1 - 15 of 15 Posts
Daniel T
Hi All,
Yesterday was a pretty hot day in Perth WA (38 degrees) and this is the first time in 5 years the car overheated...
Strangely enough the thermo fans are coming on lots and the oil temp gauge is not getting anywhere near 120 degrees but when it does the thermo fans come on and cool down as per usual.
Any ideas its an F10 535i
Premium Member
Hi All,
Water pump?
Daniel T
Discussion Starter #3
Not sure but the heater still works well. It was warm today but the car didn’t overheat.
Premium Member
How long was the drive?
Water pump is a common problem on these cars at 70,000 miles plus. Mine went on my 2012 535i at about 94,000 miles. How many miles you got?
Daniel T
Discussion Starter #6 (Edited)
Saw a self diagnose video on YouTube so I performed the test. The video showed the pump just making that buzzing noise without pumping any water. Mine is making that buzzing noise then It’s pumps the water.
The test is performed by turning the car on without starting it, turn heater fan on to fan speed 1 and heat for max temp.
https://youtu.be/szu9IfNpYTc
Daniel T
Discussion Starter #7
Now this is weird I found another video of someone doing a bleed and the waterpump is making the same noise as mine
https://youtu.be/N6qkME07omM
Daniel T
Discussion Starter #9
Car isn’t overheating anymore which is weird but the oil temperature gauge is sitting really low. The attached photo is 2 hrs of driving with the outside temp at 38 degrees C
I just hit the $75K miles mark and my fan started surging on/off randomly although it is only 30-degrees outside. I read all the posts here and am quite sure it’s time for the water pump/thermostat replacement. :(
Does a faulty water pump cause the “drivetrain malfunction” warning to come on? I was idling in the car for about 45min. last week and the warning came on. I drove home “moderately” and it has not come on since.
Daniel T
Discussion Starter #12
I was getting the drivetrain malfunction warning until I changed the spark plugs now that has stopped. took the car into BMW and they said the water pump is cycling fine but they reported no faults at the time of test. I’m wondering if ESYS can show faults.
Does anyone know if it would be safe to drive the car short distances (<20mi.) until I can drop it off on Monday?
Daniel T
Discussion Starter #14
If I'm to guess if its the spark plugs that is causing the drive fault it would be fine to drive as long as you don't put your foot down just nurse the car until you get it to the shops.
Do the water pump test; if you think its the water pump
Step 1: Turn the car on without starting it
Step 2: Turn the heater fan on the speed 1
Step 3: turn on the heater to the hottest setting in Australia the max is 28 degrees
Step 4: Press throttle for 10 seconds and listen to the water pump.
Normal working water pump should sound like -
High-speed pumping noise then it will slow down and start making a clicking sound followed by nothing then repeats full speed pumping. During that process its an idea to not have surging 'start, stop, start, stop etc etc. make sure to take the overflow cap off and don't open it when the car is hot it will spray boiling hot water at you which will be very dangerous do it when the car is cold and open with a clean cloth over the cap.
Daniel T
Discussion Starter #15
Hi All,
The problem is discovered when I use the heater, The air con runs the car super smooth.
1 - 15 of 15 Posts
