If you’ve spent any serious amount of time as a shadetree mechanic, more than likely, you’ve watched as the number of diagnostic tools in your toolbox has grown steadily over the years. OBD-II scanners, borescopes, multimeters, circuit testers, oscilloscopes – you’ve likely shopped around for one or all of them at some time or another. But there’s one particularly versatile, yet often overlooked, piece of diagnostic equipment that’s been growing in popularity over the past few years, owing both to the breadth of applications in which it can be used, and to the steady growth in availability of the technology: the thermal imaging camera.
Mechanics have found a wide range of clever uses for thermal imaging cameras in automotive diagnostics. Thermal images are among the safest and most surefire ways to track down pesky exhaust leaks, for instance, and they can help pinpoint cooling and HVAC-related issues like clogged radiators and heater cores, faulty thermostats, and leaky hoses. Mechanics have even found use for them in areas like discerning which cylinder has a misfire, where there might be an electrical short or parasitic electrical drain, and whether a certain brake caliper is seized.
In short, a good thermal imaging camera can help take some of your trickier, more error-prone diagnostic jobs and shave a number of hours off.
If you’re just now getting acquainted with thermal imaging and haven’t a clue which camera models to consider, take a look at TOPDON’s TC line of thermal imaging cameras. The model line includes the TOPDON TC001 and TC002 cameras, which are built for Windows/Android and iOS devices, respectively. That includes smartphones, tablets, and laptops. The benefits of this sort of setup are obvious: both the TC001 and TC002 are small and supremely portable, weighing around 30 grams and measuring less than 3 inches long, and with their respective software apps, the two thermal imaging cameras allow you to view large, full-color thermal images directly on your favorite smartphone or tablet screen. Both have the same impressively broad temperature sensitivity range, covering the span from -20 to 550 degrees Celsius (-4 to 1022 Fahrenheit) with a variance of just plus or minus 2 degrees Celsius. All of that comes with a high image resolution of 256 by 192 pixels, which is more than sufficient for picking out fine details. You can also use the TOPDON cameras record continuous temperature reading data for later viewing in handy graphical waveforms.
Beside the TC001 and TC002, there’s also the TOPDON TC004, which is the most affordable standalone handheld option in the TC range. The TC004 thermal imaging camera gives up some amount of effective temperature range in order to meet its diminutive price tag, but with a range from -20 to 350 Celsius, it still packs far more range than the average job would ever require, and its 0.05-degree sensitivity means that it can pick out minute temperature differentials in a way that few other thermal imaging cameras can. The built-in full-color screen packs the same 256-by-192-pixel resolution as the TC001 and TC002 imagers, and it has a stated battery life of 12 hours per charge. Arguably one of the most useful features is the TC004’s PC screen projection capability, along with TOPDON’s professional analysis software that allows users to save, share, and pick apart diagnostic data on a personal computer.
Finally, there’s the TOPDON TC005 – the “top dog” in the TOPDON thermal camera range, with the same broad temperature range as the TC001 and TC002 in a handheld temperature gun package. It boasts the same 256-by-192-pixel image resolution as the others in the lineup, the same long-lasting 12-hour battery life as the TC004, and the same awesome PC analysis software and screen projection.
No matter which thermal imaging camera in the TOPDON TC range is right for you, you get access to some truly potent diagnostic firepower. The accompanying software is highly customizable, allowing you to set your own minimum and maximum temperature ranges, choose between three different temperature check schemes, and select one of a range of available color palettes. And to be clear, it’s not just in the automotive sphere that such a powerful tool proves useful; you’ll no doubt find uses for your TOPDON TC thermal imaging camera throughout your home ownership experience, from checking your roofing and insulation to tracking electrical gremlins and HVAC issues.
To get a full, unfiltered look at TOPDON’s range of versatile thermal imaging cameras, head on over to TOPDON.com.
