Unless RD provides stronger links with the kit, and my recolection is that my kit did, I have not upgraded them separately. I have the 27mm front and 22 mm rear bars. I have re-enforced the connection points on the sub chassis. That appears to be a weak spot. My feelings have been that the stock rubber, are a compromise for streetability vs performance Thought to sell cars that drop fillings from the test drivers mouth. Afterall- although it is an M series car, they are selling a road going car.
I try to avoid too stiff..thats no good either since the car is driven on poor roads much of the time, but somewhere between the stock suspension peices and all metal bushings is a hppy place for me.
[/QUOTE]
I've got my IE bushings sitting out in the garage, and now that I've got my SES light issue resolved, the car goes to the local specialist for the sub-frame work. I didn't even think about the trailing-arm bushings... now I'm wondering if I should hold off until I can get those.[/QUOTE]
Considering how much work is involved in getting that sub chassis out, I think its worth while to do as much as you can bite off at a time. The TA bushing are cheap and IE will send them out immediately.
Was the work you had done itemized? I was quoted $500 for the adjustable subframe work, and that includes alignment. I'm not sure what extra (or if) they'll charge to install the bushings yet.[/QUOTE]
I can't speak for CA prices, but NYC area rates are a bit steep. $500 sounds very reasonable. Although I did not get an itemizaed bill, I would think thats a bit lower than what I paid for the brackets.
A good 4 wheel alighnement arount her can cost 125 to 200 alone.
Drop sub chassis , weld, prime / paint and re install-I would think 4 hours easy remember you are getting the car on the lift, removing rear calipers, exhaust,and entire subchassis- at $85 to $100 bucks an hour- you have another $340 to $400.
If your shop has the bushing removal kit he may not charge you much to remove and replace them. If he does not, he will break a sweat and charge you a couple hours work.
I think the problem we face when we are dealing with after market items, is fitment. Although the stuff works well, it takes some massaging to get right. That takes time.
The Super Sprint install alone takes a good hour or so to look right..then you test drive and bang it hits the butt strut
Short of it is, car has 50K miles on it. Car feels better than new on the road.
Motor mounts will go in- then when I need the services of Randy-I'll do the dual ear diff and replace those. Other than that I think all bushings are replaced ( can any one think of something else?).
Don't rush to get job done and have to go back in cause you missed something small that might provide big gains. I think the TA bushings would be worth the wait- just for the "its trick" factor alone :thumbup:
Daver said:
I thought the M already had hard bushings on the front suspension components. Are you still using the stock swaybar links?
