1 - 11 of 11 Posts
///M 'n it up!
A buddy of mine got in the passenger side, pulled the door handle to shut the door, and the handle came off in his hands! The door handle uses cheap plastic fasteners. The fasteners just snapped in two!
Has anyone else had this problem?
An upgrade to a z4coupe or mz4 will fix that right up. : )
Banned
Happen to me on a 91 Acura Legend after about 5 years. I think plastics in general break down over time thereby weakening the parts.
///M 'n it up!
Discussion Starter · #4 ·
I would love a mZ4 roadster (sorry, I like the sun too much for a coupe). Anyone willing to donate?
A very similar thing happened to a friend of mine, tho the passenger side door piece one pulls on to close the door, only pulled loose on one end. It is a 2000 2.8 Z3, and he was told by a quality body shop that the door panel had to be removed and replaced (it only comes as an assembly) and because of the air bags etc, the cost would be approx $1000.
Let me know how you fix this and I will pass the info along to him.
Dragon Master of TEXAS!
Nope! Plus I hope not too!
Not that uncommon.
I have gone thru one passenger side and soon to need the drivers. Price for non-extended leather pulls is about $37. Takes about 30 min to replace. You have to remove the door panel to replace. The top part of the pull uses heat melted plastic as the attaching mechanism, kinda flimsy IMHO.
thats why I put carbon fiber at the back of the door panel and bigger washers behind the handle screws to reenforce the whole panel...now its stronger than ever...pull ad slam all you want
///M 'n it up!
Discussion Starter · #9 ·
Please feel free to explain in more detail where you got the materials and how it all fit together!
you 1st remove the door panels as per Ron's instruction (search function)...read this from top to bottom before reading further...
then you remove the 2 screws holding the handle to the panel but keep the handles in place...its still held by a melted plastic tab when the mirror button is...you dont wanna break those tabs
number 10 in...
http://www.realoem.com/bmw/showparts.do?model=CM93&mospid=48089&btnr=51_2351&hg=51&fg=50
I then laminated the back of the door panel (the cardboard like material) with body repair fiber glass and carbon fiber sheets at the stress bearing location...concentrate at the attachment points of the handle and surrounding area to spread the load...dont make it too thick though or you will have hard time clear the wires behind the panel
once the sheets dried and the panel is hard...I then drilled 2 holes where the 2 screws suppose to go (careful so you dont drill thru the handle)...and I added two big washer to the original one piece washer for the screws...again to spread the load
now you have a more rigid door panel...i have been slamming and pulling both doors without any problem
took me over 2 weekends to do this...one door at a time...as you need patience and lots of air drying for the resin to harden...also dont buy cheap resin as they will make the interior smells like glue for wks...unless you like to sniff that kinda thing...
hope it helps...fix it before its too late...my panels are in mint condition so I figure in case I break mine, those junk yard ones won't cut it...
1 - 11 of 11 Posts
