Um....many people? If I am driving 700 miles and back, I want a spare.Who cares about a spare tire.
That's fine as long as you don't have a flat tire more than 50 miles from your destination.I have not carried a spare in 15 years.
LMAO!That's fine as long as you don't have a flat tire more than 50 miles from your destination.
You probably didn't need to wear your safety belts in the last 15 years.
But, if you hit something on the road and tear a chunk of side wall out, you are out of luck! :rofl:Plug kit and a pump and good to go.
If you're in the U.S. TireRack.com has winter tire and wheel packages. If the size of the brakes allow it, they usually offer a smaller diameter wheel to go with the winter tires, while still maintaining the tire outside diameter and width.Did you purchase winter rims and tires?? If so where?
I was on the phone with Tire Rack for that very reason....they don't have anything currently available for the M2 in a winter tire. Or I would have bought four with winter tires. They expect the new round of available winter tires in September.If you're in the U.S. TireRack.com has winter tire and wheel packages. If the size of the brakes allow it, they usually offer a smaller diameter wheel to go with the winter tires, while still maintaining the tire outside diameter and width.
You just redo it. The tire does not need to be replaced. I use to demo tires with 100 plugs in each tire on various cars. As long as you use the self vulcanizing plugs you will be fine. I will say it's a bitch to balance a tire with 100 plugs in it!Those do-it-yourself plug kit usually work, but not always. Those DIY plugs can also fail over time. Once a DIY plug fails. the tire will have to be replaced.
Here's a proper "high speed" plug-patch, that requires taking the tire off the rim.
Bimmerzone.com doesn't show one. Some overseas markets require that new cars come with a spare. One solution is a full size front tire/wheel, with a spacer and a set of longer lug bolts so it will fit on the rear. Most flats are on the rear.Exactly what wheel can be used for an M2 spare that will clear the front and rear brakes? Does BMW make a wheel and tire setup that is proven to work?
