> <td>SANTO ANDRE</td> <td>SAO PAULO</td> <td>BRAZIL</td> </tr> <tr> <td>PIRELLI PNEUS S.A.</td> <td>XL</td> <td>CAMPINAS</td> <td>SAO PAULO</td> <td>BRAZIL</td> </tr> <tr> <td>PIRELLI NEUMATICOS S.A.I.C.</td> <td>XM</td> <td>MERLO</td> <td>BUENOS AIRES</td> <td>ARGENTINA</td> </tr> <tr> <td>PIRELLI TYRES LTD.</td> <td>XN</td> <td>CARLISLE</td> <td>CUMBRIA</td> <td>UNITED KINGDOM</td> </tr> <tr> <td>PIRELLI TYRES LTD.</td> <td>XP</td> <td>BURTON-ON-TRENT</td> <td>STAFFORDSHIRE</td> <td>UNITED KINGDOM</td> </tr> <tr> <td>QINGDAO MORECHI RUBBER CO., LTD.</td> <td>XR</td> <td>JIAONAN</td> <td>QINGDAO</td> <td>CHINA</td> </tr> <tr> <td>PIRELLI GERMANY A.G.</td> <td>XT</td> <td>HOECHST/ODENWALD</td> <td>
</td> <td>GERMANY</td> </tr> <tr> <td>DONGYING ZHONGYI RUBBER CO., LTD.</td> <td>XU</td> <td>GUANGRAO, DONGYING</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>TOLINS TYRES PVT, LTD.</td> <td>XV</td> <td>KALADY ERNAKULAM</td> <td>KERALA</td> <td>INDIA</td> </tr> <tr> <td>QINGZHOU HUACHEN RUBBER CO., LTD.</td> <td>XW</td> <td>QINGZHOU</td> <td>SHANDONG PROVINCE</td> <td>CHINA</td> </tr> <tr> <td>BANDAG, INCORPORATED</td> <td>XX</td> <td>MUSCATINE</td> <td>IOWA</td> <td>UNITED STATES</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE CANADA INC.</td> <td>XY</td> <td>JOLIETTE</td> <td>QUEBEC</td> <td>CANADA</td> </tr> <tr> <td>KUMHO AND CO., INC.</td> <td>Y0</td> <td>GOKSUNG-GUN</td> <td>CHOLLA NAM-DO</td> <td>KOREA</td> </tr> <tr> <td>COMPANHIA GOODYEAR DO BRAZIL</td> <td>Y1</td> <td>AMERICANA, STATE OF SAO PAULO</td> <td>
</td> <td>BRAZIL</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC</td> <td>Y2</td> <td>WILSON</td> <td>NC</td> <td>UNITED STATES</td> </tr> <tr> <td>SHANDONG GOODTYRE RUBBER CO., LTD.</td> <td>Y3</td> <td>DEZHOU</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>ATC TIRES PVT. LTD.</td> <td>Y4</td> <td>MUMBAI MAHARASHTRA</td> <td>
</td> <td>INDIA</td> </tr> <tr> <td>SHANGHAI MICHELIN WARRIOR TYRE CO. LTD.(SMW)</td> <td>Y5</td> <td>MING HANG DEVELOPMENT ZONE</td> <td>SHANGHAI</td> <td>CHINA</td> </tr> <tr> <td>SIME TYRES INTERNATIONAL (M) SDN BHD</td> <td>Y6</td> <td>KEDAH</td> <td>
</td> <td>MALAYSIA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC.</td> <td>Y7</td> <td>LAVERGNE</td> <td>TENNESSEE</td> <td>UNITED STATES</td> </tr> <tr> <td>BOMBAY TYRES INTERNATIONAL LTD.</td> <td>Y8</td> <td>BOMBAY</td> <td>MAHARASHTRA</td> <td>INDIA</td> </tr> <tr> <td>P.T. GADJAH TUNGGUAL</td> <td>Y9</td> <td>KABUPATEN TANGERANG</td> <td>JAWA BARAT</td> <td>INDONESIA</td> </tr> <tr> <td>MRF LTD-TRICHY (RADIAL TYRE PLANT)</td> <td>YA</td> <td>PERAMBALUR DISTRICT</td> <td>TAMIL NADU</td> <td>INDIA</td> </tr> <tr> <td>PIRELLI VORONEZH OPCO</td> <td>YB</td> <td>VORONEZH</td> <td>
</td> <td>RUSSIA</td> </tr> <tr> <td>DAYTON TIRE & RUBBER CO.</td> <td>YC</td> <td>ALBANY</td> <td>GA</td> <td>UNITED STATES</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC</td> <td>YD</td> <td>DECATUR</td> <td>IL</td> <td>UNITED STATES</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC</td> <td>YE</td> <td>DES MOINES</td> <td>IA</td> <td>UNITED STATES</td> </tr> <tr> <td>DAYTON TIRE & RUBBER CO.</td> <td>YF</td> <td>SOUTH GATE</td> <td>CA</td> <td>UNITED STATES</td> </tr> <tr> <td>DAYTON TIRE & RUBBER CO.</td> <td>YH</td> <td>MEMPHIS</td> <td>TN</td> <td>UNITED STATES</td> </tr> <tr> <td>DAYTON TIRE & RUBBER CO.</td> <td>YJ</td> <td>POTTSTOWN</td> <td>PA</td> <td>UNITED STATES</td> </tr> <tr> <td>DAYTON TIRE & RUBBER CO.</td> <td>YK</td> <td>SALINAS</td> <td>CA</td> <td>UNITED STATES</td> </tr> <tr> <td>NOKIAN TYRE PLC</td> <td>YL</td> <td>NOKIA</td> <td>
</td> <td>FINLAND</td> </tr> <tr> <td>YOKOHAMA INDIA PRIVATE LTD. BAHADURGARH PLANT</td> <td>YM</td> <td>DISTRICT JHAJJAR</td> <td>HARYANA</td> <td>INDIA</td> </tr> <tr> <td>AUNG HTET MYET CO., LTD.</td> <td>YN</td> <td>YANGON, MYANMAR</td> <td>YANGON</td> <td>MYANMAR</td> </tr> <tr> <td>HANGZHOU SHUNYUAN TIRE MANUFACTURE CO., LTD.</td> <td>YP</td> <td>HANGZHOU</td> <td>ZHEJIANG</td> <td>CHINA</td> </tr> <tr> <td>QINGDAO HUADA RUBBER PRODUCTION CO., LTD.</td> <td>YR</td> <td>JIAONAN, QINGDAO</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>BIRLA TYRES,PROP:KESORAM INDUSTRIES LTD.</td> <td>YT</td> <td>HARIDWAR</td> <td>UTTAR KHAND</td> <td>INDIA</td> </tr> <tr> <td>BRIDGESTONE/FIRESTONE NORTH AMERICAN TIRE, LLC</td> <td>YU</td> <td>DES MOINES</td> <td>IA</td> <td>UNITED STATES</td> </tr> <tr> <td>LONGKOU YONGAN VEHICLE WINDOW CO., LTD.</td> <td>YV</td> <td>LONGKOU CITY</td> <td>SHANDONG</td> <td>CHINA</td> </tr> <tr> <td>SEIBERLING TIRE & RUBBER CO.</td> <td>YW</td> <td>MEMPHIS</td> <td>TN</td> <td>UNITED STATES</td> </tr> <tr> <td>SEIBERLING TIRE & RUBBER CO.</td> <td>YX</td> <td>POTTSTOWN</td> <td>PA</td> <td>UNITED STATES</td> </tr> <tr> <td>SEIBERLING TIRE & RUBBER CO.</td> <td>YY</td> <td>SALINAS</td> <td>CA</td> <td>UNITED STATES</td></tr>********></table>
Seek to understand,^Value
Discussion Starter #58
Discussion Starter #59 (Edited)
41 - 60 of 69 Posts
